Currently, I'm using this:
tickLine = sketchLines.addByTwoPoints(adsk.core.Point3D.create(Top, xpos, 0), adsk.core.Point3D.create(Bottom, xpos, 0))
Solved by OceanHydroAU. Go to Solution.
Solved by kandennti. Go to Solution.
Hi @owendelong -San.
Sketch processing is slow.
The only thing that might work is the Sketch.isComputeDeferred property, but it will still be slow if there is a lot of it.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-a174973f-79ac-4330-8dd7-3d3ded63e63e
Other options are,
・Create your own logic to create the DXF and load the DXF.
・Abandon the sketch and create the 3D model directly.
Since the point here is to produce a DXF that can be used for Laser Cutting, direct 3D object creation isn't really a useful solution.
I suppose creating the DXF without involving Fusion is an option, but that seems like it would involve a significant amount of recoding. I guess for now, I'll just live with the slow.
Interestingly, it seems to get slower the more lines you have in the sketch.
I will look into the deferred Compute option.
Deferred Compute isn't a panacea, as you stated, but it definitely helped quite a bit. Script now seems to build the sketch in about half the previous time.
@owendelong -San.
Very interesting. Could you be more specific? Many people must have the same problem.
Well.. I'm not sure how much more specific I can be, but basically, I turned this (times 7 python dictionary entries):
myParameters = { 'Type' : False }
into this:
if (myParameters.itemByName("Type"))
myParameters.itemByName("Type").value = False
else:
myParameters.add("Type",adsk.core.ValueInput.createByBoolean(False),"",
"False for Linear, True for Grid")
I also removed several calls to this function:
def debug(ui, *args, **kwargs):
buf = io.StringIO()
print(*args, **kwargs, file=buf)
ui.palettes.itemById('TextCommands').writeText(buf.getvalue())
However, where most of the performance improvement happened, wasn't where most of the removed calls were located, so I have to think that the former had more to do with the speed gain than the latter.
Unfortunately, it's a fairly hairy script (with some embarrassingly quick and dirty code elements) that I think would have limited value to the community.
This sounds promising:-
sketch.isComputeDeferred = True / sketch.isComputeDeferred = False
but does not work for me.
But the reason it is slow is because every new line you're drawing "touches" in some way some other thing already, and those 200ms is Fusion working it's hardest to prevent inserting duplicated things. If you can add lines in an order to minimize how they coincide with anything else, that will drastically speed things up.
I was able to improve some really bad issues by inserting things in a deliberately wrong place, then moving them to where they should be.
A better bet would be to investigate how to turn off that optimising thing that's de-duping your inserts.
you know that python can directly create DXF files (ezdxf I think?), and that fusion360 can read them - right ?
@owendelong -San.
I didn't understand it even though you went out of your way to explain it to me. I am sorry.
I know this is a different topic, but can you create a user parameter without units here? I get an error.
That actually makes some sense as to why making it into userParameters instead of an internal python Dictionary in my script would accelerate things, then. Since the values are being pulled from Fusion's userParameters, it has probably cached/pre-computed a number of things related to de-dup.
@owendelong -San.
Thanks for explaining the parameters. I was indeed able to create a unitless user parameter with the CreateByReal method.
Can I create parameters with Boolean type?
I have tested with the following code, but they all give an error.
# adsk.fusion360API Python script
import traceback
import adsk.core
import adsk.fusion
def run(context):
ui: adsk.core.UserInterface = None
try:
app: adsk.core.Application = adsk.core.Application.get()
ui = app.userInterface
des: adsk.fusion.Design = app.activeProduct
myParameters: adsk.fusion.UserParameters = des.userParameters
myParameters.add(
"Test",
myParameters.add(
"Test",
False,
myParameters.add(
"Test",
adsk.core.ValueInput.createByString("False"),
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
The CreateByString method does not generate an error, but it does on the GUI.
I could have sworn I had createByBoolean working previously, but I certainly haven't been able to get it working since it stopped. Because the script is under very active development, there were a lot of changes at the same time, so it's possible that the switch from createByReal to createByBoolean happened after the last test run and before the other changes that prompted the next test run where things were broken.
Interestingly, as I also mentioned in the other thread, assignment of a boolean value to an existing parameter seems to work (e.g. userParameter_var.value=True), so I'll probably create a Real and then set the boolean value as a workaround for now.
Etch/Cut DXF layers would be good. Native LightBurn support or similar would be even better, one where I could identify the different power/speed/pulse(where applicable) settings as part of the CAM process (similar to the way you select different end mills for a milling process) and output a file that can be directly loaded into the LASER control software would be unimaginably wonderful.
(LASER equivalent of the ShopBot post processor, for example)
Yes, the current project is transparent acrylic rulers. The script I'm writing is capable of producing sketches suitable for cutting thin wood or acrylic on the laser with etched unit lines. It can do either linear (one or two long sides with same or different units (imperial/metric)) or grid (frequently used in graphic layout and/or textiles) rulers with the same units on all 4 sides, frequently wider (think 7-15cm wide and upwards of 40cm long) and unit grids with sub-unit ticks on all the grid lines.
You can set two things on a sketch that should speed up the creation.
Any operation in Fusion has a few costs. First is the internal cost of calculating the result for whatever you're creating. This is trivial for a sketch line but expensive for a complex loft. Second, the result may also involve other calculations to update related geometry. When drawing sketch geometry, this includes the things we're trying to skip with the properties listed above. When editing a feature or changing a parameter, there is the cost of updating all of the features in the timeline after the feature that is modified. Finally, there is some cost of transacting all of that work so it can be undone.
Regarding the Boolean parameter, Fusion only supports numeric parameters and as a result, that's all the API supports.
