2D PDF Drawing Readable Quality Please?
Message 1 of 8
Hi, I have put alot of decals/labels into a control system cabinet with many internal hardware. My problem is that I want to save it in 2D drawing where all labels are readableThe quality of the decals are so bad I can't even read them. Thank you. ... Is there any other way to do this? I have tried using the Fusion Viewer but even those don't register the labels/decals 😕 The only way I can really see the labels is if I open the program in Fusion360 itself... which other people don't have. My ideal would be clear precise readable pdfs.  Thank you so much.
Replies (7)
Message 2 of 8
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for posting 🙂
If you use "Shaded" option, you are able to see the decals. but if you use the "Visible edges", it doesn't support yet.
However, I found your request in the ideastation and the status is implemented. we would be able to see the function soon. Smiley Happy
https://forums.autodesk.com/t5/fusion-360-ideastation-request-a/showing-decals-on-a-drawing/idi-p/6803756
Many thanks,
Ahreum.
Message 3 of 8
Hi, Thank you for the reply. But I'm afraid this is not what I meant. I had used shaded for it. I can see the labels. My problem is Output to PDF ... when I do save it, the quality of PDF is really bad I can't read the labels at all specially when I zoom in. I attached pic of what I meant. This is even biggest I could save with A0, ratio 1:1
Message 4 of 8
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for the reply..
Hum.... could you share your file to me? I'm not sure whether I can found a workaround. but I would like to give it a shot. my email address is ahreum.ryu@autodesk.com
I think if you extrude the shape, you would have better quality when exporting PDF.
here is QUICK TIP: How to emboss letters https://youtu.be/R-JYwL1rrxk
Many thanks,
Ahreum.
Message 5 of 8
Hi, Thanks for the reply again.  I'm not sure I am allowed to share the project, and as for emboss... it is too much time and effort.  I would like to use decals for labeling because there's so many and I can copy and paste premades from picture editor. Thank you.
Message 6 of 8
daniel_lyall
@Anonymous Fusion staff will do a NDA
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 7 of 8
TrippyLighting
I don't even think there is a NDA necessary. The quality of the PDF output of the drawing environment in Fusion 360 is is really no other word to describe it.
This is a known issue and has been reported many times.
Message 8 of 8
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for sharing your design.
When I put the shaded view in the drawing, the Decal image seems to display with lower resolution. so I reported this issue(FDWG-8265) to development team and if I receive any response, I will get back to you. Sorry for the inconvenience caused.
Many thanks,
Ahreum.
