I'm making an addin-with nested dropdowns and I have found that after about item 2 or 3 (this varies) in the nested drop-down, the menu items are not clickable. The first item is always clickable ("My button").
I have not found this behavior when not nesting drop-downs.
I have attached a minimal example add-in.
Reproduce:
I tried to record a screencast, both with Autodesk Screencast and ScreenToGif, but menu hovering does not in Fusion work while the screen recorder is running.
I am able to reproduce this issue and created FUS-70357 to track it. I do not see any other place in fusion where such deep hierarchy of submenus are used. We will investigate it further. Thanks for posting it.
@goyals , any news about this issue?
Thanks you.
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
Unfortunately We are not able to make any progress on this ticket so far. We will try to raise its priority. Thanks.
Hey, This has been an issue ive run into many times, but it seems I may have discovered a new bug this causes. If you add a checkbox control to a dropdown control, the checkbox's box disappears and does not function as expected. Any idea on when we could expect a fix for dropdowns?
