Export sketches from all components
meister_mischler
meister_mischler
A few weeks ago I found this handy script: https://forums.autodesk.com/t5/forums/forumtopicprintpage/board-id/22/message-id/15949/print-single-...
Sometimes it worked and sometimes it did not (or so it seemed to me). Today I talked to a guy with programming skills and we found out that the script only exports DXF sketches in active components. As my DXF are nested in components I would like to change this.
How can I change that? Is there something like "allComponents" instead of "activeComponent"?
 design = adsk.fusion.Design.cast(app.activeProduct)
 active_component = design.activeComponent
 sketches = active_component.sketches
Thanks for all your hints. 🙂
rohit.bapat
Hello @meister_mischler
I have a suggestion here, instead of fetching Sketches only from the active components you can loop through the components within the document and fetch sketches from each. For example
allComponentsInDesign = design.allComponents
for component in allComponentsInDesign:
  sketches = component.sketches
Please let me know if this satisfies the requirement.
Rohit Bapat
Product Owner
meister_mischler
Thank you for your reply 🙂
If I replace this:
with this:
and leave all the other lines untouched I only get the "DXF_files" from the first component in the tree. What do I have to add to loop over all components?
rohit.bapat
For that you will have go loop in this order
Components
   -> Loop to fetch a Component
   -> Fetch Sketches from this component
        -> Loop Sketches to access each Sketch
        -> Export DXF
I haven't tested following code but it should work
# Online Python - IDE, Editor, Compiler, Interpreter
import adsk.core, adsk.fusion, adsk.cam, traceback, os
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        folder_dialogue = ui.createFolderDialog()
        folder_dialogue.title = 'Select folder to export all DXFs'
        result = folder_dialogue.showDialog()
        if result == adsk.core.DialogResults.DialogOK: # If the user clicks on the "Select Folder" button
            export_folder = folder_dialogue.folder
                for sketch in sketches:
                    if is_dxf(sketch):
                        full_path = os.path.join(export_folder, sketch.name) + '.dxf'
                        sketch.saveAsDXF(full_path)
        else: # If the user clicks on the "Cancel" button
            ui.messageBox(f'No folder selected')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Unless there is any compilation issue, above code should work. (I got this code from the forum post you linked in original post)
Thank you!
Rohit Bapat
Product Owner
meister_mischler
Perfect, thanks 🙂
I added these lines and then it worked:
def is_dxf(sketch):
  if 'DXF' in sketch.name:
    return True
Hopefully I can extend the script so it lists the exported dxfs. But that's something for the weekend. 🙂
rohit.bapat
Nice! I am glad it worked for you
Cheers
Rohit Bapat
Product Owner
meister_mischler
Its not yet weekend but the job is done. 😉
https://github.com/3kmch/fusion-scripts/tree/main/Export_DXF-Sketches
