Unable to launch application on Mac with subprocess.Popen (Python)
JeromeBriot
Mentor Mentor
Message 1 of 15
JeromeBriot
Here is a script that should launch some applications on Mac:
import subprocess
import os
fileName = '/Users/jeromebriot/Desktop/Body1.stl'
# Cura
apps = ('/Applications/Ultimaker Cura.app',
        '/Applications/Meshmixer.app',
        '/Applications/meshlab.app',
        '/Applications/PreForm.app',
        '/Applications/SlicerForFusion360.app')
exe = ('cura',
       'meshmixer',
       'meshlab',
       'PreForm',
       'SlicerForFusion360')
for i in range(0, len(apps)):
    fullPath = os.path.join(apps[i], 'Contents', 'MacOS', exe[i])
    if os.path.exists(fullPath):
       subprocess.Popen([fullPath, fileName])
#       subprocess.Popen(['open', apps[i]])
    else:
        print('{} not found.'.format(exe[i]))
The basic idea is to mimic the "Send to 3D utility" of the 3D print tool.
The code works perfectly inside a terminal but it fails when run inside Spyder (and in my add-in).
For some applications, I receive a message like "The app quit unexpectedly"
Any idea?
Replies (14)
Message 2 of 15
JeromeBriot
Catching the exception, It looks like the return code for the faulty process  is always -6
import subprocess
import os
# Cura
exe = ('cura',
       'meshmixer',
       'meshlab',
       'PreForm',
        try:
#           subprocess.Popen([fullPath, fileName])
            subprocess.run([fullPath, fileName], check=True)
#            subprocess.check_output([fullPath, fileName])
        except subprocess.CalledProcessError as e:
            print(e.returncode)
            print(e.cmd)
            print(e.output)
            print(e.stderr)
            print(e.stdout)
    else:
The code above returns:
-6
['/Applications/Ultimaker Cura.app/Contents/MacOS/cura', '/Users/jeromebriot/Desktop/Body1.stl']
None
None
None
-6
['/Applications/Meshmixer.app/Contents/MacOS/meshmixer', '/Users/jeromebriot/Desktop/Body1.stl']
None
None
None
-6
['/Applications/PreForm.app/Contents/MacOS/PreForm', '/Users/jeromebriot/Desktop/Body1.stl']
None
None
None
Message 3 of 15
MichaelT_123
Hi Mr. JeromeBriot,
Do you use the same F360's Python in both cases or the terminal test was ran by an external Python installation?
Regards
MichaelT
MichaelT
Message 4 of 15
JeromeBriot
The code only works in an external terminal. Not inside Spyder (the one distributed with Fusion 360).
Note that I use the exact same version of Python in both cases (i.e. 3.5.3).
Message 5 of 15
MichaelT_123
Hi Mr. Jerome Briot,
Consider to implement the following code snippet:
def externalPackages ( packagesPath, add 😞
if ( add 😞 #assume sys is imported
#externalPackages = "C:\\Users\\MichaelT\\AppData\\Local\\Programs\\Python\\Python35\\Lib\\site-packages"
isAdded = False
for pth in sys.path:
if (pth == packagesPath 😞
isAdded = True
break
if ( not isAdded 😞
sys.path.append( packagesPath )
return
#Environmental variable PYTHON_PACKAGES
#packagesPath = "C:\\Users\\MichaelT\\AppData\\Local\\Programs\\Python\\Python35\\Lib\\site-packages"
packagesPath = os.environ.get( 'PYTHON_PACKAGES' )
if ( packagesPath == None 😞
messageStr = 'There is no PYTHON_PACKAGES environment variable defined.\n'
messageStr += ' import subprocess\n'
messageStr += ' import importlib, inspect\n'
messageStr += ' import time, datetime\n'
adsk.core.Application.get().userInterface.messageBox( messageStr )
sys.exit(-1)
It is a messy copy&paste, but you are a smart man so it will be not a problem for you to extract the juice!
Regards
MichaelT
PS.
This is for Windows, Apple is a mystery for me, so there might be some other intricacies.
MichaelT
Message 6 of 15
JeromeBriot
Thank you@MichaelT_123. But I'm not sure to understand what you mean.
I should have said that everything works perfectly on Windows. The issue only occurs on Mac.
Message 7 of 15
JeromeBriot
I found a related discussion: subprocess.run unable to run external script
Maybe @marshaltu could give us more information?
Message 8 of 15
JeromeBriot
I installed Anaconda 4.2.0 (with Python 3.5.2) on my Mac (pyenv).
The code works when executed inside Spyder.
Note that this is Spyder 3 and not the old customized Spyder 2 distributed with Fusion 360.
Message 9 of 15
MichaelT_123
I do use Anaconda Python 3.5 as the "external helper" as well. It is nice to hear that you overcome the hurdle.
Regards
MichaelT
PS.
Working with 'black boxes' of code is always a challenge, whether it is Python, F360, Apple, etc.
In old days of punched cards one has been The Master Of Even A Single Hole :).
MichaelT
Message 10 of 15
JeromeBriot
Not exactly. I meant that the code works with Anaconda but it still doesn't work with Fusion 360.
So maybe the issue is due to the customized version of Spyder that is shipped with Fusion 360.
Message 11 of 15
MichaelT_123
... I do not know how I came out with a hardle conclusion?
I  have looked once again at posts and it seems that the error comes from OS ( mind you, MacOS is a something I avoid at all costs 🙂 bbbrrr ) .
WARNING: THIS IS ONLY RESULT OF MY EMPTY MIND SEARCHING!
The error code refers to qml:TableViewSection (place specific to MacOS where executable markers are listed/assembled)
It seems that the subprocess has a problem of finding this table/database, while external console is true OS compatible and execute a respective app. May be the explicit direction of subprocess to a proper place could bring a resolution?
Can you try something like cwd=qmlDir ?
Also, can you call an app in situ in Unix way?
Regards
MichaelT
MichaelT
Message 12 of 15
JeromeBriot
I don't know if this could be of any help for someone but here is the crash log when I try to launch Cura from my add-in:
Process:               cura [931]
Path:                  /Applications/Ultimaker Cura.app/Contents/MacOS/cura
Identifier:            cura
Version:               4.2 (4.2.1)
Code Type:             X86-64 (Native)
Parent Process:        Autodesk Fusion 360 [371]
Responsible:           cura [931]
User ID:               501
Date/Time:             2019-08-01 17:53:17.163 +0200
OS Version:            Mac OS X 10.14.5 (18F132)
Report Version:        12
Anonymous UUID:        D9CB48F7-E7B5-DA5A-D97D-7C0918AF0DF9
Sleep/Wake UUID:       EEB35CBC-11AC-45C0-B6EC-2767CEBAC564
Time Awake Since Boot: 5400 seconds
Time Since Wake:       1200 seconds
System Integrity Protection: enabled
Crashed Thread:        0
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Application Specific Information:
abort() called
Thread 0 Crashed:
0   libsystem_kernel.dylib        	0x00007fff693172c6 __pthread_kill + 10
1   libsystem_c.dylib             	0x00007fff69234d8a raise + 26
2   libsystem_platform.dylib      	0x00007fff693c7b5d _sigtramp + 29
3   ???                           	000000000000000000 0 + 0
4   libsystem_c.dylib             	0x00007fff692816a6 abort + 127
5   libQt5Core.5.dylib            	0x000000010b3c24b9 0x10b3ab000 + 95417
6   libQt5Core.5.dylib            	0x000000010b3c3d07 QMessageLogger::fatal(char const*, ...) const + 231
7   libQt5Gui.5.dylib             	0x000000010bc94a28 QGuiApplicationPrivate::createPlatformIntegration() + 5912
8   libQt5Gui.5.dylib             	0x000000010bc94a4b QGuiApplicationPrivate::createEventDispatcher() + 27
9   libQt5Core.5.dylib            	0x000000010b5ae999 QCoreApplicationPrivate::init() + 2073
10  libQt5Gui.5.dylib             	0x000000010bc905b0 QGuiApplicationPrivate::init() + 64
11  libQt5Widgets.5.dylib         	0x000000010c70768a QApplicationPrivate::init() + 26
12  PyQt5.QtWidgets.so            	0x000000010c1e719f init_type_QApplication(_sipSimpleWrapper*, _object*, _object*, _object**, _object**, _object**) + 175
13  sip.so                        	0x0000000104a671fd sipSimpleWrapper_init + 183
14  nl.ultimaker.cura             	0x0000000104225c3c 0x1041bb000 + 437308
15  nl.ultimaker.cura             	0x00000001041c6eb5 PyObject_Call + 101
16  nl.ultimaker.cura             	0x000000010428db50 PyEval_EvalFrameEx + 27536
17  nl.ultimaker.cura             	0x0000000104291ba2 0x1041bb000 + 879522
18  nl.ultimaker.cura             	0x0000000104286f9e PyEval_EvalCodeEx + 78
19  nl.ultimaker.cura             	0x00000001041f051d 0x1041bb000 + 218397
20  nl.ultimaker.cura             	0x00000001041c6eb5 PyObject_Call + 101
21  nl.ultimaker.cura             	0x000000010428db50 PyEval_EvalFrameEx + 27536
22  nl.ultimaker.cura             	0x0000000104291ba2 0x1041bb000 + 879522
23  nl.ultimaker.cura             	0x0000000104286f9e PyEval_EvalCodeEx + 78
24  nl.ultimaker.cura             	0x00000001041f051d 0x1041bb000 + 218397
25  nl.ultimaker.cura             	0x00000001041c6eb5 PyObject_Call + 101
26  nl.ultimaker.cura             	0x00000001041dcbfd 0x1041bb000 + 138237
27  nl.ultimaker.cura             	0x00000001041c6eb5 PyObject_Call + 101
