ImportSplineAnyCSV is an improved version of the ImportSplineCSV script that reads data from a CSV file and creates a spline in a sketch.
This version supports:
Codes and information are posted on GitHub: https://github.com/JeromeBriot/fusion360-import-spline-any-csv
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
Your script works great!
Thank you for not being indifferent to the problems of less experienced users:)
I followed your instructions but the error message comes up like this. What would be the problem?
Please tell me what should I do...:(
Can you reach https://github.com/JeromeBriot/fusion360-import-spline-any-csv on a web browser?
Did you download and install the GitHubToFusion add-in?
github.com/JeromeBriot/fusion360-import-spline-...
how to use ? please i am fully blocked in writing a process os desining tool
not
how to load i don t get message to past in script
hhttps://github.com/JeromeBriot/fusion360-import-spline-any-csvd
