Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
fast rename dont work properly
38 REPLIES 38
Message 1 of 39
nubrandao
1528 Views, 38 Replies
# Script zum schnellen umbennen von CAM Operationen
# Bei Rückfragen bitte an M.Toepke wenden
# Marcus.Toepke@gabler-naval.com
import adsk.core, adsk.fusion, adsk.cam, traceback
import re
import sys
# Get the application and userInterface
app = adsk.core.Application.get()
ui = app.userInterface
ui_var = app.userInterface
# Get the value of the property.
propertyValue = ui.commandDefinitions
# Get the active product.
cam = adsk.cam.CAM.cast(app.activeProduct)
# Check if anything was returned.
if (cam is None😞
    ui.messageBox('Você deve estar na área de trabalho Concluído (CAM)!')
# Get the Setups collection object from the CAM object.
setups = cam.setups
# Get the first Setup object in the CAM product.
setup = setups.item(0)
# Get the Operations collection object that contains all the operations in the setup.
operations = setup.operations
# Get the first operation in the collection.
operation = operations.item(0)
# Get selected Operations
selections = ui.activeSelections
try:
    # print(f'Es sind {selections.count} Operationen ausgewählt!')
    a_selections = selections.asArray()
    if selections.count == 0:
        ui.messageBox('Nenhuma seleção de operação foi feita')
        adsk.terminate()
    if selections.count >= 1:
        # Abfrage Operations Bezeichnungen
        vorgabe = a_selections[0].entity.name
        user_input = ui_var.inputBox("Nome básico da operação", "Qual deve ser o nome básico das operações?", vorgabe)
        if user_input[1]:
            ui.messageBox('Eingabe wurde abgebrochen')
            adsk.terminate()
        if '~' not in user_input[0]:
            number = 1
            for sel_op in a_selections:
                sel_op.entity.name = f'{user_input[0]}_{number}'
                number += 1
        if '~(' in user_input[0]:
            # Input Auseinandernehmen und in Liste umformen
            input_list = re.search(r'~(.*)$', user_input[0])
            input_list = input_list[0]
            input_list = input_list.replace('~', '').replace('(', '').replace(')', '')
            input_list = input_list.split(',')
            # Zusatzargumente aus user_input entfernen
            extract = re.search(f"(.*?){re.escape('~')}", user_input[0])
            user_input = extract[0]
            user_input = user_input.replace('~', '')
            if len(a_selections) == len(input_list):
                count = 0
                    sel_op.entity.name = f'{user_input}_{input_list[count]}'
                    count += 0
            else:
                ui.messageBox('A lista que você forneceu não corresponde ao número de operações selecionadas! O script terminará agora')
        if '~' in user_input[0]:
            input_list = re.search(r'~.*$', user_input[0])
            count = 0
            new_number = float(input_list[0])
            add_number = float(input_list[1])
                if count == 0:
                    sel_op.entity.name = f'{user_input}_{new_number}'
                if count > 0:
                    new_number += add_number
                count += 1
except Exception as err:
    if selections.count < 1:
        # error_message = f'Es wurde keine Auswahl getroffen!\nEs wurden {selections.count} operationen ausgewählt'
        ui.messageBox(err)
    if ui:
      ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
   i have copied this script, but there is a problem,
rename everthing but when renumbering, it jumps numbers
por example, i input  "MOULD"
it appears
mould_01
mould_06
mould_02
mould_04
mould_07
mould_03
mould_05
38 REPLIES 38
Message 21 of 39
kandennti
in reply to: nubrandao
@nubrandao -San.
I made this for now.
Post processing is performed for each selected NCProgram operation.
In actuality, an NCProgram is created for each operation, and post processing is performed by copying the settings, so be sure to set up the NCProgram.
The output file is created in the "Output folder" of the NCProgram.
The file name is in the following format
(NCProgram's "File Name")_(operation name).(extension set in cps)
The "Name/number" will be the same for all. Please let me know if there seems to be a problem.
We have not done much checking or testing, so there is a high possibility of errors, etc.
Please contact us if you find anything.
Message 22 of 39
Tomas_V_cz
in reply to: kandennti
Hello thank you.
I think there's really a lot of potential here for a great script.
I tried your new script, but the new text is overwritten for me only in the first operation (and I think it's the same in your image).
And there could be an option in the settings to remove the old text.
I don't know why, but in the preview some tools write a lot of zeros after the decimal point and then a number (Dia 12.400000000000002)dia1.pngdia2.png
Message 23 of 39
nubrandao
I apretiate the effort 😉
Message 24 of 39
kandennti
in reply to: Tomas_V_cz
@Tomas_V_cz -San.
It was a lack of confirmation. Fixed so that selected operations can be renamed.
In addition, to prevent the numerical values from becoming too detailed, they are now limited to three decimal places.
I forgot to tell you that the units for the numbers are the units used here.
Message 25 of 39
nubrandao
that is perfect. thanks a lot
Message 26 of 39
Tomas_V_cz
Thanks, the fix works perfectly...
the zeros after the decimal point are removed and the script is applied to all operations.
