UserInterface::messageBox and localized (Russian) text
Alexander.Rivilis
Mentor Mentor
Alexander.Rivilis
I've tried to create test add-in which show simple message:
Ptr<Application> app;   app = Application::get();
Ptr<UserInterface> ui; ui = app->userInterface();
ui->messageBox("Dll загружено");
But instead of russian leters I see abrakadabra:
Is it possible to show non-english letters in text with help of UserInterface::messageBox ?
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
liujac
Yes, it’s possible to show non-English letters. You need to encode the string to UTF8 which the API supports. The code below should work with C++ 11.
#include <locale>
#include <codecvt> .... std::wstring ws(L"Dll загружено"); std::wstring_convert<std::codecvt_utf8<wchar_t>> converter; std::string s = converter.to_bytes(ws); ui->messageBox(s);
Jack
Alexander.Rivilis
Dear Jack!
Thank you so much! 🙂
Expert Elite Member
Alexander.Rivilis
Dear Jack!
And how to use Russian letters not in C++, but in JavaScript and Python?
P.S.: I'd like to write article in Russian about using non-english letters in Fusion 360 API. So additional information will be very helpful.
Expert Elite Member
ekinsb
In Python and JavaScript there's nothing special you need to do because they natively use Unicode strings.
Brian Ekins
Mod the Machine blog
Alexander.Rivilis
Thanks!
Expert Elite Member
