Unexpected behavior with ui.activeSelections
I'm trying to write a script that does essentially the following:
- Find bodies inside components.
- Select them.
- Create a selection set from the selected bodies.
- Deselect them
- Select other bodies.
- Create a selection set from these selected bodies.
- Deselect them.
- Repeat
I've managed to write a script that successfully finds bodies inside a design, select them, and then is supposed to create a selection set from them. However, when I run
ui.activeSelections.clear()
to clear the selections, the selection set created by the script is empty.
I don't really get it, and I'm kind of at a loss as to what to do. Here's the script:
#Author- #Description- # https://forums.autodesk.com/t5/fusion-360-api-and-scripts/api-for-working-with-selection-sets/td-p/8837150 import adsk.core, adsk.fusion, adsk.cam, traceback import re # Produces empty selection set when it should produce a selection set containing selected bodies then clear the selection set. def run(context): ui = None try: app = adsk.core.Application.get() ui = app.userInterface design = app.activeProduct rootComponent = design.rootComponent # Add all bodies in components to acrtive selections allComponents = rootComponent.allOccurrences for component in allComponents: componentName = component.name.split(':')[0] bRepBodies = component.bRepBodies for body in bRepBodies: ui.activeSelections.add(body) # Create selection set cmd = ui.commandDefinitions.itemById('CreateSelectionGroupCmd') cmd.execute() # Clear selections ui.activeSelections.clear() except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
I made a screencast of the script creating an empty selection set. Here's a direct link in case it doesn't work: https://autode.sk/36elSyz
And I've also attached the test design illustrating the problem.
Thanks for the help, and I'm happy to answer any questions!