Would it be possible to remove the original text? I mean the text that Fusion will generate.
I would have more ideas but I don't want to delay you, but this would be really important and beneficial.
Message 27 of 39
kandennti
@Tomas_V_cz -San.
Is this what you mean by deleting the original text?
Is it correct that this is how it works for remove?
Message 28 of 39
Tomas_V_cz
I think it could be... Maybe remove could delete the whole text. The most important thing for me is Add...
I have one more idea. Could the output text change depending on the selected cycle or tool? Or at least the most important ones? drilling, reaming, boring, tapping, bore-milling, circular-pocket-milling?
Great work from you, thank you very much
Message 29 of 39
kandennti
@Tomas_V_cz -San.
This is how we changed the behavior.
Please check it.
Message 30 of 39
Tomas_V_cz
I think it works perfectly, but would it be possible to edit the output (type of cycle)?
Some ini file or directly in the script? I don't know how complicated it is.
Deep drilling = drill a hole Dia
etc...
Awesome work from you
Message 31 of 39
kandennti
@Tomas_V_cz -San.
The API allows you to get the "Cycle Type" selection as a character. Until now, we have used that character.
Changed this character so that it can be set by itself.
"CycleType.json" is available in the script folder.
Please search for JSON format.
The contents of "CycleType.json" in the attached folder is shown in the left image, and the script is executed with the characters you set.
If you try to run the script without ["drilling": "drill a hole"], the result will be the same as before, as shown in the right image.
Message 32 of 39
Tomas_V_cz
Thank you,
I think you have chosen a great and simple solution that works.
I made a small test for several cycles (some of them we wrote in CycleType.json)
"drilling":"vrtat otvor ",
"deep-drilling":"vrtat otvor ",
"tapping":"zavit M",
"bore-milling":"hrubovat otvor ",
"circular-pocket-milling":"otvor na hotovo",
"boring" : "protocit otvor ",
"reaming" : "vystruzit otvor "
And in:
return f"{cycleType}{diaStr}" I deleted the Dia text
for better output in my language
I think the script could be further improved
(for example output "zavit M10" would be better than "zavit M10.0"),
Or for some cycles to generate values other than the tool diameter (for example, to generate the diameter of the hole for bore-milling and circular-pocket-milling), but it would probably be very complicated.
I would have a lot of ideas, unfortunately I don't have knowledge of Python programming
Awesome work, thank you very much
Edit:
i managed to get the diameter of the hole but i don't know if it is spelled correctly... But it works.
def get_diameter_with_operation(
ope: cam.Operation) -> float:
global _app
camObj: cam.CAM = _app.activeProduct
unitsMgr: core.UnitsManager = camObj.unitsManager
ratio = unitsMgr.convert(
1,
unitsMgr.internalUnits,
unitsMgr.defaultLengthUnits,
if not hasattr(ope, "tool"):
return math.nan
tool: cam.Tool = ope.tool
# Získat parametr průměru nástroje
try:
param = tool.parameters.itemByName("tool_diameter")
except:
return math.nan
# Zkontrolovat typ cyklu
cycleType = ope.parameters.itemByName("cycleType").value.value
if cycleType in ["bore-milling", "circular-pocket-milling"]:
# Získat parametr průměru otvoru
try:
param = ope.parameters.itemByName("diameter")
except:
return math.nan
return round(param.value.value * ratio, 3)
edit:
I couldn't figure out how to get the condition:
if the "counter sink" tool is selected, send the output text:
"collapse hole edge" + value hole diameter
Message 33 of 39
kandennti
@Tomas_V_cz -San.
The output is now "M" if the tool used is a tap, and "Dia" otherwise.
Note that "M" is always used in the case of taps, and is incorrect when inch taps are used.
Message 34 of 39
Tomas_V_cz
Thank you...
unfortunately, the syntax was broken when I wanted to insert my modification into the new code, which for the bore-milling and circular-pocket-milling cycles lists the diameter of the hole instead of the diameter of the tool. Could you implement my part of the code into yours? Or rather, to write the code correctly, as it should be.
95 percent of the time we use Metric threads...we mostly mill G threads (G1/2, G3/4, G1 1/2, etc...). But I don't know how scipt would know if it is G or Metric thread. Possibly by thread pitch (1.337; 1.814; 2.309 for G threads; other Metric threads)
thank you very much
Message 35 of 39
kandennti
I still can't understand it by text alone. That is the main reason why it is taking so long.
Message 36 of 39
Tomas_V_cz
I wanted the "bore-milling" and "circular-pocket-milling" operations to output the value of the hole diameter - as
shown in the picture
It is the "diameter" parameter
Message 37 of 39
kandennti
@Tomas_V_cz -San.
Don't "bore-milling" and "circular-pocket-milling" require tool diameter output?
Message 38 of 39
kandennti
Message 39 of 39
Tomas_V_cz
Thank you, great job...
Can I have any ideas for any improvements?
I don't know how to thank you...
Technology Administrators
