Spyder trouble
Spyder trouble
brad.bylls
Message 1 of 9
Spyder trouble
brad.bylls
When I click 'Edit' to work on a script, nothing happens, Spyder does not come up with the script.
Brad Bylls
Accepted solutions (3)
Replies (8)
Message 2 of 9
Rushikesh.kadam
@brad.bylls, Spyder is replaced by VS Code in September 2019 release.
Here is a link to one of the post https://forums.autodesk.com/t5/fusion-360-api-and-scripts/python-upgraded-to-3-7-3-and-spyder-replac...
If my reply was helpful, please give a "Like" or click the "Accept as Solution" button below (or both).
Rushikesh Kadam
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 9
JeromeBriot
You can't use Spyder anymore. The official IDE is now Visual Studio Code.
There is also an alternative for PyCharm (see here).
Message 4 of 9
brad.bylls
Hi Rushikesh,
Thanks for the update, however, when I debug in VSC I get an error message:
Exception has occurred: ModuleNotFoundError
No module named 'adsk'
This is at line 4:   import adsk.core, adsk.fusion, traceback
Brad Bylls
Message 5 of 9
brad.bylls
Just realized that the script was already in VSC when I got the error message. Fusion was not open.
However, when I go to debug the script from Fusion360. nothing happens.
A dos window pops up for a second and then nothing, no VSC window for debugging.
Do I need to do something in Fusion to set it for VSC?
Brad Bylls
Message 6 of 9
Rushikesh.kadam
@brad.bylls can you try below steps and see if it works:
- Close Fusion and VS Code and launch VS Code independently.
- go to the Extensions tab in VS Code
- click on the Settings button ⚙ of the Python extension
- select "Install Another Version..."
- select 2019.9.34911
- close VS Code
- Launch Fusion and try to debug a script.
You can refer the content under 'Problem debugging Python code' of https://modthemachine.typepad.com/my_weblog/fusion-360/
Rushikesh Kadam.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
Message 7 of 9
JeromeBriot
Actually, it works with newer versions of the plugin (e.g. 2020.6.91350)
Message 8 of 9
brad.bylls
Thank you, that worked.
It is an older version than what I had but . . .
Brad Bylls
Message 9 of 9
brad.bylls
This works also, so I will keep the newer version.
Thank you.
Brad Bylls
