Fusion 360
AddIn Start Failed: Traceback (most recent call last):
File "C:/ProgramData/Autodesk/ApplicationPlugins/SlicerforFusion360.bundle/Contents\packages
\Fusion360CommandBase.py", line 186, in onRun
newControl_ = toolbarPanelTwo_.controls.addCommand(commandDefinition_, '', False)
File "C:/Users/------/AppData/Local/Autodesk/webdeploy/production/d114930713fc09ae573cf2ada6f60182d13cd0ed/Api/Python/packages\adsk\core.py", line 13238, in addCommand
return _core.ToolbarControls_addCommand(self, *args)
RuntimeError: 2 : InternalValidationError : res
OK
ETFrench
The Slicer add-in works fine on my machine with the lastest version of Fusion 360
How did you install this add-in? The install path is not the same as the one on my computer:
C:\Program Files (x86)\Autodesk\Slicer for Fusion 360\bin
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
@etfrench Hey I was getting the same error message. I remembered going into Preferences/Preview and ticking the 'UI Preview' after Fusion 360 updated, so I could try out the Tabbed controls. It was after this that the error started but I was thinking it was the new version. I went back and turned off/disabled the 'UI Preview' and the error went away. Give that a try and see if it fixes your error. If it does then something in the UI Preview is interfering with the Slicer plugin.
Please keep us update.
On my Windows computer with June 4 update, Slicer For Fusion 360 works fine with both UI Preview and default UI.
I was having this same issue and couldn't seem to find an answer that worked for me. Since I don't do much 3D printing and I have it sent to Cura anyway, I opted to shut off the slicer at start up. These are the clicks I did.
manufacture workspace
utilities tab
add-ins tab
scripts and add-ins
When box pops up...add-ins tab
click on Slicer for Fusion 360
uncheck Run on Startup
closed out fusion and started it back up again....error gone.
I can finally go back to starting Fusion and walking away while it's starting without having to wait to click on the error box.
