3 Dimensional Pipe
3 Dimensional Pipe
arnou-verfaillie
Message 1 of 12
3 Dimensional Pipe
arnou-verfaillie
Hello
I want to make a sort of handle using the pipe command (I used this because I thought this would be possible).
1. So in the screencast below you can see, I want to make the bottem half of the two circles and connect them with another piece of pipe. I cannot select more than 1 curve, so I repeated the command 3 times and joined them. Tried to finish it with a fillet, but it looks hideous. Is there a way you can select more curves/ more dimensions for the pipe command. Or is there a better way to do this?
2. In the second "part" of the screencast (using the pipe command), why can't I make the pipe stop earlier towards the door, so that it doesn't stick out on the other side?
Thanks in advance!
Replies (11)
Message 2 of 12
Beyondforce
Hi @arnou-verfaillie,
Is that what you are looking for (you can use the Filet to make the corners nice and round)?
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 12
arnou-verfaillie
@Beyondforce
Yes, that's exactly what I want, but the pipe command did not allow me to choose multiple lines to construct a pipe...
Maybe there was a gap in between, I will try this again. This is strange!
Message 4 of 12
PhilProcarioJr
@arnou-verfaillie
Is this what your after?
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 5 of 12
Beyondforce
You gotta make sure when you create the rectangle, that you are touching the circular points!
Ben Korez
| YouTube
Message 6 of 12
sanjay_jayabal
Hi arnou-verfaillie,
Here is one way to do it.  I used sweep but you can also use Pipe and select the intersection curve as the path.  Hope this helps.
best regards,
Sanjay Jayabal.
Message 7 of 12
Beyondforce
@sanjay_jayabal,
Very interesting technique, I like it.
Ben.
Ben Korez
| YouTube
Message 8 of 12
jeff_strater
Here is an adaptation of @Beyondforce's workflow, but in a single sketch:
Jeff
Jeff Strater
Engineering Director
Message 9 of 12
Beyondforce
@jeff_strater, this is brilliant!
You are so smart and it's really annoying 🙂
Ben.
Ben Korez
| YouTube
Message 10 of 12
michallach81
I would go with most flexible way:
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Message 11 of 12
arnou-verfaillie
Thanks guys!
Every option seems to work! Apparently one point of my curve was not connected, is there any easy way to check this?
Message 12 of 12
jeff_strater
That's very clever @michallach81!  I love this method, because it is very easy to create the "guide solid"...
Jeff
Jeff Strater
