Synthesis plugin does not run
Message 1 of 10
Recently, I installed Fusion 360 and Synthesis. However, when I go into fusion, I see the "Robot exporter" plugin. When I try to run it however, nothing happens. The popup windows disappear and revert to as if nothing has happened. I have made sure that I have installed fusion and then synthesis and that both are the latest version. However, I am still getting the same error.
Nick
Replies (9)
Message 2 of 10
Same problem for me.
Message 3 of 10
bgapinski
I too, am having this same problem.  I have tried on multiple computers as well.  Has anyone been able to resolve this.
Message 4 of 10
I think it is a problem with his build of either synthesis or fusion. I'm
going to try flashing back a version and see what happens when I get home
tonight.
Message 5 of 10
bgapinski
I got it fixed!  I followed the readme from this github repository,
https://github.com/Autodesk/synthesis/tree/master/exporters/FusionRobotExporter
I had errors along the way but just essentially ignored them and it somehow fixed the problem.  It is now showing up appropriately.
Message 6 of 10
I've been having this issue as well and I'm glad there's a solution, but the repository doesn't seem to exist.  😕
Message 8 of 10
This branch does work. Thanks.
I seem to be having an issue with step 4: "Change Debug command in project settings to the Fusion 360 executable." I don't see FusionRobotExporter Properties under Debug. Could there be a reason why?
Message 9 of 10
JeromeBriot
It seems to work with Visual Studio 2015 :
Message 10 of 10
910649XYK3C
Observer
Observer
hey was really looking for this but the link doesn't seem to work. Any way you could update it?
@bgapinski
