when viewing / editing a 2D drawing on a 4K monitor the drawing is only fully rendered on the top 60% of the screen area. ( ie if the drawing is maximised in the workspace the lower %40 is only partially rendered )
There is no problem with 3D views / webpages / other apps etc etc ... so its not my screen or graphics.
If I zoom the drawing to make it smaller and move it to the top half of the workspace it renders OK but this defeats the purpose of using a big screen ?? ;-0
See screenshot ... the drawing block is only partially rendered as described .... there is no design in this picture.
partial render
Hello Rushabh,
thank you for the answer, but id does not solve the problem, though there is some change. With the "Preferences >> Preview Features >> General >> HighDPIScaling (Windows Only)" setting switched ON, I had to override the "High DPI settings", then the issue disappeared at 150% window scaling. For 100% or 125%, or without override, the problem is still there.
With the "Preferences >> Preview Features >> General >> HighDPIScaling (Windows Only)" setting switched OFF, the situation is better. Now I could switch off High DPI override, and now it works with 125% or higher scaling. But at 100% it is still bad. Again, this is the "vanilla" setting, everything is default, so I suppose it would have to be fine.
I have a simple 4k monitor, Gforce MX 250 + UHD 620 video.
