I activated the tryal to check the inspection tab a little bit more .
Where I need a bit of help is , i need to measure the diference betwen 2 surfaces that are parallel and tolerated and need to print the measure result on display controller using the variable #10188 because you can go on current comands and where you can reset M30 counter you can set variables to show below the M30 counter .
For short I need to be able to measure surface 1 - surface 2 and the result to be shown on the controller display .
Can anny one help me on this matter , I attache a photo with the model.
