Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
New add-ins for Windows: Toolbar & Shortcuts Editor and Extra Shortcuts
18 REPLIES 18
Message 1 of 19
axalea_thomas
2311 Views, 18 Replies
I'm developing two add-ins for Fusion 360 on Windows. First and foremost Toolbar & Shortcuts Editor (TSE), which is complemented by Extra Shortcuts (ES).
TLDR: Download here: https://apps.autodesk.com/en/Publisher/PublisherHomepage?ID=QF2AP7A29Y9C
I would like to have some feedback. Especially information on any assigned keyboard shortcuts getting reset. (Please include command, assigned shortcut and when it was reset.)
Although the Toolbar & Shortcuts Editor lists a lot of commands, not all of them can be executed. Please try the commands you intend to use. The Extra Shortcuts add-in is a remedy for this problem, where it reimplements common commands and allows them to be executed.
Toolbar & Shortcuts Editor features
  • Add commands to any toolbar panel/menu.
  • Favorites panel, that is available on every tab. One for each workspace.
  • Assign keyboard shortcuts for many commands*.
  • See keyboard shortcut assignments (experimental).
  • Easily pin and unpin commands on panels.
  • Forced shortcuts: Assign keyboard shortcuts to any keyboard key and override unchangeable Fusion 360™ keyboard shortcuts (experimental).
  • Beta v0.0.6: Forced shortcuts: Assign mouse buttons (combined with ctrl, alt, shift) as shortcuts. (Buttons: Left, middle, right, back, forward). (experimental)
* Some existing shortcut keys revert when Fusion 360 is restarted. Not all commands work with shortcut keys.
NOTE: Some commands, although listed, are not meant to be executed directly. They might not do anything or, in the worst case, crash Fusion 360 when they are run.
Trial limitations:
- Only one added menu item will be saved
- Edit 3 keyboard shortcuts per start
- Forced keyboard shortcuts will not be saved
If you find any useful commands, please share them in the comments!
Are the keyboard shortcuts forgotten after restarting the add-in or Fusion 360? Please comment with what you did and what commands you used!
Try restarting Fusion 360 and see if the shortcut is restored.
Extra Shortcuts features
* Provides copies of common Fusion 360 commands, that normally can't have a keyboard shortcut assigned to them.
This add-in complements Toolbar & Shortcuts Editor, so it does not include commands that are already possible to assign shortcuts to and run correctly.
Trial limitations:
- Starts showing a nagging dialog after running 15 commands. The count is reset when Fusion is restarted.
Some popular commands to assign keyboard shortcuts to
Provided by Extra Shortcuts
Look At in Sketch mode and Design mode
View top, right, etc (Orthographic views)
Rotate model
View Perspective, Orthogonal
Go Home ("Home view")
Selection Filters: Select All
Show/Hide Layout Grid
Toggle Snap to Grid
Toggle Incremental Move
Move Timeline forwards/backwards
Switch to different workspace
Activate Selected (activates the selected component or the component to which the selected entity belongs)
Activate Root Component
Show/Hide User Work Planes
Already available in Fusion and easily accessible using Toolbar & Shortcuts Editor:
Paste New - FusionPasteNewCommand (A component must be selected)
Isolate, isolate all & unisolate - IsolateCmd, UnisolateCmd, UnisolateAllCmd
Activate component - FusionActivateLocalCompCmd
Set and reset orbit center - SetOrbitCenterCommand, ResetOrbitCenterCommand
Zoom Window (drag a rectangle) - ZoomWindowViewCmd
Show All Bodies/Components (for selected in Browser) - ShowAllBodiesCmd, ShowAllComponentsCmd
Pan - PanCommand
Zoom - ZoomCommand
Download
https://axalea.se/downloads/beta.html
FAQ
  • Why is the Favorites panel at the end of the toolbar?
    Due to restrictions in the add-in interface provided by Fusion 360.
  • Can all controls be edited?
    Currently, pre-existing menu items cannot be removed.
  • The configuration window keeps disappearing when I'm in the drawing workspace.
    For some reason, Fusion 360 puts itself on top if the mouse hovers the drawing area.
    Try making the windows smaller or open the configuration window when you have another workspace active.
  • I pinned/unpinned a command in the Favorites panel using the "..." menu, but the change is lost after restarting Fusion 360.
    Currently, pinning of favorites must be edited using the configuration window to be stored correctly.
  • Why do the beta versions have trial limitations?
    While the add-ins might still have quirks, they are already very useful in the current state. Licenses will be sold at https://store.axalea.se .
  • I tried to assign a shortcut to command X or place it in a menu, but it does not work when I click on it.
    Unfortunately, not all built-in commands can be directly executed. Some can be recreated and can then be implemented in Extra Shortcuts.
