Trying to get RoboDK to Work with Fusion 360, Unable to Edit the Settings?
jon.one.2021
Observer Observer
jon.one.2021
Observer
Observer
Hey all, I have been trying to understand how to get RoboDK to work with Fusion360 but it gives me an error every time I try to open the 'RoboDK Add-In Settings' in the Design>Tools>RoboDK menu.
I have a setup for the robot I'm using, originally I was using Alphacam and would select the setup file for the robots position when transferring a file from Alphacam to RoboDK, but i'm not sure how to get Fusion to use that same setup file for operations loaded into it from Fusion 360.
The error says:
can't set attribute
Traceback (most recent call last):
File "C:/RoboDK/Other/Plugin-Fusion360/RoboDK/v373/fission\app.py", line 367, in notify
File "C:/RoboDK/Other/Plugin-Fusion360/RoboDK/v373/fission\app.py", line 570, in __on_create
File "C:/RoboDK/Other/Plugin-Fusion360/RoboDK/v373/robodk_autodesk.py", line 181, in initialize_inputs
File "C:/RoboDK/Other/Plugin-Fusion360/RoboDK/v373/fission\app.py", line 930, in begin_tab
AttributeError: can't set attribute
Does anyone have an idea or a different setup guide?
I have been reading through: https://robodk.com/doc/en/Plugin-Fusion360.html
Many thanks!
JeromeBriot
Unfortunately the source code of this add-in is not accessible. You have to contact its author for support.
