From Python to C++
From Python to C++
bernard5BABD
From Python to C++
bernard5BABD
I have an add-in written in Python, which has been downloaded numerous times. I am thinking about expanding it (or writing a new one based on it), but I would like the new version to be paid for. I believe that to protect the code, I have to write in C++ and compile it.
Is there a way to "translate" Python to C++, or should I prepare myself to rewrite everything in C++?
The correlative question follows: is there a way to compile and protect Python code? I know you can compile it for standalone programs, but not sure with Fusion 360 API.
Thanks for your help, advice, pointers, and best regards,
Bernard
Bernard Grosperrin, Retired, Maker, and Autodesk Certified Instructor
Blog : Le Bear CNC | Forum : Le Bear CNC Forum | Addin : Airfoil Sketch from file
JeromeBriot
AFAIK, no.
Well, that depends on your skill in C++ programming. Distribute compiled C++ code is the safer way for sure. But does it worth the effort and the time spent in rewriting the all code ?
You can compile Python code in .pyc files using compileall or py_compile modules. The .pyc files are binary files not readable by humans (read limitations here: Important Python Version Change Information).
I attached a script example to this message.
First I wrote the code in the source/message.py file. Then I opened a terminal, I went to the folder where the py file is, and I runnned the following command (replace <USERNAME> and <FUSION360INSTALLID>)
C:\Users\<USERNAME>\AppData\Local\Autodesk\webdeploy\production\<FUSION360INSTALLID>\Python\python.exe -m py_compile message.py
The __pycache__ folder was then created with the .pyc file inside. I copied the file message.cpython-37.pyc in the root folder and I renamed it as message.pyc
Here is the script that calls the pyc file:
import adsk.core, adsk.fusion, adsk.cam, traceback
from . import message
def run(context):
    app = adsk.core.Application.get()
    ui  = app.userInterface
    try:
        message.hello()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Don't forget to remove the source file when you distribute the add-in.
All the process can be automated using more Python code. But I keep it short here…
Hope it helps.
bernard5BABD
Thank you Jérôme. I'll look at this solution as soon as I have some time..... 😉
