Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to create a mirror feature with a Join Operation?
3 REPLIES 3
tiktuk
289 Views, 3 Replies
I would like to mirror a body, it works fine except that the operation by default is set to New Feature and I want it to be a Join Feature (adsk.fusion.FeatureOperations.JoinFeatureOperation). I checked and it does not have an operations attribute to set this, like for example the Extrude Feature does.
So how to set this?
# This works
mirror_feature_input = features.mirrorFeatures.createInput(
    adsk.core.ObjectCollection.createWithArray([quarter_body]),
    length_midplane
mirror_feature = features.mirrorFeatures.add(mirror_feature_input)
# Would like to be able to do this
mirror_feature_input.operations = adsk.fusion.FeatureOperations.JoinFeatureOperation
3 REPLIES 3
tiktuk
in reply to: tiktuk
Without being able to set up the mirror feature with the join operation I end up with two bodies instead of one, as shown in the following screen shots:
CADacombs
in reply to: tiktuk
You may just need to include
mirror_feature_input.isCombine = True
because that property is False by default.
tiktuk
in reply to: CADacombs
Thank you so much, I must have been so focused looking for something with 'join' that I skimmed right over this..
