Unexpected behavior with ui.activeSelections
rmiglioriEKDK2
rmiglioriEKDK2
I'm trying to write a script that does essentially the following:
  • Find bodies inside components.
  • Select them.
  • Create a selection set from the selected bodies.
  • Deselect them
  • Select other bodies.
  • Create a selection set from these selected bodies.
  • Deselect them.
  • Repeat
I've managed to write a script that successfully finds bodies inside a design, select them, and then is supposed to create a selection set from them. However, when I run
ui.activeSelections.clear()
to clear the selections, the selection set created by the script is empty.
I don't really get it, and I'm kind of at a loss as to what to do. Here's the script:
#Author-
#Description-
# https://forums.autodesk.com/t5/fusion-360-api-and-scripts/api-for-working-with-selection-sets/td-p/8837150
import adsk.core, adsk.fusion, adsk.cam, traceback
import re
# Produces empty selection set when it should produce a selection set containing selected bodies then clear the selection set.
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = app.activeProduct
        rootComponent = design.rootComponent
        # Add all bodies in components to acrtive selections
        allComponents = rootComponent.allOccurrences
        for component in allComponents:
        	componentName = component.name.split(':')[0]
        	bRepBodies = component.bRepBodies
        	for body in bRepBodies:
        		ui.activeSelections.add(body)
        # Create selection set
        cmd = ui.commandDefinitions.itemById('CreateSelectionGroupCmd')
        cmd.execute()
        # Clear selections
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
I made a screencast of the script creating an empty selection set. Here's a direct link in case it doesn't work: https://autode.sk/36elSyz
And I've also attached the test design illustrating the problem.
Thanks for the help, and I'm happy to answer any questions!
kandennti
Hi rmiglioriEKDK2.
At the end of the command, I felt that the selection set was completed, so I created the following code.
However, only an empty selection set was made.
Since it is not provided by API, it seems impossible.
_app = None
_ui  = None
_handlers = []
class MyExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            cmd = _ui.commandDefinitions.itemById('CreateSelectionGroupCmd')
            cmd.execute()
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyCommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            adsk.terminate()
        except:
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            cmd = adsk.core.Command.cast(args.command)
            onExecute = MyExecuteHandler()
            cmd.execute.add(onExecute)
            _handlers.append(onExecute)
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
        except:
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        cmdDef = _ui.commandDefinitions.itemById('test')
        if cmdDef:
            cmdDef.deleteMe()
        cmdDef = _ui.commandDefinitions.addButtonDefinition('test', 'test', 'test')
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        des = _app.activeProduct
        root = des.rootComponent
        occs = root.allOccurrences
        for occ in occs:
            bRepBodies = occ.bRepBodies
                _ui.activeSelections.add(body)
            cmdDef.execute()
            _ui.activeSelections.clear()
except: if _ui: _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
rmiglioriEKDK2
So even your attempt creates an empty selection set? Wow. I really wonder what is going on that clearing active selections executes with a higher priority than anything else.
Sorry to take this in another direction, but I have another question. How could I run one script from another script? Is that possible to do ?
kandennti
I'm sorry to bring up the old story.
With Ver2.0.8335, I found that this method can be used for processing.
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
def run(context):
    try:
        global _app, _ui
        des  :adsk.fusion.Design = _app.activeProduct
        root :adsk.fusion.Component = des.rootComponent
        txtCmd :str = 'NuComponents.CreateSelectionGroupCmd'
        actSels :adsk.core.Selections = _ui.activeSelections
        for occ in root.allOccurrences:
            actSels.clear()
            [actSels.add(body) for body in bRepBodies]
            _app.executeTextCommand(txtCmd)
        actSels.clear()
        _ui.messageBox('done')
    except:
        if _ui:
