I'm working on a plugin that allows modelers to apply soft constraints to their models (more than just numerical constraints on parameters) and I want to alert the user when one of their constraints may be validated after an action.
Is there a way to continuously track the user's actions from the plugin API. I see there are mouse events but they are specific to one command and I don't think are tracked while the user uses a different command. I want to be able to check the constraints when the user adds or modifies bodies in the design. Is this possible?
Solved by ekinsb. Go to Solution.
Check my reply to your other question. You asked something similar there so I answered it there before I saw this question.