28  nl.ultimaker.cura             	0x0000000104225bae 0x1041bb000 + 437166
29  nl.ultimaker.cura             	0x0000000104222169 0x1041bb000 + 422249
30  nl.ultimaker.cura             	0x00000001041c6eb5 PyObject_Call + 101
31  nl.ultimaker.cura             	0x000000010428d056 PyEval_EvalFrameEx + 24726
32  nl.ultimaker.cura             	0x0000000104291ba2 0x1041bb000 + 879522
33  nl.ultimaker.cura             	0x0000000104286f41 PyEval_EvalCode + 81
34  nl.ultimaker.cura             	0x00000001042aa166 PyImport_ExecCodeModuleObject + 390
35  nl.ultimaker.cura             	0x000000010431128d 0x1041bb000 + 1401485
36  nl.ultimaker.cura             	0x000000010420ff85 PyCFunction_Call + 165
37  nl.ultimaker.cura             	0x000000010428d3b0 PyEval_EvalFrameEx + 25584
38  nl.ultimaker.cura             	0x0000000104292392 0x1041bb000 + 881554
39  nl.ultimaker.cura             	0x000000010428ccff PyEval_EvalFrameEx + 23871
40  nl.ultimaker.cura             	0x0000000104292392 0x1041bb000 + 881554
41  nl.ultimaker.cura             	0x000000010428ccff PyEval_EvalFrameEx + 23871
42  nl.ultimaker.cura             	0x0000000104292392 0x1041bb000 + 881554
43  nl.ultimaker.cura             	0x000000010428ccff PyEval_EvalFrameEx + 23871
44  nl.ultimaker.cura             	0x0000000104291ba2 0x1041bb000 + 879522
45  nl.ultimaker.cura             	0x0000000104286f9e PyEval_EvalCodeEx + 78
46  nl.ultimaker.cura             	0x00000001041f051d 0x1041bb000 + 218397
47  nl.ultimaker.cura             	0x00000001041c6eb5 PyObject_Call + 101
48  nl.ultimaker.cura             	0x00000001041c7ae7 _PyObject_CallMethodIdObjArgs + 407
49  nl.ultimaker.cura             	0x00000001042ab14f PyImport_ImportModuleLevelObject + 2079
50  nl.ultimaker.cura             	0x0000000104283d57 0x1041bb000 + 822615
51  nl.ultimaker.cura             	0x000000010420ff1c PyCFunction_Call + 60
52  nl.ultimaker.cura             	0x000000010428d3b0 PyEval_EvalFrameEx + 25584
53  nl.ultimaker.cura             	0x0000000104291ba2 0x1041bb000 + 879522
54  nl.ultimaker.cura             	0x0000000104286f41 PyEval_EvalCode + 81
55  nl.ultimaker.cura             	0x00000001042aa166 PyImport_ExecCodeModuleObject + 390
56  nl.ultimaker.cura             	0x000000010431128d 0x1041bb000 + 1401485
57  nl.ultimaker.cura             	0x000000010420ff85 PyCFunction_Call + 165
58  nl.ultimaker.cura             	0x000000010428d3b0 PyEval_EvalFrameEx + 25584
59  nl.ultimaker.cura             	0x0000000104292392 0x1041bb000 + 881554
60  nl.ultimaker.cura             	0x000000010428ccff PyEval_EvalFrameEx + 23871
61  nl.ultimaker.cura             	0x0000000104292392 0x1041bb000 + 881554
62  nl.ultimaker.cura             	0x000000010428ccff PyEval_EvalFrameEx + 23871
63  nl.ultimaker.cura             	0x0000000104292392 0x1041bb000 + 881554
64  nl.ultimaker.cura             	0x000000010428ccff PyEval_EvalFrameEx + 23871
65  nl.ultimaker.cura             	0x0000000104291ba2 0x1041bb000 + 879522
66  nl.ultimaker.cura             	0x0000000104286f9e PyEval_EvalCodeEx + 78
67  nl.ultimaker.cura             	0x00000001041f051d 0x1041bb000 + 218397
68  nl.ultimaker.cura             	0x00000001041c6eb5 PyObject_Call + 101
69  nl.ultimaker.cura             	0x00000001041c7ae7 _PyObject_CallMethodIdObjArgs + 407
70  nl.ultimaker.cura             	0x00000001042ab14f PyImport_ImportModuleLevelObject + 2079
71  nl.ultimaker.cura             	0x0000000104283d57 0x1041bb000 + 822615
72  nl.ultimaker.cura             	0x000000010420ff1c PyCFunction_Call + 60
73  nl.ultimaker.cura             	0x000000010428d3b0 PyEval_EvalFrameEx + 25584
74  nl.ultimaker.cura             	0x0000000104291ba2 0x1041bb000 + 879522
75  nl.ultimaker.cura             	0x0000000104286f41 PyEval_EvalCode + 81
76  nl.ultimaker.cura             	0x00000001042aa166 PyImport_ExecCodeModuleObject + 390
77  nl.ultimaker.cura             	0x000000010431128d 0x1041bb000 + 1401485
78  nl.ultimaker.cura             	0x000000010420ff85 PyCFunction_Call + 165
79  nl.ultimaker.cura             	0x000000010428d3b0 PyEval_EvalFrameEx + 25584
80  nl.ultimaker.cura             	0x0000000104292392 0x1041bb000 + 881554
81  nl.ultimaker.cura             	0x000000010428ccff PyEval_EvalFrameEx + 23871
82  nl.ultimaker.cura             	0x0000000104292392 0x1041bb000 + 881554
83  nl.ultimaker.cura             	0x000000010428ccff PyEval_EvalFrameEx + 23871
84  nl.ultimaker.cura             	0x0000000104292392 0x1041bb000 + 881554
85  nl.ultimaker.cura             	0x000000010428ccff PyEval_EvalFrameEx + 23871
86  nl.ultimaker.cura             	0x0000000104291ba2 0x1041bb000 + 879522
87  nl.ultimaker.cura             	0x0000000104286f9e PyEval_EvalCodeEx + 78
88  nl.ultimaker.cura             	0x00000001041f051d 0x1041bb000 + 218397
89  nl.ultimaker.cura             	0x00000001041c6eb5 PyObject_Call + 101
90  nl.ultimaker.cura             	0x00000001041c7ae7 _PyObject_CallMethodIdObjArgs + 407
91  nl.ultimaker.cura             	0x00000001042ab14f PyImport_ImportModuleLevelObject + 2079
92  nl.ultimaker.cura             	0x0000000104283d57 0x1041bb000 + 822615
93  nl.ultimaker.cura             	0x000000010420ff1c PyCFunction_Call + 60
94  nl.ultimaker.cura             	0x00000001041c6eb5 PyObject_Call + 101
95  nl.ultimaker.cura             	0x00000001041c7036 PyObject_CallFunction + 246
96  nl.ultimaker.cura             	0x00000001042aa81d PyImport_Import + 429
97  nl.ultimaker.cura             	0x00000001041bbef5 main + 837
98  libdyld.dylib                 	0x00007fff691dc3d5 start + 1
Thread 1:
0   libsystem_kernel.dylib        	0x00007fff6931486a __psynch_cvwait + 10
1   libopenblasp-r0.3.5.dylib     	0x000000010547517b blas_thread_server + 235
2   libsystem_pthread.dylib       	0x00007fff693d02eb _pthread_body + 126
3   libsystem_pthread.dylib       	0x00007fff693d3249 _pthread_start + 66
4   libsystem_pthread.dylib       	0x00007fff693cf40d thread_start + 13
Thread 2:
0   libsystem_pthread.dylib       	0x00007fff693cf3f0 start_wqthread + 0
1   ???                           	0x00007fe7ec200000 0 + 140634075693056
Thread 3:
1   ???                           	0x0000000054485244 0 + 1414025796
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x00000001051085c0  rcx: 0x000000010447ca48  rdx: 0x0000000000000000
  rdi: 0x0000000000000307  rsi: 0x0000000000000006  rbp: 0x000000010447ca80  rsp: 0x000000010447ca48
   r8: 0x000000010447cf48   r9: 0x80013e052cc8f2e0  r10: 0x000000010510866c  r11: 0x0000000000000206
  r12: 0x0000000000000307  r13: 0x00007fe7ebe75260  r14: 0x0000000000000006  r15: 0x000000000000002d
  rip: 0x00007fff693172c6  rfl: 0x0000000000000206  cr2: 0x000000010447cf48
Logical CPU:     0
Error Code:      0x02000148
Trap Number:     133
Binary Images:
       0x1041bb000 -        0x104362ff7 +nl.ultimaker.cura (4.2 - 4.2.1) <C560C6DF-CAC0-3EB5-86FF-763A101636B3> /Applications/Ultimaker Cura.app/Contents/MacOS/cura
       0x10447d000 -        0x104480fff +zlib.cpython-35-darwin.so (0) <CEB24BF6-AA3D-3519-B872-6A6CC459CC70> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/zlib.cpython-35-darwin.so
       0x104485000 -        0x104499ff7 +libz.1.dylib (0) <785F9AF3-0FA4-343E-949E-CBEE4F54E539> /Applications/Ultimaker Cura.app/Contents/MacOS/libz.1.dylib
       0x104542000 -        0x104542fff +_heapq.cpython-35-darwin.so (0) <CF5932EB-DAF8-33F4-BCA9-1DC6028197CB> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/_heapq.cpython-35-darwin.so
       0x104546000 -        0x10454affb +_struct.cpython-35-darwin.so (0) <0B01E0E3-0594-3AB1-9C6F-61CA528FDA0A> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/_struct.cpython-35-darwin.so
       0x104574000 -        0x104578ff7 +math.cpython-35-darwin.so (0) <0B0140C0-2AAC-3531-AD7C-F7B812105556> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/math.cpython-35-darwin.so
       0x10457f000 -        0x10458aff7 +_datetime.cpython-35-darwin.so (0) <F429AABA-0F17-3D49-957D-99DE64123575> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/_datetime.cpython-35-darwin.so
       0x1045f6000 -        0x1045f6ffb +grp.cpython-35-darwin.so (0) <315E8042-9063-3C5E-9B06-2566C12BABF9> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/grp.cpython-35-darwin.so
       0x1045f9000 -        0x1045faffb +_bz2.cpython-35-darwin.so (0) <785A8E2D-5985-35D9-A657-5366860D1F13> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/_bz2.cpython-35-darwin.so
       0x1045fe000 -        0x104601fff +_lzma.cpython-35-darwin.so (0) <C36344AB-BA30-3CA2-9D69-0F15644666AB> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/_lzma.cpython-35-darwin.so
       0x104607000 -        0x104626ff3 +liblzma.5.dylib (0) <75C56960-6BD8-337F-AC86-EAC40D0FDB70> /Applications/Ultimaker Cura.app/Contents/MacOS/liblzma.5.dylib
