Flat Pattern
Flat Pattern
paul.slaterMZZFE
Flat Pattern
paul.slaterMZZFE
Is it possible to make a flat pattern of a cone? thanks Paul S
Brady_Fulton
Possible? Yes, but the only way I can think of it would be quite tedious. Lots of small flanges and face moves (rotate).
If you just need a pattern, you can create a sketch and use parameters and math to generate that. I did a google search and see lots of good examples with the formulas you'd need:
https://www.google.com/search?q=flat+pattern+of+a+cone&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwiO...
paul.slaterMZZFE
Thank you. this is my first post on the forum. I am new to Fusion and did not know if it was possible straight out of the box.
