Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
fast rename dont work properly
38 REPLIES 38
Message 1 of 39
Bnuno608
1075 Views, 38 Replies
# Script zum schnellen umbennen von CAM Operationen
# Bei Rückfragen bitte an M.Toepke wenden
# Marcus.Toepke@gabler-naval.com
import adsk.core, adsk.fusion, adsk.cam, traceback
import re
import sys
# Get the application and userInterface
app = adsk.core.Application.get()
ui = app.userInterface
ui_var = app.userInterface
# Get the value of the property.
propertyValue = ui.commandDefinitions
# Get the active product.
cam = adsk.cam.CAM.cast(app.activeProduct)
# Check if anything was returned.
if (cam is None😞
    ui.messageBox('Você deve estar na área de trabalho Concluído (CAM)!')
# Get the Setups collection object from the CAM object.
setups = cam.setups
# Get the first Setup object in the CAM product.
setup = setups.item(0)
# Get the Operations collection object that contains all the operations in the setup.
operations = setup.operations
# Get the first operation in the collection.
operation = operations.item(0)
# Get selected Operations
selections = ui.activeSelections
try:
    # print(f'Es sind {selections.count} Operationen ausgewählt!')
    a_selections = selections.asArray()
    if selections.count == 0:
        ui.messageBox('Nenhuma seleção de operação foi feita')
        adsk.terminate()
    if selections.count >= 1:
        # Abfrage Operations Bezeichnungen
        vorgabe = a_selections[0].entity.name
        user_input = ui_var.inputBox("Nome básico da operação", "Qual deve ser o nome básico das operações?", vorgabe)
        if user_input[1]:
            ui.messageBox('Eingabe wurde abgebrochen')
            adsk.terminate()
        if '~' not in user_input[0]:
            number = 1
            for sel_op in a_selections:
                sel_op.entity.name = f'{user_input[0]}_{number}'
                number += 1
        if '~(' in user_input[0]:
            # Input Auseinandernehmen und in Liste umformen
            input_list = re.search(r'~(.*)$', user_input[0])
            input_list = input_list[0]
            input_list = input_list.replace('~', '').replace('(', '').replace(')', '')
            input_list = input_list.split(',')
            # Zusatzargumente aus user_input entfernen
            extract = re.search(f"(.*?){re.escape('~')}", user_input[0])
            user_input = extract[0]
            user_input = user_input.replace('~', '')
            if len(a_selections) == len(input_list):
                count = 0
                    sel_op.entity.name = f'{user_input}_{input_list[count]}'
                    count += 0
            else:
                ui.messageBox('A lista que você forneceu não corresponde ao número de operações selecionadas! O script terminará agora')
        if '~' in user_input[0]:
            input_list = re.search(r'~.*$', user_input[0])
            count = 0
            new_number = float(input_list[0])
            add_number = float(input_list[1])
                if count == 0:
                    sel_op.entity.name = f'{user_input}_{new_number}'
                if count > 0:
                    new_number += add_number
                count += 1
except Exception as err:
    if selections.count < 1:
        # error_message = f'Es wurde keine Auswahl getroffen!\nEs wurden {selections.count} operationen ausgewählt'
        ui.messageBox(err)
    if ui:
      ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
   i have copied this script, but there is a problem,
rename everthing but when renumbering, it jumps numbers
por example, i input  "MOULD"
it appears
mould_01
mould_06
mould_02
mould_04
mould_07
mould_03
mould_05
38 REPLIES 38
Message 2 of 39
kandennti
in reply to: Bnuno608
Hi @Bnuno608 -San.
I think they are simply processed in the order in which they are selected.
I have fixed it this way.
                number = 1
                # for sel_op in a_selections:
                #     sel_op.entity.name = f'{user_input[0]}_{number}'
                #     number += 1
                opeLst = [s.entity for s in a_selections]
                if isinstance(opeLst[0], adsk.cam.Operation):
                    setup = opeLst[0].parent
                    for ope in setup.operations:
                        if ope in opeLst:
                            ope.name = f'{user_input[0]}_{number}'
                            number += 1
The image on the right is the result of executing the script after selecting in the order of the numbers on the left of the image.
Message 3 of 39
Tomas_V_cz
in reply to: kandennti
so the script stopped working after I inserted the new code... I think I put it in a good place (we localized the comments and the output)
# Skript pro rychlé přejmenování CAM operací
# V případě dotazů se obraťte na M.Toepke
import re
import sys
# Získání aplikace a uživatelského rozhraní
# Získání hodnoty vlastnosti.
# Získání aktivního produktu.
# Kontrola, zda bylo něco vráceno.
if (cam is None):
    ui.messageBox('Musíte být v pracovním prostoru CAM (Fertigen)!')