       0x10463a000 -        0x10463cffb +_hashlib.cpython-35-darwin.so (0) <F8DAF286-0A6A-36E3-BF6A-495DD4A2399C> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/_hashlib.cpython-35-darwin.so
       0x104641000 -        0x104684fff +libssl.1.0.0.dylib (0) <5D4CA0A6-3EB9-325B-887A-26746767A7EF> /Applications/Ultimaker Cura.app/Contents/MacOS/libssl.1.0.0.dylib
       0x1046a4000 -        0x104861927 +libcrypto.1.0.0.dylib (0) <42B31BC1-6811-3461-BCD2-AEB18F0F2F64> /Applications/Ultimaker Cura.app/Contents/MacOS/libcrypto.1.0.0.dylib
       0x1048e1000 -        0x1048e2fff +_random.cpython-35-darwin.so (0) <F820303A-4121-3BC3-8EF4-C9D3A7E02563> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/_random.cpython-35-darwin.so
       0x1048e5000 -        0x1048e5ffb +_opcode.cpython-35-darwin.so (0) <4C893ED5-3F93-3D8C-B7EF-7DFA01ECC4E3> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/_opcode.cpython-35-darwin.so
       0x1048e8000 -        0x1049d2fff +Arcus.so (0) <E54CB07C-EC9F-38ED-86C5-95D1AE032BE4> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/Arcus.so
       0x104a64000 -        0x104a77fff +sip.so (0) <5155672D-D6BD-3267-9808-F4A9C757D231> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/sip.so
       0x104a82000 -        0x104ab6ff7 +Savitar.so (0) <A9668CDD-328F-3BD3-8ADD-2D2E6FFE7601> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/Savitar.so
       0x104b35000 -        0x104cabff3 +multiarray.cpython-35-darwin.so (0) <74E8E54C-A9CA-3385-A5E0-63574CBE9BE6> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/numpy/core/multiarray.cpython-35-darwin.so
       0x104d83000 -        0x104fb4fef +libgfortran.5.dylib (0) <7A3F3AFE-D02C-3A88-91CA-CEFF5B0740EB> /Applications/Ultimaker Cura.app/Contents/MacOS/libgfortran.5.dylib
       0x105041000 -        0x105056fef +libgcc_s.1.dylib (1) <2F068636-B3CC-3D99-B93D-E862197BC7AE> /Applications/Ultimaker Cura.app/Contents/MacOS/libgcc_s.1.dylib
       0x105066000 -        0x1050d06ef  dyld (655.1.1) <CE635DB2-D47E-3C05-A0A3-6BD982E7E750> /usr/lib/dyld
       0x105131000 -        0x108993667 +libopenblasp-r0.3.5.dylib (0) <45CF9676-2A85-3294-8B45-8FA7F09C9439> /Applications/Ultimaker Cura.app/Contents/MacOS/libopenblasp-r0.3.5.dylib
       0x108c6d000 -        0x108ca5fff +libquadmath.0.dylib (0) <E5A7047C-6353-38E3-8669-A2503D7D6AD9> /Applications/Ultimaker Cura.app/Contents/MacOS/libquadmath.0.dylib
       0x10acb8000 -        0x10adecffb +umath.cpython-35-darwin.so (0) <8AD069A3-CD85-3784-A5FC-BEEA65B545C1> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/numpy/core/umath.cpython-35-darwin.so
       0x10ae33000 -        0x10ae43fff +_ctypes.cpython-35-darwin.so (0) <E20340D8-CDFE-3083-B3C0-940C5DC75574> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/_ctypes.cpython-35-darwin.so
       0x10ae55000 -        0x10ae66ff7 +_pickle.cpython-35-darwin.so (0) <80600807-9F66-3A90-AC4F-7F87E1760DA1> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/_pickle.cpython-35-darwin.so
       0x10af33000 -        0x10af34ff3 +lapack_lite.cpython-35-darwin.so (0) <79B35469-34FE-3FF0-B50E-A458314A1586> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/numpy/linalg/lapack_lite.cpython-35-darwin.so
       0x10af38000 -        0x10af50fff +_umath_linalg.cpython-35-darwin.so (0) <FCF7DCFA-9F5A-329A-9828-9834935699F9> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/numpy/linalg/_umath_linalg.cpython-35-darwin.so
       0x10af5e000 -        0x10afa4fff +_decimal.cpython-35-darwin.so (0) <8A524D3F-9043-31D3-8B57-05B427D2BD5B> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/_decimal.cpython-35-darwin.so
       0x10afc2000 -        0x10afcfffb +_multiarray_tests.cpython-35-darwin.so (0) <147D3484-448E-3FA9-80AA-FE2D675234A9> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/numpy/core/_multiarray_tests.cpython-35-darwin.so
       0x10afde000 -        0x10afe7ffb +fftpack_lite.cpython-35-darwin.so (0) <80FA6343-4C18-3D6F-AF30-C3E8997121CC> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/numpy/fft/fftpack_lite.cpython-35-darwin.so
       0x10afeb000 -        0x10b085fff +mtrand.cpython-35-darwin.so (0) <83B23EA0-11BB-3EA9-A557-30B44B65F493> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/numpy/random/mtrand.cpython-35-darwin.so
       0x10b0ff000 -        0x10b246ff7 +PyQt5.QtCore.so (0) <EA00DF16-EA5B-3604-A62D-E0ACE724D2AD> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/PyQt5.QtCore.so
       0x10b3ab000 -        0x10b8aaff7 +libQt5Core.5.dylib (0) <BA0A785A-3CB7-39CD-B67C-2B040EC1223C> /Applications/Ultimaker Cura.app/Contents/MacOS/libQt5Core.5.dylib
       0x10b972000 -        0x10bad9ff3 +PyQt5.QtGui.so (0) <CEC441EB-7891-365F-910B-F01EAB279FFF> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/PyQt5.QtGui.so
       0x10bc66000 -        0x10c0b3fe3 +libQt5Gui.5.dylib (0) <2FEC6D7F-90F2-3297-8E06-3F66002DE3CA> /Applications/Ultimaker Cura.app/Contents/MacOS/libQt5Gui.5.dylib
       0x10c1c0000 -        0x10c41fff3 +PyQt5.QtWidgets.so (0) <230ABE45-F8B7-330E-99CC-0B5C9F1F1378> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/PyQt5.QtWidgets.so
       0x10c6fd000 -        0x10cb4fff7 +libQt5Widgets.5.dylib (0) <17DBD4E5-4D2D-34A3-8390-A50433E952B5> /Applications/Ultimaker Cura.app/Contents/MacOS/libQt5Widgets.5.dylib
       0x10ccc4000 -        0x10cd0bff3 +PyQt5.QtQml.so (0) <41E2419C-000C-378F-AB98-BE414A64A5C1> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/PyQt5.QtQml.so
       0x10cd8e000 -        0x10d0afff7 +libQt5Qml.5.dylib (0) <D4C6B6F8-1236-30E5-BC26-1B4306442BC5> /Applications/Ultimaker Cura.app/Contents/MacOS/libQt5Qml.5.dylib
       0x10d168000 -        0x10d275ff7 +libQt5Network.5.dylib (0) <E87812D8-D5D1-361D-874F-ED5037D79229> /Applications/Ultimaker Cura.app/Contents/MacOS/libQt5Network.5.dylib
       0x10d2c2000 -        0x10d31eff3 +PyQt5.QtNetwork.so (0) <54E5FF08-47C9-34F4-B617-5F491FCD8D21> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/PyQt5.QtNetwork.so
       0x10d38f000 -        0x10d394ff3 +_json.cpython-35-darwin.so (0) <D0EAC13E-9A3A-37BB-A9A6-081B61B2111C> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/_json.cpython-35-darwin.so
       0x10d399000 -        0x10d39cff3 +binascii.cpython-35-darwin.so (0) <5D6B4D03-B02F-31DD-AF4B-D53EE28CC489> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/binascii.cpython-35-darwin.so
       0x10d3a0000 -        0x10d3aafff +_ccallback_c.cpython-35-darwin.so (0) <69B39979-75CE-38E5-8AC7-F556422A972F> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/_lib/_ccallback_c.cpython-35-darwin.so
       0x10d3c7000 -        0x10d743ff7 +_sparsetools.cpython-35-darwin.so (0) <150D7722-84C7-3F15-9089-50705FEC0A97> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/sparse/_sparsetools.cpython-35-darwin.so
       0x10d823000 -        0x10d823fff +_bisect.cpython-35-darwin.so (0) <8501752E-0327-3A13-A22F-73C7247CC3AC> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/_bisect.cpython-35-darwin.so
       0x10d826000 -        0x10d88afff +_csparsetools.cpython-35-darwin.so (0) <EBBE6D4F-9AA4-3B3E-AF2B-D2E23EB12B8F> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/sparse/_csparsetools.cpython-35-darwin.so
       0x10d8a8000 -        0x10d8daff3 +_shortest_path.cpython-35-darwin.so (0) <6AD9D2A0-C763-3B47-AF85-0D53A64C1F9B> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/sparse/csgraph/_shortest_path.cpython-35-darwin.so
       0x10d8ed000 -        0x10d908fff +_tools.cpython-35-darwin.so (0) <37FB8E45-2B7A-33F8-B92C-6B54985A5D7E> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/sparse/csgraph/_tools.cpython-35-darwin.so
       0x10d918000 -        0x10d933fff +_traversal.cpython-35-darwin.so (0) <DE5EE673-DFD6-378D-98CE-C1024C400B83> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/sparse/csgraph/_traversal.cpython-35-darwin.so
       0x10d941000 -        0x10d960ffb +_min_spanning_tree.cpython-35-darwin.so (0) <2B36515C-D56F-3FC4-853D-EADB8C71A120> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/sparse/csgraph/_min_spanning_tree.cpython-35-darwin.so
       0x10d973000 -        0x10d9acff7 +_reordering.cpython-35-darwin.so (0) <06880C0D-AD11-329A-A3C5-4BA042BB7FD8> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/sparse/csgraph/_reordering.cpython-35-darwin.so
       0x10d9c7000 -        0x10da40fff +ckdtree.cpython-35-darwin.so (0) <0E02EBD0-948C-321C-A71C-03B9B179E080> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/spatial/ckdtree.cpython-35-darwin.so
       0x10da67000 -        0x10db2bff3 +qhull.cpython-35-darwin.so (0) <66118352-4F86-3B05-9B28-BF200EA79F54> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/spatial/qhull.cpython-35-darwin.so
       0x10db65000 -        0x10db6affb +messagestream.cpython-35-darwin.so (0) <DDA59D03-B551-39DA-85C7-85BE97B7FC45> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/_lib/messagestream.cpython-35-darwin.so
