Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Inconsistency between Matrix3D.translation documentation and actual behavior
6 REPLIES 6
nnikbin
1099 Views, 6 Replies
Based on Matrix3D.translation documentation:
it "Gets and sets the translation component of the matrix"
but setting it actually resets the matrix to an identify matrix, then sets the translation.
Here is a code block showing this inconsistency:
import adsk.core, adsk.fusion, adsk.cam, traceback, math
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        transform = adsk.core.Matrix3D.create()
        transform.setToRotation(math.pi/3, adsk.core.Vector3D.create(0, 1, 0), adsk.core.Point3D.create(0, 0, 0))
        ui.messageBox(str(transform.asArray()))
        transform.translation = adsk.core.Vector3D.create(20, 20, 20)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
The following picture shows the result:
Navid
6 REPLIES 6
jan_priban
in reply to: nnikbin
Hi Navid,
I can share my script that creates copy of component in the active document. There is also Matrix3D.translation and it works as expected. So you can use it for your propose.
It modifies translation matrix by setCell method
trans.setCell(0, 3, 15.0);
Regards
Jan (Autodesk Fusion 360 team)
//Author-JP
//Description-tocite schody
function run(context) {
"use strict";
if (adsk.debug === true) {
/*jslint debug: true*/
debugger;
/*jslint debug: false*/
var ui;
try {
var app = adsk.core.Application.get();
ui = app.userInterface;
var product = app.activeProduct;
var design = adsk.fusion.Design(product);
if (!design) {
ui.messageBox('No active Fusion design', 'No Design');
return;
// Get the root component of the active design.
var rootComp = design.rootComponent;
var occs = rootComp.allOccurrences;
// Gather information about each unique component
var count = occs.count;
ui.messageBox(count.toString(), 'pocet');
//jmena vsech component
var i;
for (i = 0;i < count;++i) {
var comp = occs.item(i).component;
ui.messageBox(comp.name, 'jmeno');
//var comp = occs.item(0).component;
//var jmeno = comp.name
//ui.messageBox(jmeno,'jmeno');
// Create a new occurrence.
var trans = adsk.core.Matrix3D.create();
//var occ = rootComp.occurrences.addNewComponent(trans);
// Get the associated component.
//var newComp = occs.item(i).component;
//var newComp = occ.component;
// Create a new occurrence for the component, offset by 15 cm in the X direction.
var newOcc = rootComp.occurrences.addExistingComponent(occs.item(0).component, trans);
//ui.messageBox('Hello script');
catch (e) {
if (ui) {
ui.messageBox('Failed : ' + (e.description ? e.description : e));
adsk.terminate();
ekinsb
Thank you for reporting this.  This is not expected behavior and I've logged a bug for the problem.  Following up with Jan's response, a workaround is to set the specific cells of the matrix that define the translation.  Here's a modified version of your code that creates the correct result.
import math
def run(context):
    ui = None
    try:
        #transform.translation = adsk.core.Vector3D.create(20, 20, 20)
        transform.setCell(0, 3, 20) # X component of translate
        transform.setCell(1, 3, 20) # Y component of translate
        transform.setCell(2, 3, 20) # Z component of translate
    except:
        if ui:
Brian Ekins
Mod the Machine blog
nnikbin
in reply to: ekinsb
Hi Brian,
Thanks for logging the bug. I was aware of the workaround by using setcell. I just wanted to report the issue.
Best regards,
Navid
nnikbin
in reply to: jan_priban
Hi Jan,
Thanks for your reply,
As Brian confirmed,  "This is not expected behavior"
Best regards,
Navid
keqingsong
Good news! We are getting this fixed in the next update coming this December!
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
nnikbin
in reply to: keqingsong
Hi Keqing,
Thanks for your good news 🙂
Navid
