[VS Code] Upgrade to the latest Python extension?
JeromeBriot
Mentor Mentor
JeromeBriot
@goyals wrote:
It is already done and changes were delivered as part of Fusion April release. You can upgrade to latest extension from VSCode itself. Thanks.
I tried yesterday the upgrade suggested by @goyals in this message but it did'nt work on my machine (Windows 10 & ms-python 2020.4.76186).
After the upgrade, I restarded VS Code and the message below appeared:
I restarted Fusion 360 and my computer but then Fusion 360 refused to open VS Code. No error message.
I found that there was a remaining dll in the ms-python folder:
Finally I downgraded ms-python back to version 2019.9.34911 😞
goyals
Is it possible for you to give one more try by deleting all the ms-python extensions present at this place .vscode\extensions in your user's directory manually and restart Fusion and edit a script. It will install latest extension by itself. If you still notice problem, We will investigate it further. Thanks.
Shyam Goyal
Sr. Software Dev. Manager
JeromeBriot
It works perfectly by first manually deleting the ms-python.python-2019.9.34911 folder in "C:\Users\<USERNAME>\.vscode\extensions"
Glad to see this extension up to date. 👍
Thank you.
regalheros
I have experimented and learned:
1.  Downgrading the VSCode Python Extension to 2019.9.34911 will allow Fusion 360 to open a Python script in VSCode.  Good.
2.  Once in VSCode, upgrade the Python Extension to the latest, in this case 2020.8.103604.  Great.
3.  Run the script from VSCode; press F5.
4.  Script result appears in Fusion 360.  The process is working properly!
So, VSCode to Fusion 360 is ok.
Fusion 360 to VSCode is not ok.
Is there a fix for this?
Regards
RH
regalheros
Is there a solution to the "downgrade Python extension to fix VSCode not opening"?
I have:
1. Downgraded VSCode Python Extension to 2019.9.34911.  <Begrudgingly>
2. Opened a Python script for editing in Fusion 360.
3. VSCode opens.  <Great>
4. Upgrade Python Extension to 2020.8.103604 (latest today).
5. Running the script from VSCode (press f5) results in object appearing in Fusion 360.  <Fantastic>
It appears Fusion can't 'link' to VSCode.  No problem with VSCode.
As I don't only use VSCode for Fusion 360 programming I would like a fix to this.  Is there a time frame for this?
Regards
RH
JeromeBriot
It works only until the 2020.6.91350 version.
