Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Error Adding User Parameter Using Python
2 REPLIES 2
garyTAC3Y
318 Views, 2 Replies
garyTAC3Y
Hello All,
I was successful with pulling all of my userParameters from a design, converting them to JSON, then saving them to a file. Now that I have switched to a new design, I am trying to read that saved file, convert back from JSON to a nested dictionary, and then create userParameters using the info in that nested dictionary.
Everything works great up to the point where I try to create (ADD) a new userParameter. No matter what I use for parameters in the app.activeProduct.userParameters.add, I get...
TypeError: in method 'UserParameters_add', argument 3 of type 'adsk::core::Ptr< adsk::core::ValueInput > const &'
from...
        design = app.activeProduct
        userp=design.userParameters
        result = userp.add('testing',123,'in','this is a test')
This is a static example of course. I reverted to this after the elements from my dictionary were throwing the same error.
Thanks!
Hello All,
from...
Thanks!
Labels (3)
2 REPLIES 2
kandennti
in reply to: garyTAC3Y
kandennti
Hi @garyTAC3Y -San.
The second argument must be a ValueInput object.
        userp: adsk.fusion.UserParameters = design.userParameters
        result = userp.add(
            'testing',
            adsk.core.ValueInput.createByReal(123),
            'in',
            'this is a test'
Hi @garyTAC3Y -San.
        result = userp.add(
            'testing',
            'in',
            'this is a test'
garyTAC3Y
in reply to: kandennti
garyTAC3Y
Thank you for the info! I see that I somehow missed the object type required and now I have read up on it. I sincerely appreciate the help!
