Cannot launch VSCode by "Scripts and Add-ins" -> "Edit"
hajime2MRG3
hajime2MRG3
The "Edit" button should launch VSCode. But now, it doesn't. I found it with my Windows 11, and verified with Windows 11 Enterprise Evaluation (here) on VirtualBox 7.0.12. VSCode has been changed something?
Replies (9)
KarlRBS
The same happened to me today. I believe it was a change in the just released v2024.4.0 of the VSCode python extension. Unfortunately, downgrading the extension to the previously working v2024.2.1 did not solve the problem for me. Luckily it was a fairly simple fix for me so we don't have to wait for Fusion to be updated.
All we have to do is edit the pre-run.py file to change "pythonFiles" to "python_files". This script can be found in Fusion by opening Preferences > API and navigating to the "Default Path for Scripts and Add-Ins." From here, we just need to navigate to the ./Python/vscode directory where the script is stored. On a Mac, the full path may look like "/Users/<username_goes_here>/Library/Application Support/Autodesk/Autodesk Fusion 360/API/Python/vscode/pre-run.py". Edit this file and find "pythonFiles" when setting msPythonPath and change it to "python_files". Restart Fusion and you should be good to go with v2024.4.0 of the ms-python.python extension. Here's the full difference:
+++ pre-run.py	2024-04-04
@@ -38,7 +38,7 @@
         msPythonPath = os.path.expandvars(msPythons[0][0].path)
         index = msPythonPath.rfind('.')
         version  = int(msPythonPath[index+1:])
-        msPythonPath = os.path.join(msPythonPath, 'pythonFiles', 'lib','python')
+        msPythonPath = os.path.join(msPythonPath, 'python_files', 'lib','python')
         msPythonPath = os.path.normpath(msPythonPath)
         if os.path.exists(msPythonPath) and os.path.isdir(msPythonPath):
             return msPythonPath
The reason for this change is described in the vscode-python changelog where it notes Issue #22921 "Rename pythonFiles to python_files". Hope that works for you too!
hajime2MRG3
It worked like a charm! Thank you!
OceanHydroAU
me too - worked fine thismorning, now I can't get anything done!
The above solution did nothing for me (Windows 10N)
** Update - you have to close and restart Fusion for this to start working.
Also fixes "debug":
It probably should not be marked as "Fixed" ... editing system files manually is a workaround - someone else really needs to find and fix the root problem here.
JeromeBriot
The above fix did not completely resolve the issue on my PC (Windows 11). There was something wrong with the Python Debugger extension :
20240405T114111 I .15948 VSCode:Starting script run
20240405T114111 I .15948 VSCode:Python manager initializing
20240405T114111 I .15948 VSCode:Running script
20240405T114111 I .15948 VSCode:Running python script
20240405T114111 E .15948 NUBASE.PYTHON: failed to start python debugger:
Traceback (most recent call last):
  File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'debugpy'
20240405T114111 I .15948 VSCode:Launching visual studio code editor failed
I had to downgrade the "Python" extension and the "Python Debugger" extension in VS Code to version v2024.2.1 and to version v2024.2.0
en9y37
It worked to me too. Thanks a lot!!!!
JeromeBriot
On Windows, the pre-run.py file is located under :
C:\Users\<USERNAME>\AppData\Local\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Python\vscode
If you don't find the b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1 folder, search for the newest one.
GAAS.Design
Observer
Observer
edit: still broken
erik_per_rosen
Observer
Observer
Hey, I tried this but sadly it dosen't seem to work anymore. Is there some other solution?
BrianEkins
See this post for a solution.
https://forums.autodesk.com/t5/fusion-api-and-scripts/can-t-edit-or-debug-my-python-scripts/m-p/1275...
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
