ImportManager Runtime Error in Command Input Code
lucas.devito
lucas.devito
My code is crashing when I import components into my current design. I get a run time error when the code enters the function importarqfusion and reads line 1010.  I'm not sure what is causing this, as I was using the same code before I introduced command inputs to it. Any help is appreciated!
Run functionRun functionimportarqfusion functionimportarqfusion functionError MessageError Message
kandennti
Hi @lucas.devito .
Is it the script that is giving you the error? Is it an add-in?
Since the update of Ver 2.0.12157, there seems to be a problem when importToTarget is used in the execute event handler of a custom command.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/addin-cause-the-crash-shutdown-of-fusion-a...
However, there was no problem before Ver 2.0.12157.