       0x10db71000 -        0x10db8fffb +_voronoi.cpython-35-darwin.so (0) <3BBEEF9E-FA29-3126-ACF6-AB1ECE4D0785> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/spatial/_voronoi.cpython-35-darwin.so
       0x10dba1000 -        0x10dbaffff +_distance_wrap.cpython-35-darwin.so (0) <B268ADDE-69E4-37A2-A504-FBFAFA5E48F5> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/spatial/_distance_wrap.cpython-35-darwin.so
       0x10dbb9000 -        0x10dbd7ffb +_hausdorff.cpython-35-darwin.so (0) <F2FFE0F3-5F24-3A18-9713-B7CE2CB6EA67> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/spatial/_hausdorff.cpython-35-darwin.so
       0x20dbe9000 -        0x20dc3dff7 +_fblas.cpython-35-darwin.so (0) <CBB518C5-49C3-3BA4-8486-DEE463E938BA> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/linalg/_fblas.cpython-35-darwin.so
       0x30dc75000 -        0x30dd44ff7 +_flapack.cpython-35-darwin.so (0) <2EDE31CE-C8B1-3152-980A-B0F3045F3EA4> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/linalg/_flapack.cpython-35-darwin.so
       0x40ddde000 -        0x40dde8ff7 +_flinalg.cpython-35-darwin.so (0) <CFAF2D49-23FE-301E-BF74-60510859947A> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/linalg/_flinalg.cpython-35-darwin.so
       0x40ddf0000 -        0x40de17fff +_solve_toeplitz.cpython-35-darwin.so (0) <55AA66EC-96F0-3244-BB4F-15B74D5B6A73> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/linalg/_solve_toeplitz.cpython-35-darwin.so
       0x40de2d000 -        0x40de67fff +_decomp_update.cpython-35-darwin.so (0) <B948AB8A-A389-3F0F-8DAF-16D4CBF67BAF> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/linalg/_decomp_update.cpython-35-darwin.so
       0x50de7c000 -        0x50dea5fff +cython_blas.cpython-35-darwin.so (0) <C930B93A-BEF4-353D-9CA7-90E0B0C2A6BA> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/linalg/cython_blas.cpython-35-darwin.so
       0x60dec2000 -        0x60df3aff7 +cython_lapack.cpython-35-darwin.so (0) <AE92A699-A3A2-38EF-90B6-FDDB5A17B204> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/linalg/cython_lapack.cpython-35-darwin.so
       0x70df97000 -        0x70e10bfef +_ufuncs.cpython-35-darwin.so (0) <5ACEBC77-D1E3-3F7B-8CB1-FAD956FE8789> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/special/_ufuncs.cpython-35-darwin.so
       0x70e181000 -        0x70e196fff +_ufuncs_cxx.cpython-35-darwin.so (0) <E710EA56-A165-3E92-9718-37706230CBB5> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/special/_ufuncs_cxx.cpython-35-darwin.so
       0x80e1a5000 -        0x80e260fef +specfun.cpython-35-darwin.so (0) <732E97A9-639A-3873-831C-C7B31CF26462> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/special/specfun.cpython-35-darwin.so
       0x80e283000 -        0x80e287ff3 +_comb.cpython-35-darwin.so (0) <159A1EA7-ECD6-3432-A9DF-D4C09D58E391> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/special/_comb.cpython-35-darwin.so
       0x80e28c000 -        0x80e299ff3 +_ellip_harm_2.cpython-35-darwin.so (0) <8DB443EE-E904-3446-91C0-F06BD7F79626> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/scipy/special/_ellip_harm_2.cpython-35-darwin.so
       0x80e2a3000 -        0x80e2a4fff +_posixsubprocess.cpython-35-darwin.so (0) <28B0BDE3-47AE-3A0E-8E7B-F2C9174CBF06> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/_posixsubprocess.cpython-35-darwin.so
       0x80e2a8000 -        0x80e2aaff7 +select.cpython-35-darwin.so (0) <E37C9467-B2EF-377E-ADCB-8D910EE8A6F5> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/select.cpython-35-darwin.so
       0x80e2b0000 -        0x80e2b1ff7 +fcntl.cpython-35-darwin.so (0) <45FE8107-00B8-374E-9DD9-592089C4577B> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/fcntl.cpython-35-darwin.so
       0x80e2b5000 -        0x80e31cff3 +PyQt5.QtQuick.so (0) <090F056B-BB0D-3DB2-B8E0-6E03D0C82738> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/PyQt5.QtQuick.so
       0x80e3d5000 -        0x80e6a5ff7 +libQt5Quick.5.dylib (0) <22FFC65C-876E-388D-8E00-E8C4C46AA471> /Applications/Ultimaker Cura.app/Contents/MacOS/libQt5Quick.5.dylib
       0x80e934000 -        0x80e93cfff +_socket.cpython-35-darwin.so (0) <F3375495-0FFE-304D-968F-2C5BB31DF070> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/_socket.cpython-35-darwin.so
       0x80e948000 -        0x80e953ffb +_ssl.cpython-35-darwin.so (0) <D0A45E03-530D-3D8D-804F-4DA7FF6139A1> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/_ssl.cpython-35-darwin.so
       0x80e962000 -        0x80ea2fffb +unicodedata.cpython-35-darwin.so (0) <D013E767-D570-37E3-9EF0-6FDD5118E52A> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/unicodedata.cpython-35-darwin.so
       0x80ea9d000 -        0x80ea9dff3 +_scproxy.cpython-35-darwin.so (0) <A23F4947-8696-371F-B7E8-CF571F53F18D> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/_scproxy.cpython-35-darwin.so
       0x80ead3000 -        0x80ead8fff +array.cpython-35-darwin.so (0) <D91AEFFA-A590-3877-B918-2689A6558444> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/array.cpython-35-darwin.so
       0x80eae2000 -        0x80eb00ff7 +libgeos_c.1.dylib (0) <65FEF1C8-7381-3F8B-B89F-6076808826D0> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/shapely/.dylibs/libgeos_c.1.dylib
       0x80eb13000 -        0x80ebd3ff3 +libgeos.3.7.0.dylib (0) <DBC48F04-C2DC-3BC2-8ADA-2FA3DA374705> /Applications/Ultimaker Cura.app/Contents/MacOS/libgeos.3.7.0.dylib
       0x80ec76000 -        0x80ec92ff3 +_speedups.cpython-35-darwin.so (0) <9081CA1B-48C9-3A6B-B704-3E46B4D58F8A> /Applications/Ultimaker Cura.app/Contents/MacOS/lib/python3.5/shapely/speedups/_speedups.cpython-35-darwin.so
       0x80eca1000 -        0x80ecbfff7 +libgeos_c.1.dylib (0) <65FEF1C8-7381-3F8B-B89F-6076808826D0> /Applications/Ultimaker Cura.app/Contents/MacOS/libgeos_c.1.dylib
    0x7fff390ad000 -     0x7fff390b1fff  com.apple.agl (3.3.2 - AGL-3.3.2) <D1753A7C-4109-3778-BA57-9ED1BCED8EBC> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x7fff3945c000 -     0x7fff3945cfff  com.apple.Accelerate (1.11 - Accelerate 1.11) <B2A0C739-1D41-3452-9D00-8C01ADA5DD99> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff39474000 -     0x7fff39d68fcb  com.apple.vImage (8.1 - ???) <B51A0BC2-012E-3D03-992F-091F2E076EB4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff39d69000 -     0x7fff39f0ffeb  libBLAS.dylib (1243.200.4) <02059CCF-0B14-3BFA-9B74-B5685219682E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff39f10000 -     0x7fff39f54ff7  libBNNS.dylib (38.250.1) <AB890F6F-0B7D-3EC5-8A0E-874EAA4D0731> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fff39f55000 -     0x7fff3a30dff3  libLAPACK.dylib (1243.200.4) <2CD8E9C6-E489-38E1-8A08-42CBE87FAC77> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff3a30e000 -     0x7fff3a323ffb  libLinearAlgebra.dylib (1243.200.4) <E7507B69-EF24-39D6-9B35-4A66E833C3F8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff3a324000 -     0x7fff3a329ff3  libQuadrature.dylib (3.200.2) <1BAE7E22-2862-379F-B334-A3756067730F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fff3a32a000 -     0x7fff3a3a6ff3  libSparse.dylib (79.200.5) <E78B33D3-672A-3C53-B512-D3DDB2E9AC8D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
    0x7fff3a3a7000 -     0x7fff3a3b9ffb  libSparseBLAS.dylib (1243.200.4) <069BE0D3-FEDF-3848-81B7-B5D64F511EC6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff3a3ba000 -     0x7fff3a55afef  libvDSP.dylib (671.250.4) <CA46FD92-D0CB-39B5-BD26-BEB3897D3154> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff3a55b000 -     0x7fff3a6cffdf  libvMisc.dylib (671.250.4) <32F2043A-9CBB-36F0-91C0-088D50C31BF1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff3a6d0000 -     0x7fff3a6d0fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <A83C1419-E651-3924-8A6D-FF7321C8AB90> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff3a872000 -     0x7fff3b627ff3  com.apple.AppKit (6.9 - 1671.50.111) <933155DC-6404-3646-B6AE-087D34F611BE> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff3b679000 -     0x7fff3b679fff  com.apple.ApplicationServices (50.1 - 50.1) <4A6ACC13-2623-36B8-A196-2300980803CD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff3b67a000 -     0x7fff3b6e5fff  com.apple.ApplicationServices.ATS (377 - 453.11.2.2) <A258DA73-114B-3102-A056-4AAAD3CEB9DD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff3b77e000 -     0x7fff3b895fff  libFontParser.dylib (228.6.2.3) <3602D55B-3B9E-3B3A-A814-08C1244A8AE4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fff3b896000 -     0x7fff3b8d8fff  libFontRegistry.dylib (228.12.2.3) <2A56347B-2809-3407-A8B4-2AB88E484062> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff3b9c9000 -     0x7fff3b9cdff3  com.apple.ColorSyncLegacy (4.13.0 - 1) <B53D557C-071F-3ED9-826A-847DEB465F62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
