Typos in the API documentation
JeromeBriot
Mentor Mentor
JeromeBriot
1) There is a missing "r" in the title and the breadcrumb of the Features.pipeFeatures documentation
2) The anchor in the URL for "Activate, Deactivate, and Destroy Events" on the Commands documentation needs a capitalized "D" :
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-3922697A-7BF1-4799-9A5B-C8539DF57051#Activat...DeactivateandDestroyEvents
JeromeBriot
Information about the return parameter is missing in the documentation of the Profile.areaProperties Method.
It should point to the documentation of the AreaProperties Object.
JeromeBriot
In documentation of ConstructionPlaneInput, ConstructionAxisInput, ConstructionPointInput and similar inputs, there is a typo in the targetBaseOrFormFeature property:
Because of a current limitation, if you want to create a construction plane associated with a base or form feature, you must set this property AND call the startEdit method of the base or form feature, create the feature, and then call the finishEdit method of the base or form feature. The base or form feature must be in an "edit" state to be able to add any additional items to it.
JeromeBriot
In the Features sample section of the documentation, all samples have a double "API Sample" in their titles (except the first one).
Example for the Hole Feature sample: Hole Feature API Sample API Sample
