Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
how can merge faces in same body?
1 REPLY 1
ho-kou
189 Views, 1 Reply
ho-kou
Hi, everyone
I want use merge to join same faces in the same body.
But i can not find the api to do it.
Who konw the merge api like the picture.
Thank you for your help.
Hi, everyone
1 REPLY 1
kandennti
in reply to: ho-kou
kandennti
Hi @ho-kou -San.
Since merge commands do not seem to be provided by the API, this sample uses text commands.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        if des.designType == fusion.DesignTypes.ParametricDesignType:
            ui.messageBox("Valid only in direct mode.")
            return
        root: fusion.Component = des.rootComponent
        exec_surface_merge_command(root.bRepBodies[0])
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def exec_surface_merge_command(
        body: fusion.BRepBody
) -> None:
    ui: core.UserInterface = app.userInterface
    sels: core.Selections = ui.activeSelections
    [sels.add(f) for f in body.faces]
    app.executeTextCommand(u"Commands.Start FusionSurfaceMergeCommand")
    app.executeTextCommand(u'NuCommands.CommitCmd')
In the GUI, the merge command is only available in direct mode, but when I tried it, it worked in parametric mode as well.
However, since nothing appears on the timeline, we felt that this might cause problems, so the sample works only in direct mode.
Hi @ho-kou -San.
import traceback
def run(context):
    try:
            return
    except:
        if ui:
) -> None:
