Helix Generator
Helix Generator
Helix Generator
Had the Helix Generator on my Fusion 360, and since most recent update it will not work? Deleted it, tried to redownload it and will not attach??
imajar
You will probably need to contact the person who wrote the Helix Generator to help you. . .  If you can provide a code example and specific error, then someone on this forum may be able to help.
If you are interested in writing your own script, the code below would be a good starting point.  Or, you could just update the parameters and use it as is. . . (Note that the units of measure are cm and radians though)
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        design.designType = adsk.fusion.DesignTypes.DirectDesignType
        rootComp = design.rootComponent
        bRepTemp = adsk.fusion.TemporaryBRepManager.get()
        #Helix Parameters
        axisPoint = adsk.core.Point3D.create(10.0, 10.0, 10.0)
        axisVector = adsk.core.Vector3D.create(0.0, 1.0, 0.0)
        startPoint = adsk.core.Point3D.create(8.0, 2.0, 10.0)
        pitch = 1.0
        turns = 5
        taperAngle = 0.5
        #Create the helix
        helixBody = bRepTemp.createHelixWire(axisPoint,axisVector,startPoint,pitch,turns,taperAngle)
        bRepBodies=rootComp.bRepBodies
        newHelix=bRepBodies.add(helixBody)
        sketches=rootComp.sketches
        xyPlane=rootComp.xYConstructionPlane
        mySketch=sketches.add(xyPlane)
        mySketch.include(newHelix.wires[0].edges[0])
        newHelix.deleteMe()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
