How to delete rows in DropdownCommandInput
Message 1 of 13
Hello. It need delete rows in DropDownCommandInput if button delete is pressed. I try this code
dropDownCommandInput=adsk.core.DropDownCommandInput.cast(inputs.itemById(piecesListId))
    if dropDownCommandInput:
        for item in dropDownCommandInput.listItems:
            item.deleteMe
I try delete all rows and add new rows, but only new rows are added.How delete all rows in DropDownCommandInput?
Replies (12)
Message 2 of 13
ekinsb
You've gotten caught by a common Python programming error that I've made several times myself.
item.deleteMe
should be
item.deleteMe()
Your current code is just getting a reference to the deleteMe function while the second one is executing it.
Brian Ekins
Mod the Machine blog
Message 3 of 13
Sorry it was my mistake. I try this code, but one row still remain.
    dropdownItems=dropDownCommandInput.listItems
    count=dropDownCommandInput.listItems.count
    index=count-1
    while index>=0:
        row=dropDownCommandInput.listItems.item(index)
        print(row.deleteMe())
        index-=1
row.deleteMe() return False if index=0
how to remove last Row?
Message 4 of 13
ekinsb
I'm not exactly sure why your code isn't working.  I didn't take the time to debug it, but this simpler version is working for me.
    dropDown = eventArgs.inputs.itemById('dropDown')
for i in range(0, dropDown.listItems.count):
print(dropDown.listItems.item(0).deleteMe())
We also have it on our backlog to add a "clear" method to the ListItems class to make this much easier.
Brian Ekins
Message 5 of 13
dropDownCommandInput = inputs.itemById(piecesListId)
    for i in range(0, dropDownCommandInput.listItems.count):
        print(dropDownCommandInput.listItems.item(0).deleteMe())
print False( , and no one row is not delete.
but if add Breakpoint and write in console
dropDownCommandInput.listItems.item(1).deleteMe()
return true
Message 6 of 13
ekinsb
I don't know what the difference could be.  I just double-checked my test and it's returning True for every delete.  What type of drop-down are you testing with?  I'm using check boxes.
Brian Ekins
Message 7 of 13
commandInputs_.addDropDownCommandInput(piecesListId, 'Piece', adsk.core.DropDownStyles.TextListDropDownStyle);
Message 8 of 13
Active Row is not deleted. It need delete all old rows and set new list of rows.
Message 9 of 13
ekinsb
I've verified the problem with a text list and also see that it's not allowing the selected item in the list to be deleted.  The only workaround I can see now is:
1. Delete all of the items in the list except for the selected item.
2. Add your new items to the list and have one them selected.
3. Delete the first item in the (which will be the one left over).
Brian Ekins
Message 10 of 13
No chanses :), I am crying. When in list remains 2 rows. Both rows have status isSelected=True, and no one is not deletable
def deleteSelectedRow(inputs):
    count =  len(dropDownCommandInput.listItems)
    first=True
    for piece in currentPiecesSet.pieces:
        if first==True:
            dropDownCommandInput.listItems.add(piece.name, False, '')
            first=False
        else: dropDownCommandInput.listItems.add(piece.name, False, '')
    dropDownCommandInput.listItems.item(1).isSelected=True
    for i in range(0, count):
    print(len(dropDownCommandInput.listItems))
Message 11 of 13
code without garbage
            dropDownCommandInput.listItems.add(piece.name, True, '')
Message 12 of 13
It looks like a Bug, or I am not right?
Message 13 of 13
SeanKane88
Has this issue been fixed or a solution found? I am having exactly the same problem.
