Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to Edit VALUE of Text in a Sketch
4 REPLIES 4
fsonnichsen
301 Views, 4 Replies
I have never used text before---
How do I edit the VALUE of Text in a Sketch (see attached) once it has been entered?  Right-click, left-click, select-and-click.....nothing seems to work.  With the last method I get an amorphous pink selection area and a right-click shows an Edit Text option--but this only asks for a "path" and I am not doing text on a path
(very rarely a right click has rendered a panel where I can change the text but only very rarely!)
Fritz
4 REPLIES 4
g-andresen
in reply to: fsonnichsen
Rightclick sketch > EDIT SKETCH
günther
fsonnichsen
Thanks Gunther--apparently one must click exactly on the text item--not the box. I enlarged the area and it worked OK after that.
Fritz
bwnicholspe
Ay yi yi, spent about 10 minutes trying to figure why I couldn't edit text -- remember to check status of your selection filters!
fsonnichsen
in reply to: bwnicholspe
Good.
 I certainly hope the Fusion teams monitors issues like these when they add features to future releases. Seems like software a one time was more intuitive and the authors would attempt to guess the most likely move of the user to accomplish something and then make it happen that way.
   Lately I have reams of "cheat sheets" that I need for how to do things with various languages and products because they are so inconsistent
cheers
Fritz
Technology Administrators
