1/2 UNF-20 ANSI Thread
Hi guys,
I'm loosing miry mind trying to thread a simple cylinder with a UNF 1/2-20 thread. Any idea? I need to CNC a nut to hold that thread behind a 6mm alloy plate. Anything I'm trying is not working and there's no chance to get the OK icon.
Cheers
Luca
AmandaFowler
Hi Luca
Welcome to the Fusion 360 forums - Are you trying to model a machinable thread or are you just looking to get a toolpath? If you're looking to model the threads - I made a quick video showing how. If you're looking for just the toolpath - have you tried using the 2D Thread toolpath on a hole placed where you want the thread? If I'm misunderstanding something - it might be helpful to attach your file to this thread so we can better help you out.
Thanks!
Amanda Fowler
Technical Support Specialist (CAM / HSMWorks)
Hi Amanda and thanks for the answer.
Apparently I was doing all correct, was just a software problem immediately after the upgraded version release. Had to move the scene a bit in any direction to get the OK button working, don't know why but it's not doing It anymore.
Thanks and good day.
Luca