    0x7fff3ba68000 -     0x7fff3babaff7  com.apple.HIServices (1.22 - 628) <26A8B7C0-41CC-3DB4-99D7-BD922866DC77> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff3babb000 -     0x7fff3bacafff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <F5617A2A-FEA6-3832-B5BA-C2111B98786F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff3bacb000 -     0x7fff3bb14ff7  com.apple.print.framework.PrintCore (14.2 - 503.8) <57C2FE32-0E74-3079-B626-C2D52F2D2717> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff3bb15000 -     0x7fff3bb4eff7  com.apple.QD (3.12 - 407.2) <28C7D39F-59C9-3314-BECC-67045487229C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff3bb4f000 -     0x7fff3bb5bfff  com.apple.speech.synthesis.framework (8.1.3 - 8.1.3) <80FA7439-EC77-3CEC-B5D1-5EFE9E503E11> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff3bb5c000 -     0x7fff3bdd3ff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <EB71583C-58C9-3CF8-92F9-2D57B24BBD4F> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff3bdd5000 -     0x7fff3bdd5fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <121176B6-7ABE-3AFB-A252-CCED694D98D4> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff3c12d000 -     0x7fff3c4cefff  com.apple.CFNetwork (978.0.7 - 978.0.7) <9FDEFE50-BE1B-386E-8B3C-AEF251069E52> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff3c4e3000 -     0x7fff3c4e3fff  com.apple.Carbon (158 - 158) <AC9E8C1E-2566-3C2C-8B6B-B5B4C9A1B8B7> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff3c4e4000 -     0x7fff3c4e7ffb  com.apple.CommonPanels (1.2.6 - 98) <1CD6D56D-8EC7-3528-8CBC-FC69533519B5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff3c4e8000 -     0x7fff3c7deff7  com.apple.HIToolbox (2.1.1 - 918.5) <F7DA4F20-123B-30FB-9C27-5AB1746DEF63> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff3c7df000 -     0x7fff3c7e2ff3  com.apple.help (1.3.8 - 66) <A08517EB-8958-36C9-AEE0-1A8FEEACBE3F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff3c7e3000 -     0x7fff3c7e8ff7  com.apple.ImageCapture (9.0 - 1534.2) <DB063E87-ED8F-3E4E-A7E2-A6B45FA73EF7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff3c7e9000 -     0x7fff3c87eff3  com.apple.ink.framework (10.9 - 225) <7C7E9483-2E91-3DD3-B1E0-C238F42CA0DD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff3c87f000 -     0x7fff3c897ff7  com.apple.openscripting (1.7 - 179.1) <9B8C1ECC-5864-3E21-9149-863E884EA25C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff3c8b7000 -     0x7fff3c8b8ff7  com.apple.print.framework.Print (14.2 - 267.4) <A7A9D2A0-D4E0-35EF-A0F7-50521F707C33> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff3c8b9000 -     0x7fff3c8bbff7  com.apple.securityhi (9.0 - 55006) <05717F77-7A7B-37E6-AB3E-03F063E9095B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff3c8bc000 -     0x7fff3c8c2ff7  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <3CC050FB-EBCB-3087-8EA5-F378C8F99217> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff3c9f2000 -     0x7fff3cabeff7  com.apple.ColorSync (4.13.0 - 3340.7) <74B373AB-42C7-330D-A577-1C43BFA6024F> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff3cc4a000 -     0x7fff3ccd0fff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <1E8E64E6-0E58-375A-97F7-07CB4EE181AC> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff3cd34000 -     0x7fff3cd5effb  com.apple.CoreBluetooth (1.0 - 1) <F08FE8C0-DD18-37E0-B707-3EF704A73FD6> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff3cd5f000 -     0x7fff3d0f1ff7  com.apple.CoreData (120 - 866.5) <E8EB8787-9802-315C-8DDB-A42DA5A78BB0> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff3d0f2000 -     0x7fff3d1d9ff7  com.apple.CoreDisplay (101.3 - 109.19) <B00A19C2-4A6A-388C-8AD6-33A42D10D7F0> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fff3d1da000 -     0x7fff3d61eff7  com.apple.CoreFoundation (6.9 - 1575.12) <B1D65801-A477-3F70-B97F-C2B43ECFF4FE> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff3d620000 -     0x7fff3dcccff7  com.apple.CoreGraphics (2.0 - 1260.2) <06B01A87-6CB4-3046-9D97-595BD8A9061A> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff3dcce000 -     0x7fff3dfeefff  com.apple.CoreImage (14.4.0 - 750.0.140) <96FA4D1B-AC88-305C-8F4D-D7D44657B733> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff3e44c000 -     0x7fff3e44cfff  com.apple.CoreServices (945 - 945) <E937BA69-19D5-3A30-B31E-8A6B94E9D9A0> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff3e44d000 -     0x7fff3e4c9ff7  com.apple.AE (773 - 773) <55AE7C9E-27C3-30E9-A047-3B92A6FD53B4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff3e4ca000 -     0x7fff3e7a1fff  com.apple.CoreServices.CarbonCore (1178.32 - 1178.32) <52F5484E-94B1-37B7-B1AC-E210DF5721AE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff3e7a2000 -     0x7fff3e7eaff7  com.apple.DictionaryServices (1.2 - 284.16.4) <C3D15FD1-759B-3815-8128-42D8220BC459> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff3e7eb000 -     0x7fff3e7f3ffb  com.apple.CoreServices.FSEvents (1239.200.12 - 1239.200.12) <8406D379-8D33-3611-861B-7ABD26DB50D2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff3e7f4000 -     0x7fff3e9a6fff  com.apple.LaunchServices (945 - 945) <05FA145B-75AA-3AE6-BB82-F156B29F4FF1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff3e9a7000 -     0x7fff3ea45ff7  com.apple.Metadata (10.7.0 - 1191.57) <BFFAED00-2560-318A-BB8F-4E7E5123EC61> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff3ea46000 -     0x7fff3ea90ff7  com.apple.CoreServices.OSServices (945 - 945) <119C5548-59C3-3F94-B23F-8AF02CA10EAA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff3ea91000 -     0x7fff3eaf8ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <DA08AA6F-A6F1-36C0-87F4-E26294E51A3A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff3eaf9000 -     0x7fff3eb1aff3  com.apple.coreservices.SharedFileList (71.28 - 71.28) <487A8464-729E-305A-B5D1-E3FE8EB9CFC5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff3ee25000 -     0x7fff3ef87ff3  com.apple.CoreText (352.0 - 584.26.3.2) <A99FD623-7F6E-3C77-8241-E98F664EC039> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff3ef88000 -     0x7fff3efc7fff  com.apple.CoreVideo (1.8 - 0.0) <1AD23C58-E68E-329B-A1FA-6BF7DD577687> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff3efc8000 -     0x7fff3f057fff  com.apple.framework.CoreWLAN (13.0 - 1375.2) <F2EA31D8-53BF-32E8-B537-64B4F2BF4B6E> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff3f2ae000 -     0x7fff3f2b3ffb  com.apple.DiskArbitration (2.7 - 2.7) <F481F2C0-884E-3265-8111-ABBEC93F0920> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff3f479000 -     0x7fff3f826fff  com.apple.Foundation (6.9 - 1575.12) <AD258ED7-64AE-367C-AE5F-48D45089D9F2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff3f895000 -     0x7fff3f8c4ffb  com.apple.GSS (4.0 - 2.0) <E41430E5-713B-3E53-BF7E-A3991A881B62> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff3f9c4000 -     0x7fff3facefff  com.apple.Bluetooth (6.0.12 - 6.0.12f1) <58A607F0-A818-3535-A7BD-858D5BB0A807> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff3fb30000 -     0x7fff3fbbffff  com.apple.framework.IOKit (2.0.2 - 1483.260.4) <CCA92450-8808-37EC-B68E-2C2846B086CE> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff3fbc1000 -     0x7fff3fbd0ffb  com.apple.IOSurface (255.5.4 - 255.5.4) <83F58E47-0D06-3E78-9D19-D38D3205464B> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff3fc24000 -     0x7fff3fdb2fff  com.apple.ImageIO.framework (3.3.0 - 1850.2) <DC226D07-C52D-3440-9027-D3EA33DD99B2> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff3fdb3000 -     0x7fff3fdb7ffb  libGIF.dylib (1850.2) <F5D1AA0A-4EB4-37C0-89AA-C71FB53405F2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff3fdb8000 -     0x7fff3fe95ff7  libJP2.dylib (1850.2) <2DE256E2-FA27-38A3-BFDF-5C1E0A135BCB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff3fe96000 -     0x7fff3febbfff  libJPEG.dylib (1850.2) <16A9719C-DB6E-37EE-B62F-DD81A822160A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff4017f000 -     0x7fff401a5ff7  libPng.dylib (1850.2) <EFB3874A-3ABB-3EC7-8708-0110ECFFE169> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff401a6000 -     0x7fff401a8ffb  libRadiance.dylib (1850.2) <19C26767-DE6D-3DE9-B5ED-F6BF148FBDBC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff401a9000 -     0x7fff401f6ffb  libTIFF.dylib (1850.2) <527F8740-9B75-39D6-AFD9-519817724B5D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff4136d000 -     0x7fff41386fff  com.apple.Kerberos (3.0 - 1) <DB1E0679-37E1-3B93-9789-32F63D660C3B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff41da2000 -     0x7fff41e4aff7  com.apple.Metal (161.9.16 - 161.9.16) <A93AA7FC-B72A-3CBF-9932-81DDDFA1DFCD> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff41e66000 -     0x7fff41e85ff7  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <EE85B6D5-5C12-3CE8-8C33-54A203EDC76E> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
