I have not yet written any API script for Fusion, but I would like to create customized 3d Print choices to the Make menu, for 2 reasons:
Solved by marshaltu. Go to Solution.
You can probably refer to "AddInSample" in "Scripts & AddIn" dialog for how to add entries to Make Menu. The id Make menu is "SolidMakePanel" in model workspace and "SurfaceMakePanel" in in patch workspace. Also you can refer to following sample for how to show a file dialog.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-d5163350-6d2f-11e7-8c44-3417ebc87622
Have a good luck.
Marshal
Please refer to the following code samples.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-ECA8A484-7EDD-427D-B1E3-BD59A646F4FA
Marshal
Thanks so much, that's exactly what I needed.
