timelineObject for moving bodies
brad.bylls
Message 1 of 8
brad.bylls
I am grouping objects in the timeline.
However, I cannot find the last 'move' timelineObject
I would like to get the 'move' (red arrow) into the group (blue arrow)
The code works and moves the bodies, I just want to get the timelimeObject 'move' into the group.
This is the part of the code I am working with.
Brad Bylls
Replies (7)
Message 2 of 8
kandennti
Hi @brad.bylls .
Perhaps it is not possible to add elements to a timeline group.
Therefore, I deleted the timeline group and re-created it.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        tlGroup: adsk.fusion.TimelineGroup = des.timeline.timelineGroups[-1]
        targetFeat: adsk.fusion.MoveFeature = root.features.moveFeatures[-1]
        add_group_like(tlGroup, targetFeat)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def add_group_like(
    group: adsk.fusion.TimelineGroup,
    targetFeat: adsk.fusion.MoveFeature) -> adsk.fusion.TimelineGroup:
    # backup
    backupCollapsed = group.isCollapsed
    backupName = group.name
    # get timeline group items
    startObj: adsk.fusion.TimelineObject = group.item(0)
    endObj: adsk.fusion.TimelineObject= group.item(group.count - 1)
    # delete timeline group
    group.isCollapsed = True
    group.deleteMe(False)
    # get the index that creates the group
    indexes = [
        startObj.index,
        endObj.index,
        targetFeat.timelineObject.index
    startIdx = min(indexes)
    endIdx = max(indexes)
    # create new timeline group
    des: adsk.fusion.Design = targetFeat.parentComponent.parentDesign
    groups: adsk.fusion.TimelineGroups = des.timeline.timelineGroups
    newGroup: adsk.fusion.TimelineGroup = groups.add(startIdx, endIdx)
    # match state
    newGroup.isCollapsed = backupCollapsed
    newGroup.name = backupName
    return newGroup
If you run it with the attached f3d file, you will see the following.
Message 3 of 8
BrianEkins
@kandennti is correct. Fusion doesn't support adding items to an existing group. The exception to this is if you expand the group and move the timeline marker to somewhere within the group, and add a new feature. The new feature will now be part of a group. However, it's not possible to move the timeline marker to the end of the group, so it's after the last feature but still within the group. The best alternative is, as kandennti suggested, and delete and re-create the group.
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
Message 4 of 8
brad.bylls
I am not trying to ADD to the group.
I cannot CREATE the group with the move in it.
It tells me that the move does not have a timelineObject.
Brad Bylls
Message 5 of 8
brad.bylls
I was not trying to add to a group, I was trying to create the group with 'move' in it and couldn't get the 'timelineObject' for the moveFeats.
Turns out all I needed to do was
Brad Bylls
Message 6 of 8
kandennti
@brad.bylls .
index is a read-only property and cannot be assigned to.
Message 7 of 8
brad.bylls
@kandennti yes I know.
I was just getting the number.
Brad Bylls
Message 8 of 8
kandennti
@brad.bylls .
I think "moveFeats" refers to the adsk.fusion.MoveFeatures object.
The corresponding adsk.fusion.MoveFeature object must be retrieved with the Item method.
