2 Point Align - How
2 Point Align - How
docara
2 Point Align - How
docara
Hi
How do you align two components based on 2 points when you use the Align command instead of using a face and an (approximate) angle?
An example - 2 plates with 2 holes all aligned nicely and constructed in place via Project etc. I now want to replace one of these plates with a third (constructed earlier) having the same 2 holes but sketched in a different orientation.
I'mm guessing the nearest equivalent would be the 3d Align command in Autocad.
Thanks again
Matt
davebYYPCU
Use joints with components, on the hole centres.
g-andresen
Hi Matt,
are you looking for this?
günther
docara
Hi Geunther and Dave,
Many thanks to you both
Yes this procedure was what I was looking for - somewhat counteractive - to me joints are only used in assemblies - learnt something new
Thanks again
Matt