Thomas @ Axalea
Try the Toolbar & Shortcuts Editor and Extra Shortcuts add-ins - assign any key (and some mouse buttons) as keyboard shortcut! - Assign shortcut to Front, Home view, Look At, Timeline Back ... - (Windows only)
18 REPLIES 18
Message 2 of 19
I wish I could organize the s menu.  right now shortcuts just get jumbled on in what ever order they are added.  with one hand on the mouse and one hand on my space mouse I tend to use the s menu more than keyboard shortcuts.
Message 3 of 19
You can organise them now.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 19
you can arrange the order, but you can't put them in logical groups on different rows.
Message 5 of 19
Same here. Simple separators would already help.
Message 6 of 19
Extra Shortcuts v0.0.2 uploaded!
New commands:
* Show/Hide Layout Grid
* Toggle Snap to Grid
* Toggle Incremental Move
(No icons)
Thomas @ Axalea
Message 7 of 19
@laughingcreek @TrippyLighting
I couldn't resist and threw together a quick and dirty solution for the S menu arrangement. What do you do when you need to fill some space? Add spacers! It's cludgy, but it kind of works, I think.
  1. Download the attached Zip file. Unpack it.
  2. In Fusion, press Shift+S, open the Add-ins tab and click the Green plus.
  3. Select the "Spacers" directory.
  4. Click Run.
The add-in is barely tested at all.
Usage:
Press "S". Search for "Axalea Spc". Add some spacers using the arrow button. Then rearrange the icons by dragging.
Thomas @ Axalea
Message 8 of 19
Some small updates.
Extra Shortcuts v0.0.3:
  • Perspective/Orthographic view feature stabilized
  • Look At Sketch restored (menu item was missing)
Toolbar & Shortcuts Editor v0.0.4:
  • Insert command after selected when clicking "Add >>"
Thomas @ Axalea
Message 9 of 19
terryHCEB7
in reply to: axalea_thomas
This is an excellent addition to help users customize the UI to their preferred work flow.
Thank you for this!
Message 10 of 19
Big update!
Toolbar & Shortcuts editor v0.0.5.
Forced keyboard shortcuts allows you to use any key* for a shortcut. It is also possible to override unchangeable shortcuts in Fusion. :party_popper:
*Please give it a good spin! My keyboard does not have multimedia keys, so I would appreciate to get feedback on such keys (play, stop etc).
Thomas @ Axalea
Message 11 of 19
Two new commands added to ExtraShortcuts (v0.0.4):
  • Smart Active Component (activates the selected component or the component to which the selected entity belongs)
  • Activate Root Component
Thomas @ Axalea
Message 12 of 19
Extra Shortcuts v0.0.5 uploaded:
  • Look At commands combined into one: Look At (Universal)
  • Fixed add-in failing to load and not showing its icon
  • Smart Activate Component renamed to Activate Selection
  • Icons for all commands
Thomas @ Axalea
Message 13 of 19
WesleyTack
Thomas,
Something that would be useful to add as a shortcut is to be able and hide/unhide (toggle) the work planes:
Is that something that's possible to add? This would allow for quick removal of vital mirror planes clutter you don't need while designing.
Sincerely,
- Wesley Tack
Message 14 of 19
axalea_thomas
in reply to: WesleyTack
Yes!
Extra Shortcuts v0.0.6 is now uploaded. Download
Changes:
  • Show/hide User Work Planes added (under Display Settingsm menu)
  • Camera type moved to Display Settings menu
Toolbar & Shortcuts Editor is now available the Autodesk app store.
Note however that it does not yet have the Forced Keyboard Shortcuts feature. I'm still in the process of getting Extra Shortcuts approved. Once both are approved, I intend to upgrade them to the latest versions, if no bugs have been reported towards them.
Uninstall the beta versions before installing the app store versions (different installer).
Thomas @ Axalea
Message 15 of 19
Both add-ins are finally released and available in the Autodesk app store!
Thomas @ Axalea
Message 16 of 19
Toolbar & Shortcuts Editor v0.0.6 (beta) is now uploaded!
(Extended with Extra Shortcuts in the above screenshot)
You can now use mouse buttons in Forced shortcuts! (5 buttons are supported. "Super mice" with their own software will still likely require that software.)
Please only install either the beta or release version at the same to avoid any conflicts.
Beta downloads:
Thomas @ Axalea
Message 17 of 19
Toolbar & Shortcuts Editor v1.0.0 has now been released in the app store!
* Mouse button support (same as in v0.0.6 beta)
https://apps.autodesk.com/FUSION/en/Detail/Index?id=6203905753706706460&appLang=en&os=Win64
Thomas @ Axalea
Message 18 of 19
I just want to say thank you. You simply did what people've been waiting for for years. It makes everything so much easier. ♥
Message 19 of 19
Thank you! I'm glad to hear that the add-ins are useful. 🙂
Thomas @ Axalea