# Získání kolekce nastavení z objektu CAM.
setups = cam.setups
# Získání prvního objektu nastavení v produktu CAM.
# Získání kolekce operací, která obsahuje všechny operace v nastavení.
# Získání první operace v kolekci.
# Získání vybraných operací
try:
    # print(f'Bylo vybráno {selections.count} operací!')
        ui.messageBox('Nebyl proveden žádný výběr operací')
        adsk.terminate()
        # Dotaz na názvy operací
        user_input = ui_var.inputBox("Základní název operace", "Jak má základní název operací znít?", vorgabe)
        if user_input[1]:
            ui.messageBox('Vstup byl zrušen')
            adsk.terminate()
                number = 1
                #     number += 1
                        if ope in opeLst:
                            number += 1
            # Rozdělení vstupu a převedení do seznamu
            # Odstranění doplňkových argumentů z uživatelského vstupu
                count = 0
                    count += 1
            else:
                ui.messageBox('Seznam, který jste poskytl, neodpovídá počtu vybraných operací! Skript bude nyní ukončen')
            count = 0
                if count == 0:
                if count > 0:
                count += 1
        # error_message = f'Nebyl proveden žádný výběr!\nBylo vybráno {selections.count}
        ui.messageBox(err)
    if ui:
Message 4 of 39
kandennti
in reply to: Tomas_V_cz
@Tomas_V_cz -San.
Here is what I tried.
import re
import sys
ui = None
def run(context):
    if (cam is None):
    setups = cam.setups
    try:
            adsk.terminate()
            if user_input[1]:
                adsk.terminate()
                number = 1
                #     number += 1
                        if ope in opeLst:
                            number += 1
                    count = 0
                        count += 0
                else:
                count = 0
                    if count == 0:
                    if count > 0:
                    count += 1
            ui.messageBox(err)
        if ui:
The data I used is also attached.
Message 5 of 39
Tomas_V_cz
thanks, now it works perfectly...
would it be possible to capture for example the diameter of the tool in the operation comment?
For example, I would select drilling operations and the script would complete the text- drill hole - tool diameter
Message 6 of 39
Bnuno608
Awesome. Is perfect
Based in this script, is hard to create a NC program for each toolpath
selected?
Message 7 of 39
Bnuno608
@kandennti hey mister
Thanks a lot for the help
Can you help with One more thing? Its very important and useful in my company.
I want to select all toolpaths, and create a single NC program for each toolpath selected
Message 8 of 39
kandennti
@Bnuno608 -San.
I haven't worked on the Fusion360 API for a while, so I need some time to research and try it out.
Message 9 of 39
kandennti
@Tomas_V_cz -San.
Perhaps I can do what you want, but I do not understand it in detail.
Since my native language is not English, I often cannot understand the meaning of the text alone.
I think it would be easier to understand the meaning and arrive at the answer if you could present images or data.
(This is not only you, but many others as well.)
Message 10 of 39
Tomas_V_cz
Good day, my language is also not English, but for demonstration we switched Fusion to English environment.
I would like to automate the output to the program as much as possible, and I think that using a macro would be possible - I think mainly for drilling operations. Example:
Drill bit diameter 6 drills holes.
Operation created:
Then a script would be activated that would complete the text:
script would create text, for example
drill a hole dia. 6
or
drill a hole 6
It would automatically for the text:
"drill  a hole" + tool diameter
Message 11 of 39
Bnuno608
Thanks you very much
Message 12 of 39
Bnuno608
Thank you very much
Message 13 of 39
kandennti
@Tomas_V_cz -San.
Thanks for the clarification.
I have created a script to add the tool diameter for now.