    0x7fff41e86000 -     0x7fff41f02fe7  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <5A78F2DC-9D2B-37BA-B21F-ECFFCC6F7720> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
    0x7fff41f03000 -     0x7fff41f2afff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <096DB3E6-7DDF-3B47-857A-46A203642ACF> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
    0x7fff41f2b000 -     0x7fff42056ff7  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <D2128338-F1E8-3BEE-A729-AC13A524DD78> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
    0x7fff42057000 -     0x7fff42071fff  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <ADA5A93C-F79E-3931-840D-48C6B6B305EA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
    0x7fff42072000 -     0x7fff42073ff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <515A92B3-A23B-3AC2-8D1B-85B248595B76> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fff42e6a000 -     0x7fff42e76ff7  com.apple.NetFS (6.0 - 4.0) <E917806F-0607-3292-B2D6-A15404D61B99> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff45914000 -     0x7fff4596bff7  com.apple.opencl (2.15.3 - 2.15.3) <AA9CE8F7-DB7C-35A5-A019-2207D1BBFF38> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff4596c000 -     0x7fff45987ff7  com.apple.CFOpenDirectory (10.14 - 207.200.4) <F03D84EB-49B2-3A00-9127-B9A269824026> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff45988000 -     0x7fff45993ffb  com.apple.OpenDirectory (10.14 - 207.200.4) <A8020CEE-5B78-3581-A735-EA2833683F31> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff462e3000 -     0x7fff462e5fff  libCVMSPluginSupport.dylib (17.7.2) <247121BB-626C-318E-B24E-3D436E752DF7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff462e6000 -     0x7fff462ebff3  libCoreFSCache.dylib (166.2) <222C2A4F-7E32-30F6-8459-2FAB98073A3D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fff462ec000 -     0x7fff462f0fff  libCoreVMClient.dylib (166.2) <6789ECD4-91DD-32EF-A1FD-F27D2344CD8B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff462f1000 -     0x7fff462f9ff7  libGFXShared.dylib (17.7.2) <B75A6E93-E5BE-32A8-8D46-00D8E909DFD3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff462fa000 -     0x7fff46305fff  libGL.dylib (17.7.2) <E88FF023-7E15-3E95-88FD-6C415550F769> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff46306000 -     0x7fff46340fe7  libGLImage.dylib (17.7.2) <B4C140F3-AF8C-30C8-A03E-B16A20BB05A7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff464b4000 -     0x7fff464f2fff  libGLU.dylib (17.7.2) <EA69FA36-3F20-337C-A6B3-EC49DC2F12F5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff46e8f000 -     0x7fff46e9effb  com.apple.opengl (17.7.2 - 17.7.2) <8EFFA6F9-ABE8-3131-9D3F-37E9796DDF34> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff47ca1000 -     0x7fff47ef7fff  com.apple.QuartzCore (1.11 - 699.27.4.1) <BB3BBD58-84DF-3849-B4ED-5FF8DA4015B8> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff4872c000 -     0x7fff48a2bfff  com.apple.security (7.0 - 58286.260.20) <59B4100E-5A31-3EF4-954A-2A69341995F3> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff48a2c000 -     0x7fff48ab8fff  com.apple.securityfoundation (6.0 - 55185.260.1) <DB8EB672-5D3A-3082-A62E-4D75C81D94A4> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff48aea000 -     0x7fff48aeefff  com.apple.xpc.ServiceManagement (1.0 - 1) <4AD0F8EE-884C-3FA7-85D9-27F201BC3C64> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff48e86000 -     0x7fff48ef3fff  com.apple.SystemConfiguration (1.17 - 1.17) <1562078D-3251-31B2-B9C6-2667C567F883> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff4c172000 -     0x7fff4c217feb  com.apple.APFS (1.0 - 1) <C001DCC2-32BE-327A-AE03-281885BD93BF> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
    0x7fff4cc29000 -     0x7fff4cc2aff7  com.apple.AggregateDictionary (1.0 - 1) <A6AF8AC4-1F25-37C4-9157-A02E9C200926> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
    0x7fff4d228000 -     0x7fff4d254ff7  com.apple.framework.Apple80211 (13.0 - 1380.2) <3850E3A9-E00A-374E-87EA-AB01E503E769> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff4d37c000 -     0x7fff4d38bfc7  com.apple.AppleFSCompression (96.200.3 - 1.0) <3CF60CE8-976E-3CB8-959D-DD0948C1C2DE> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fff4d487000 -     0x7fff4d492fff  com.apple.AppleIDAuthSupport (1.0 - 1) <2E9D1398-DBE6-328B-ADDA-20FA5FAD7405> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
    0x7fff4d4d3000 -     0x7fff4d51cff3  com.apple.AppleJPEG (1.0 - 1) <4C1F426B-7D77-3980-9633-7DBD8C666B9A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff4d770000 -     0x7fff4d792fff  com.apple.applesauce (1.0 - ???) <F49107C7-3C51-3024-8EF1-C57643BE4F3B> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
    0x7fff4d8f1000 -     0x7fff4d905ffb  com.apple.AssertionServices (1.0 - 1) <11FC4241-6069-3B3A-9BCE-9B68F3A4D2AB> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
    0x7fff4dcd4000 -     0x7fff4ddc0ff7  com.apple.AuthKit (1.0 - 1) <34496FD5-4BAB-3DF3-BF7F-70F38C66848D> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
    0x7fff4df82000 -     0x7fff4df8afff  com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <2A396FC0-7B79-3088-9A82-FB93C1181A57> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
    0x7fff4df8b000 -     0x7fff4e020fff  com.apple.backup.framework (1.10.5 - ???) <BAFC1D7F-9D75-3C45-AAD4-569D13E445C5> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fff4e021000 -     0x7fff4e08eff3  com.apple.BaseBoard (360.28 - 360.28) <DBE27FB4-3FFD-3E9A-846C-F6E7D797286A> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
    0x7fff4fcf8000 -     0x7fff4fd01ffb  com.apple.CommonAuth (4.0 - 2.0) <81C987FD-69EB-344B-94D9-B9D93624D257> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff509d9000 -     0x7fff509eaff7  com.apple.CoreEmoji (1.0 - 69.19.9) <228457B3-E191-356E-9A5B-3C0438D05FBA> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fff50f93000 -     0x7fff50ff9ff7  com.apple.CoreNLP (1.0 - 130.15.22) <27877820-17D0-3B02-8557-4014E876CCC7> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
    0x7fff512a6000 -     0x7fff512aeff7  com.apple.CorePhoneNumbers (1.0 - 1) <7A826DA2-4725-39D8-AF27-6F034DC53C4E> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
    0x7fff5142a000 -     0x7fff5145bff3  com.apple.CoreServicesInternal (358 - 358) <DD6EF60D-048F-3186-83DA-EB191EDF48AE> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff51822000 -     0x7fff518a6fff  com.apple.CoreSymbolication (10.2 - 64490.25.1) <28B2FF2D-3FDE-3A20-B343-341E5BD4E22F> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff51936000 -     0x7fff51a61ff7  com.apple.coreui (2.1 - 499.10) <105F61F3-D0AE-332B-A485-8615187BB409> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff51a62000 -     0x7fff51c00fff  com.apple.CoreUtils (5.8 - 580.19) <CF9C5677-4946-3328-8CE3-C70F2E8599D8> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fff51c54000 -     0x7fff51cb7ff7  com.apple.framework.CoreWiFi (13.0 - 1375.2) <77E078A7-A34F-333B-B50F-8829537D6E9D> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff51cb8000 -     0x7fff51cc9ff7  com.apple.CrashReporterSupport (10.13 - 938.25) <C7665EC7-9389-3717-B152-A59D7872C63C> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff51d59000 -     0x7fff51d68fff  com.apple.framework.DFRFoundation (1.0 - 211.1) <E3F02F2A-2059-39CC-85DA-969676EB88EB> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fff51d69000 -     0x7fff51d6dfff  com.apple.DSExternalDisplay (3.1 - 380) <645C719D-05D4-3CD7-84D7-4C5218859E0C> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
    0x7fff51dee000 -     0x7fff51e63ff3  com.apple.datadetectorscore (7.0 - 590.24) <72F0CBF1-D3E9-36C5-B877-F42E1EC59A0E> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff51eaf000 -     0x7fff51eecff7  com.apple.DebugSymbols (190 - 190) <6F4FAACA-E06B-38AD-A0C2-14EA5408A231> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff51eed000 -     0x7fff52028ff7  com.apple.desktopservices (1.13.5 - ???) <4AF2E011-2CB0-3588-83CB-882ADDA78CAD> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff52f65000 -     0x7fff53380fff  com.apple.vision.FaceCore (3.3.4 - 3.3.4) <A576E2DA-BF6F-3B18-8FEB-324E5C5FA9BD> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff582d5000 -     0x7fff582dafff  com.apple.GPUWrangler (3.40.16 - 3.40.16) <B9D4F2DD-5D11-32FF-B5BE-29E137458728> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
    0x7fff590e5000 -     0x7fff590f4fff  com.apple.GraphVisualizer (1.0 - 5) <48D020B7-5938-3FAE-B468-E291AEE2C06F> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
