2D Lines dissapearing when extruding.
If I draw something in 2D, then extrude part of it, then all the other lines etc disappear as well.
Is there anyway to stop this happening?
For example, I will want to extrude part of a drawing 10mm, then another part 5mm, when I extrude the first part 10mm then all the 2D part disappears.
Thanks.
davebYYPCU
Yes.
Fusion hides the sketch after that 1st operation,
Unhide the sketch with its eyeball.
There is a Preference setting to stop it as a permanent thing, (that it would never happen) but you need to decide how it suits you, so then the sketch will always be visible, and you would manually have to hide it, at some stage, or not.
Might help.....
Thats it.
Thanks very much.