# Fusion360API Python script
import traceback
import adsk
import adsk.core as core
import adsk.cam as cam
import re
_app: core.Application = None
_ui: core.UserInterface = None
_handlers = []
_setupSelIpt: core.SelectionCommandInput = None
CMD_INFO = {
    "id": "kantoku_rename_operations_by_diameter",
    "name": "rename operations by diameter",
    "tooltip": "rename operations by diameter"
class MyCommandCreatedHandler(core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandCreatedEventArgs):
        core.Application.get().log(args.firingEvent.name)
        try:
            global _handlers
            cmd: core.Command = core.Command.cast(args.command)
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onExecute = MyExecuteHandler()
            cmd.execute.add(onExecute)
            _handlers.append(onExecute)
            onPreSelect = MyPreSelectHandler()
            cmd.preSelect.add(onPreSelect)
            _handlers.append(onPreSelect)
            inputs: core.CommandInputs = cmd.commandInputs
            global _setupSelIpt
            _setupSelIpt = inputs.addSelectionInput(
                "_setupSelIptId",
                "Setup",
                "Please select Setup."
        except:
            _ui.messageBox("Failed:\n{}".format(traceback.format_exc()))
class MyPreSelectHandler(core.SelectionEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.SelectionEventArgs):
        ent = args.selection.entity
        if not ent.classType() == cam.Setup.classType():
            args.isSelectable = False
class MyExecuteHandler(core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandEventArgs):
        global _setupSelIpt
        rename_operations_by_diameter(_setupSelIpt.selection(0).entity)
class MyCommandDestroyHandler(core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        adsk.terminate()
def rename_operations_by_diameter(setup: cam.Setup):
    global _app
    camObj: cam.CAM = _app.activeProduct
    unitsMgr: core.UnitsManager = camObj.unitsManager
    ratio = unitsMgr.convert(
        1,
        unitsMgr.internalUnits,
        unitsMgr.defaultLengthUnits,
    key = " Dia "
        if not hasattr(ope, "tool"): continue
        tool: cam.Tool = ope.tool
        dia = tool.parameters.itemByName(
            "tool_diameter"
        ).value.value
        if key in ope.name:
            pattern = key + r".*"
            name = re.sub(pattern, "", ope.name)
        else:
            name = ope.name
        newName = f"{name}{key}{dia * ratio}"
        if not ope.name == newName:
            ope.name = newName
def run(context):
    try:
        global _app, _ui
        _app = core.Application.get()
        _ui = _app.userInterface
        cmdDef: core.CommandDefinition = _ui.commandDefinitions.itemById(
            CMD_INFO["id"]
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition(
                CMD_INFO["id"],
                CMD_INFO["name"],
                CMD_INFO["tooltip"]
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
After running the script, a dialog appears.
Select "Setup" and press OK button to append the diameter.
If you change the tool after running the script once and the diameter changes, just run the script again.
I figured out to change "drill" -> "drill a hole", but I didn't know what to change it to for the other types of operations.
Message 14 of 39
Tomas_V_cz
thank you for your script.
It would be possible to add an option:
include only for drilling operations (I think it's unnecessary for other operations)
or:
include only for selected operations (the operations on which the script would be activated would have to be selected with the mouse)?
Alternatively, both options for faster selection (only those operations for which the script would be activated would be selected from the drilling operations).
and it would also be good if the text would be added after the existing one, or would replace it completely (the original text would be deleted)
Thank you very much
Message 15 of 39
kandennti
@Tomas_V_cz -San.
I'm sorry, but I didn't understand what you meant.
Message 16 of 39
ArjanDijk
@Tomas_V_cz Have you tried without a script, just select all operations slowly click the top one, rename to "mould" and it will number all below?
Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
Message 17 of 39
Tomas_V_cz
Good day.
In this latest version, the script is applied to all operations - but I think that, for example, I want the diameter of the tool (drill) only for drilling operations (and only for some, where the diameter of the tool = the diameter of the hole).
  In the previous version, the operations were marked and the script was applied to them. This is not possible in this version. In this new version, the script is applied to all operations (which I think is not desirable). For example, I do not want the tool diameter to be displayed for milling operations, and this is not possible in this new version.
Furthermore, in this new version the original text remains and a new text is added after the old test (example Dia 50), in the old version the old (original) text was completely replaced by the new text, which I think is desirable.
Thank you
Message 18 of 39
Bnuno608
Hi, did you tried to create NC program for each toolpath selected? Thanks on advance
Message 19 of 39
kandennti
@Tomas_V_cz -San.
I understand what you mean.
I am attaching the file as it is long.
・I have stopped selecting "Setup" and only "Drill" operations can be selected.
・I can now select the option to add/remove the tool diameter to/from the name.
・The name of the tool can be checked after the change, though it is simple.
This is a script, so please be careful when registering it.
Message 20 of 39
kandennti
@Bnuno608 -San.
I have worked on this a bit, but feel it is not easy.
At first I was going to manipulate this check button on the NCProgram to perform the process, but I could not find a function in the API to manipulate this check.
I think I will have to create a new NCProgram and either transcribe all the settings or duplicate them and do something with them, but I haven't fully researched it yet.