    0x7fff59244000 -     0x7fff592b8ffb  com.apple.Heimdal (4.0 - 2.0) <5E8F6B79-960D-3030-B889-D29A4015D205> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff5a5a7000 -     0x7fff5a5aeffb  com.apple.IOAccelerator (404.9 - 404.9) <F9C604B3-3DF7-3EE7-8A44-7877FAF2E6A4> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff5a5b2000 -     0x7fff5a5cafff  com.apple.IOPresentment (1.0 - 42.6) <55CB91EF-90F1-3D0A-A59E-2F75CD2EB4AE> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fff5a972000 -     0x7fff5a99fff7  com.apple.IconServices (379 - 379) <7BAD562D-4FA3-3E11-863C-1EEBE2406D2C> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff5ac33000 -     0x7fff5ac45ff3  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <5AAC527E-D197-39B2-A6C9-E0D0FB9CA9B9> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
    0x7fff5ac60000 -     0x7fff5ad3bff7  com.apple.LanguageModeling (1.0 - 159.15.15) <3DE3CE61-542B-37B7-883E-4B9717CAC65F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff5ad3c000 -     0x7fff5ad78ff7  com.apple.Lexicon-framework (1.0 - 33.15.10) <4B5E843E-2809-3E70-9560-9254E2656419> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
    0x7fff5ad7f000 -     0x7fff5ad84fff  com.apple.LinguisticData (1.0 - 238.25) <61910887-D5CE-3567-9A5F-6DFEC942EC1F> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
    0x7fff5ba79000 -     0x7fff5baa1ff7  com.apple.spotlight.metadata.utilities (1.0 - 1191.57) <38BB1FB7-3336-384C-B71F-4D0D402EB606> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
    0x7fff5baa2000 -     0x7fff5bb2fff7  com.apple.gpusw.MetalTools (1.0 - 1) <DBC4718E-F588-382D-A415-405D0028804D> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
    0x7fff5bcdc000 -     0x7fff5bcf7ffb  com.apple.MobileKeyBag (2.0 - 1.0) <4678FECE-538B-381C-80F2-27AA4805F160> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
    0x7fff5bd80000 -     0x7fff5bdaaffb  com.apple.MultitouchSupport.framework (2450.1 - 2450.1) <3BF81F33-89A8-3A2D-84B3-B343020B6D98> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff5bfe6000 -     0x7fff5bff0fff  com.apple.NetAuth (6.2 - 6.2) <0D01BBE5-0269-310D-B148-D19DAE143DEB> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff5c851000 -     0x7fff5c8a2ff3  com.apple.OTSVG (1.0 - ???) <3976F8CC-1CFB-3E09-9009-FE985550565B> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
    0x7fff5da27000 -     0x7fff5da36ff7  com.apple.PerformanceAnalysis (1.218.2 - 218.2) <65F3DB3E-6D4E-33A0-B510-EF768D323DAB> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff5f8c6000 -     0x7fff5f8e4ff7  com.apple.ProtocolBuffer (1 - 263.2) <907D6C95-D050-31DE-99CA-16A5135BC6F9> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff5fa7c000 -     0x7fff5faccfff  com.apple.ROCKit (27.6 - 27.6) <756C2253-E8B1-3C48-9945-DE8D6AD24DE2> /System/Library/PrivateFrameworks/ROCKit.framework/Versions/A/ROCKit
    0x7fff5fc1f000 -     0x7fff5fc41fff  com.apple.RemoteViewServices (2.0 - 128) <8FB0E4EB-DCBB-32E6-94C6-AA9BA9EE4CAC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff61446000 -     0x7fff61564fff  com.apple.Sharing (1288.43 - 1288.43) <B9AB8C05-F2F2-371F-A9AF-1D139E2CE54C> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff62375000 -     0x7fff62623ffb  com.apple.SkyLight (1.600.0 - 340.26) <CD2A7069-6CEA-3737-9E9D-7AE2FED912AB> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fff62dc5000 -     0x7fff62dd1fff  com.apple.SpeechRecognitionCore (5.0.21 - 5.0.21) <7A6A67DB-C813-328E-AAFB-D267A5B50B3D> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fff63522000 -     0x7fff635adfc7  com.apple.Symbolication (10.2 - 64490.38.1) <9FDCC98D-5B32-35AD-A9BF-94DF2B78507F> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fff63a95000 -     0x7fff63aa1ffb  com.apple.TCC (1.0 - 1) <968ECAE1-FBB9-3478-BDCE-85E54B6C422D> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff63d07000 -     0x7fff63dcfff3  com.apple.TextureIO (3.8.4 - 3.8.1) <7CEAC05A-D283-3D5A-B1E3-C849285FA0BF> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fff63e8c000 -     0x7fff64042ff7  com.apple.UIFoundation (1.0 - 551) <E9D17DAD-230D-390A-B117-3D100C5AF5F2> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff6556e000 -     0x7fff65571fff  com.apple.dt.XCTTargetBootstrap (1.0 - 14490.66) <7AE3457F-AF40-3508-93FB-1D9E31EB1C9D> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
    0x7fff65972000 -     0x7fff65974ffb  com.apple.loginsupport (1.0 - 1) <3F8D6334-BCD6-36C1-BA20-CC8503A84375> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fff65c3e000 -     0x7fff65c72fff  libCRFSuite.dylib (41.15.4) <406DAC06-0C77-3F90-878B-4D38F11F0256> /usr/lib/libCRFSuite.dylib
    0x7fff65c75000 -     0x7fff65c7fff7  libChineseTokenizer.dylib (28.15.3) <9B7F6109-3A5D-3641-9A7E-31D2239D73EE> /usr/lib/libChineseTokenizer.dylib
    0x7fff65d0d000 -     0x7fff65d0effb  libDiagnosticMessagesClient.dylib (107) <A14D0819-0970-34CD-8680-80E4D7FE8C2C> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff65d45000 -     0x7fff65f9cff3  libFosl_dynamic.dylib (18.3.4) <45E50221-1A39-3AB3-8267-C1E4E39ECF83> /usr/lib/libFosl_dynamic.dylib
    0x7fff65fed000 -     0x7fff6600bfff  libMobileGestalt.dylib (645.260.6) <0232958E-1EF2-3627-B8FF-09C6522594C7> /usr/lib/libMobileGestalt.dylib
    0x7fff6600c000 -     0x7fff6600cfff  libOpenScriptingUtil.dylib (179.1) <4D603146-EDA5-3A74-9FF8-4F75D8BB9BC6> /usr/lib/libOpenScriptingUtil.dylib
    0x7fff6614c000 -     0x7fff6614dffb  libSystem.B.dylib (1252.250.1) <1A13E822-B59C-3A36-A2E4-9968149714F9> /usr/lib/libSystem.B.dylib
    0x7fff661c9000 -     0x7fff661cafff  libThaiTokenizer.dylib (2.15.1) <ADB37DC3-7D9B-3E73-A72A-BCC3433C937A> /usr/lib/libThaiTokenizer.dylib
    0x7fff661dc000 -     0x7fff661f2ffb  libapple_nghttp2.dylib (1.24.1) <6F04250A-6686-3FDC-9A8D-290C64B06502> /usr/lib/libapple_nghttp2.dylib
    0x7fff661f3000 -     0x7fff6621cffb  libarchive.2.dylib (54.250.1) <47289946-8504-3966-9127-6CE39993DC2C> /usr/lib/libarchive.2.dylib
    0x7fff6621d000 -     0x7fff6631cfef  libate.dylib (1.13.8) <461F7EA4-05E2-3091-8905-473A63A75300> /usr/lib/libate.dylib
    0x7fff66320000 -     0x7fff66320ff3  libauto.dylib (187) <3E3780E1-96F3-3A22-91C5-92F9A5805518> /usr/lib/libauto.dylib
    0x7fff663f0000 -     0x7fff66400ffb  libbsm.0.dylib (39.200.18) <CF381E0B-025B-364F-A83D-2527E03F1AA3> /usr/lib/libbsm.0.dylib
    0x7fff66401000 -     0x7fff6640efff  libbz2.1.0.dylib (38.200.3) <272953A1-8D36-329B-BDDB-E887B347710F> /usr/lib/libbz2.1.0.dylib
    0x7fff6640f000 -     0x7fff66462ff7  libc++.1.dylib (400.9.4) <9A60A190-6C34-339F-BB3D-AACE942009A4> /usr/lib/libc++.1.dylib
    0x7fff66463000 -     0x7fff66478ff7  libc++abi.dylib (400.17) <38C09CED-9090-3719-90F3-04A2749F5428> /usr/lib/libc++abi.dylib
    0x7fff66479000 -     0x7fff66479ff3  libcharset.1.dylib (51.200.6) <2A27E064-314C-359C-93FC-8A9B06206174> /usr/lib/libcharset.1.dylib
    0x7fff6647a000 -     0x7fff6648affb  libcmph.dylib (6.15.1) <9C52B2FE-179F-32AC-B87E-2AFC49ABF817> /usr/lib/libcmph.dylib
    0x7fff6648b000 -     0x7fff664a3ffb  libcompression.dylib (52.250.2) <C7BE9843-9B19-33E0-A4A0-D48D0A999E86> /usr/lib/libcompression.dylib
    0x7fff66718000 -     0x7fff6672efff  libcoretls.dylib (155.220.1) <4C64BE3E-41E3-3020-8BB7-07E90C0C861C> /usr/lib/libcoretls.dylib
    0x7fff6672f000 -     0x7fff66730ff3  libcoretls_cfhelpers.dylib (155.220.1) <0959B3E9-6643-3589-8BB3-21D52CDF0EF1> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fff66bdc000 -     0x7fff66c32ff7  libcups.2.dylib (462.10) <2AC7B8C3-0D25-3E0F-A34A-94658A06FF94> /usr/lib/libcups.2.dylib
    0x7fff66d66000 -     0x7fff66d66fff  libenergytrace.dylib (17.200.1) <80BB567A-FD18-3497-BF97-353F57D98CDD> /usr/lib/libenergytrace.dylib
    0x7fff66d98000 -     0x7fff66d9dff7  libgermantok.dylib (17.15.2) <E5F0F794-FF27-3D64-AE52-C78C6A84DD67> /usr/lib/libgermantok.dylib
    0x7fff66d9e000 -     0x7fff66da3ff7  libheimdal-asn1.dylib (520.260.1) <DC44D1D1-D3DF-38B3-AFC3-1D50B92BE401> /usr/lib/libheimdal-asn1.dylib
    0x7fff66dce000 -     0x7fff66ebefff  libiconv.2.dylib (51.200.6) <2047C9B7-3F74-3A95-810D-2ED8F0475A99> /usr/lib/libiconv.2.dylib
    0x7fff66ebf000 -     0x7fff67120fff  libicucore.A.dylib (62135.0.1) <2B292561-798A-381C-AA41-90EE6549C7CF> /usr/lib/libicucore.A.dylib
    0x7fff6716d000 -     0x7fff6716efff  liblangid.dylib (128.15.1) <22D05C4F-769B-3075-ABCF-44A0EBACE028> /usr/lib/liblangid.dylib
    0x7fff6716f000 -     0x7fff67187ff3  liblzma.5.dylib (10.200.3) <E1F4FD60-1CE4-37B9-AD95-29D348AF1AC0> /usr/lib/liblzma.5.dylib
    0x7fff6719f000 -     0x7fff67243ff7  libmecab.1.0.0.dylib (779.24.1) <A8D0379B-85FA-3B3D-89ED-5CF2C3826AB2> /usr/lib/libmecab.1.0.0.dylib
    0x7fff67244000 -     0x7fff67448fff  libmecabra.dylib (779.24.1) <D71F71E0-30E2-3DB3-B636-7DE13D51FB4B> /usr/lib/libmecabra.dylib
    0x7fff67620000 -     0x7fff67971ff7  libnetwork.dylib (1229.250.15) <72C7E9E3-B2BE-3300-BE1B-64606222022C> /usr/lib/libnetwork.dylib
