using Dropdown menu items
MJK_Performance
MJK_Performance
very new to API and Add ins, Im trying to add drop down menu items in an add in, that depending on what is selected, would change a user parameter. I have the menu working and the "else" writing to parameters. But I cant get the IF statement to work, mostly because I have no idea what i'm doing.
 dropDownCommandInput_ = commandInputs_.addDropDownCommandInput('dropdownCommandInput', _('Material'), adsk.core.DropDownStyles.LabeledIconDropDownStyle)
                    dropDownItems_ = dropDownCommandInput_.listItems
                    dropDownItems_.add(_('ALREC00229  0.5in_1in'), True)
                    dropDownItems_.add(_('ALREC00174  1in_2.5in'), False)
                    dropDownItems_.add(_('ALREC00290  1in_3in'), False)
                    if dropDownItems_ == 'ALREC00229  0.5in_1in':
                        userParams.itemByName('stockX').expression = '.5'
                        userParams.itemByName('stockY').expression = '1'
                    else:
                     userParams.itemByName('stockX').expression = '5'
                     userParams.itemByName('stockY').expression = '5'
JeromeBriot
Try this :
if dropDownCommandInput_.selectedItem.name == 'ALREC00229  0.5in_1in':
MJK_Performance
perfect! that works!, but now is there a way to make that selection false so another one can be true?
 dropDownItems_.add(_('Select'), True)
                    dropDownItems_.add(_('ALREC00229  0.5in_1in'), False)
                    if dropDownCommandInput_.selectedItem.name == 'Select':
                        userParams.itemByName('stockZ').expression = '1'
                        userParams.itemByName('stockX').expression = '1'
                        userParams.itemByName('stockZ').expression = '.5'
MJK_Performance
what I meant to say was... That seem to work great for the first one, but doesn't seem to work for any other selection
JeromeBriot
Here is a basic example:
import adsk.core, adsk.fusion, adsk.cam, traceback
# Global variables to keep everything in scope
handlers = []
app = adsk.core.Application.get()
ui = app.userInterface
# Event handler for the commandCreated event.
class CommandCreatedEventHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            eventArgs = adsk.core.CommandCreatedEventArgs.cast(args)
            cmd = eventArgs.command
            inputs = cmd.commandInputs
            dropDownCommandInput = inputs.addDropDownCommandInput('dropdownCommandInput', 'Material', adsk.core.DropDownStyles.LabeledIconDropDownStyle)
            dropDownItems = dropDownCommandInput.listItems
            dropDownItems.add('ALREC00229  0.5in_1in', True)
            dropDownItems.add('ALREC00174  1in_2.5in', False)
            dropDownItems.add('ALREC00290  1in_3in', False)
            #Connect handler to inputChanged event
            onInputChanged = CommandInputChangedHandler()
            cmd.inputChanged.add(onInputChanged)
            handlers.append(onInputChanged)
        except:
            if ui:
                ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# Event handler for the inputChanged event.
class CommandInputChangedHandler(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
         try:
            eventArgs = adsk.core.InputChangedEventArgs.cast(args)
            changedInput = eventArgs.input
            if changedInput.id == 'dropdownCommandInput':
                ui.messageBox(changedInput.selectedItem.name)
                if changedInput.selectedItem.name == 'ALREC00229  0.5in_1in':
                    stockZ = .5
                    stockX = .5
#                    userParams.itemByName('stockZ').expression = '.5'
#                    userParams.itemByName('stockX').expression = '1'
                else:
                    stockX = 5
                    stockY = 5
#                    userParams.itemByName('stockX').expression = '5'
#                    userParams.itemByName('stockY').expression = '5'
         except:
             if ui:
def run(context):
    try:
        # Get the CommandDefinitions collection.
        cmdDefs = ui.commandDefinitions
        # Create a button command definition.
        buttonDefinition = cmdDefs.addButtonDefinition('TestDropdownId',
                                                   'Test Dropdown',
                                                   'resources')
        # Get the ADD-INS panel in the model workspace.
        addInsPanel = ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel')
        # Add the button to the bottom of the panel.
        buttonCommand = addInsPanel.controls.addCommand(buttonDefinition)
        buttonCommand.isPromoted = True
        buttonCommand.isPromotedByDefault = True
        # Connect to the command created event.
        commandCreated = CommandCreatedEventHandler()
        buttonDefinition.commandCreated.add(commandCreated)
        handlers.append(commandCreated)
    except:
        if ui:
def stop(context):
    try:
        # Clean up the UI.
        cmdDef = ui.commandDefinitions.itemById('TestDropdownId')
        if cmdDef:
            cmdDef.deleteMe()
        addinsPanel = ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel')
        cntrl = addinsPanel.controls.itemById('TestDropdownId')
        if cntrl:
            cntrl.deleteMe()
    except:
        if ui:
You should read this carefully: Creating Custom Fusion 360 Commands
MJK_Performance
AMAZING! thank you!