    0x7fff67a03000 -     0x7fff6818bfd7  libobjc.A.dylib (756.2) <20942D4E-CE6F-376A-8BCD-016F88E4BFD5> /usr/lib/libobjc.A.dylib
    0x7fff6819d000 -     0x7fff681a1ffb  libpam.2.dylib (22.200.1) <586CF87F-349C-393D-AEEB-FB75F94A5EB7> /usr/lib/libpam.2.dylib
    0x7fff681a4000 -     0x7fff681d9fff  libpcap.A.dylib (79.250.1) <C0893641-7DFF-3A33-BDAE-190FF54837E8> /usr/lib/libpcap.A.dylib
    0x7fff682f2000 -     0x7fff6830affb  libresolv.9.dylib (65.200.2) <893142A5-F153-3437-A22D-407EE542B5C5> /usr/lib/libresolv.9.dylib
    0x7fff6835d000 -     0x7fff6852effb  libsqlite3.dylib (274.25) <F9589951-4ADE-3CD4-9D79-B4A0FD12E844> /usr/lib/libsqlite3.dylib
    0x7fff68747000 -     0x7fff6874aff7  libutil.dylib (51.200.4) <CE9B18C9-66ED-32D4-9D29-01F8FCB467B0> /usr/lib/libutil.dylib
    0x7fff6874b000 -     0x7fff68758fff  libxar.1.dylib (417.1) <39CCF46B-C81A-34B1-92A1-58C4E5DA846E> /usr/lib/libxar.1.dylib
    0x7fff6875d000 -     0x7fff6883fff3  libxml2.2.dylib (32.8) <54F896CF-6D83-300B-9CD9-1636BE5375A4> /usr/lib/libxml2.2.dylib
    0x7fff68840000 -     0x7fff68868ff3  libxslt.1.dylib (16.1) <31F7018B-D8F2-36ED-A13B-1E5A16DFAAA1> /usr/lib/libxslt.1.dylib
    0x7fff68869000 -     0x7fff6887bff7  libz.1.dylib (70.200.4) <B048FC1F-058F-3A08-A1FE-81D5308CB3E6> /usr/lib/libz.1.dylib
    0x7fff6905f000 -     0x7fff69063ff3  libcache.dylib (81) <1987D1E1-DB11-3291-B12A-EBD55848E02D> /usr/lib/system/libcache.dylib
    0x7fff69064000 -     0x7fff6906eff3  libcommonCrypto.dylib (60118.250.2) <1765BB6E-6784-3653-B16B-CB839721DC9A> /usr/lib/system/libcommonCrypto.dylib
    0x7fff6906f000 -     0x7fff69076ff7  libcompiler_rt.dylib (63.4) <5212BA7B-B7EA-37B4-AF6E-AC4F507EDFB8> /usr/lib/system/libcompiler_rt.dylib
    0x7fff69077000 -     0x7fff69080ff7  libcopyfile.dylib (146.250.1) <98CD00CD-9B91-3B5C-A9DB-842638050FA8> /usr/lib/system/libcopyfile.dylib
    0x7fff69081000 -     0x7fff69105fc3  libcorecrypto.dylib (602.260.2) <BED0F385-D8A2-334A-BD7B-0673B5DABBC5> /usr/lib/system/libcorecrypto.dylib
    0x7fff6918c000 -     0x7fff691c5ff7  libdispatch.dylib (1008.250.7) <26DF5B1E-A388-38EF-B73B-AF0E93FB02DB> /usr/lib/system/libdispatch.dylib
    0x7fff691c6000 -     0x7fff691f2ff7  libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib
    0x7fff691f3000 -     0x7fff691f3ffb  libkeymgr.dylib (30) <0D0F9CA2-8D5A-3273-8723-59987B5827F2> /usr/lib/system/libkeymgr.dylib
    0x7fff691f4000 -     0x7fff69200ff3  libkxld.dylib (4903.261.4) <71CF1ECD-AC4E-3FDD-BEDF-14933D843EEE> /usr/lib/system/libkxld.dylib
    0x7fff69201000 -     0x7fff69201ff7  liblaunch.dylib (1336.261.2) <BD5CDB35-2BB4-349A-8D14-78E387563F89> /usr/lib/system/liblaunch.dylib
    0x7fff69202000 -     0x7fff69207fff  libmacho.dylib (927.0.2) <3C5C9024-45FD-38C2-B01A-07A322966063> /usr/lib/system/libmacho.dylib
    0x7fff69208000 -     0x7fff6920affb  libquarantine.dylib (86.220.1) <6D0BC770-7348-3608-9254-F7FFBD347634> /usr/lib/system/libquarantine.dylib
    0x7fff6920b000 -     0x7fff6920cff7  libremovefile.dylib (45.200.2) <9FBEB2FF-EEBE-31BC-BCFC-C71F8D0E99B6> /usr/lib/system/libremovefile.dylib
    0x7fff6920d000 -     0x7fff69224ff3  libsystem_asl.dylib (356.200.4) <A62A7249-38B8-33FA-9875-F1852590796C> /usr/lib/system/libsystem_asl.dylib
    0x7fff69225000 -     0x7fff69225ff7  libsystem_blocks.dylib (73) <A453E8EE-860D-3CED-B5DC-BE54E9DB4348> /usr/lib/system/libsystem_blocks.dylib
    0x7fff69226000 -     0x7fff692adfff  libsystem_c.dylib (1272.250.1) <7EDACF78-2FA3-35B8-B051-D70475A35117> /usr/lib/system/libsystem_c.dylib
    0x7fff692ae000 -     0x7fff692b1ffb  libsystem_configuration.dylib (963.260.1) <C7D2BA09-8D5B-3393-8D84-304D76C55DEF> /usr/lib/system/libsystem_configuration.dylib
    0x7fff692b2000 -     0x7fff692b5ff7  libsystem_coreservices.dylib (66) <719F75A4-74C5-3BA6-A09E-0C5A3E5889D7> /usr/lib/system/libsystem_coreservices.dylib
    0x7fff692b6000 -     0x7fff692bcfff  libsystem_darwin.dylib (1272.250.1) <EC9B39A5-9592-3577-8997-7DC721D20D8C> /usr/lib/system/libsystem_darwin.dylib
    0x7fff692bd000 -     0x7fff692c3ff7  libsystem_dnssd.dylib (878.260.1) <64B79B01-B1B0-3C7E-87A1-023B71843F1F> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff692c4000 -     0x7fff6930fffb  libsystem_info.dylib (517.200.9) <D09D5AE0-2FDC-3A6D-93EC-729F931B1457> /usr/lib/system/libsystem_info.dylib
    0x7fff69310000 -     0x7fff69338ff7  libsystem_kernel.dylib (4903.261.4) <7B0F52C4-4CC9-3282-8457-C18C6FE1B99E> /usr/lib/system/libsystem_kernel.dylib
    0x7fff69339000 -     0x7fff69384ff7  libsystem_m.dylib (3158.200.7) <F19B6DB7-014F-3820-831F-389CCDA06EF6> /usr/lib/system/libsystem_m.dylib
    0x7fff69385000 -     0x7fff693affff  libsystem_malloc.dylib (166.261.1) <4D1CEF38-DE32-3ECF-9F70-0ADDD5C8775F> /usr/lib/system/libsystem_malloc.dylib
    0x7fff693b0000 -     0x7fff693baff7  libsystem_networkextension.dylib (767.250.2) <FF06F13A-AEFE-3A27-A073-910EF78AEA36> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff693bb000 -     0x7fff693c2fff  libsystem_notify.dylib (172.200.21) <145B5CFC-CF73-33CE-BD3D-E8DDE268FFDE> /usr/lib/system/libsystem_notify.dylib
    0x7fff693c3000 -     0x7fff693ccfef  libsystem_platform.dylib (177.250.1) <16949870-9152-3B0D-9EF0-40FAF84B0F1E> /usr/lib/system/libsystem_platform.dylib
    0x7fff693cd000 -     0x7fff693d7ff7  libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib
    0x7fff693d8000 -     0x7fff693dbff7  libsystem_sandbox.dylib (851.260.2) <9CACC5F5-3859-3A1F-BCC6-96DDD4A556A8> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff693dc000 -     0x7fff693deff3  libsystem_secinit.dylib (30.260.2) <88F3CE61-5FAD-3CDA-AA13-B5B18B3EBD26> /usr/lib/system/libsystem_secinit.dylib
    0x7fff693df000 -     0x7fff693e6ff3  libsystem_symptoms.dylib (820.267.1) <03F1C2DD-0F5A-3D9D-88F6-B26C0F94EB52> /usr/lib/system/libsystem_symptoms.dylib
    0x7fff693e7000 -     0x7fff693fcfff  libsystem_trace.dylib (906.260.1) <100013AE-0443-3CF0-AC17-5D934608B60B> /usr/lib/system/libsystem_trace.dylib
    0x7fff693fe000 -     0x7fff69403ffb  libunwind.dylib (35.4) <24A97A67-F017-3CFC-B0D0-6BD0224B1336> /usr/lib/system/libunwind.dylib
    0x7fff69404000 -     0x7fff69433fff  libxpc.dylib (1336.261.2) <9A0FFA79-082F-3293-BF49-63976B073B74> /usr/lib/system/libxpc.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 1695
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=496.8M resident=0K(0%) swapped_out_or_unallocated=496.8M(100%)
Writable regions: Total=28.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=28.1G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Activity Tracing                   256K        1
Dispatch continuations            8192K        1
Kernel Alloc Once                    8K        1
MALLOC                            68.0M       24
MALLOC guard page                   16K        4
MALLOC_LARGE (reserved)            384K        1         reserved VM address space (unallocated)
STACK GUARD                         12K        3
Stack                             9752K        4
Stack Guard                       56.0M        1
VM_ALLOCATE                          8K        2
VM_ALLOCATE (reserved)            32.0M        1         reserved VM address space (unallocated)
__DATA                            29.3M      342
__FONT_DATA                          4K        1
__LINKEDIT                       242.0M       88
__TEXT                           254.7M      316
__UNICODE                          564K        1
dylib (reserved)                  28.0G        7         reserved VM address space (unallocated)
mapped file                       25.9M        2
shared memory                      592K        6
TOTAL                             28.7G      806
TOTAL, minus reserved VM space   694.9M      806
Model: Macmini6,1, BootROM 278.0.0.0.0, 2 processors, Intel Core i5, 2,5 GHz, 4 GB, SMC 2.7f0
Graphics: kHW_IntelHD4000Item, Intel HD Graphics 4000, spdisplays_builtin
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333235533643465238432D50422020
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333235533643465238432D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x10E), Broadcom BCM43xx 1.0 (7.21.190.33 AirPortDriverBrcm4360-1325.2)
Bluetooth: Version 6.0.12f1, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: M4-CT128M4SSD2, 128,04 GB
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: Hub
USB Device: Hub
USB Device: IR Receiver
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB 3.0 Bus
USB Device: USB Receiver
USB Device: Hub
USB Device: Apple Keyboard
Thunderbolt Bus: Mac mini, Apple Inc., 23.4
Thank you
Message 13 of 15
JeromeBriot
If anyone wants to investigate this issue in a real case, you can download my latest add-in 3D Print Plus (it's free).
Message 14 of 15
JeromeBriot
The recent update to Python 3.7.3 didn't solve the problem 😟
Message 15 of 15
marvinQ8Y7M
Observer
Observer
any updates on the topic?
Marvin
