Is there any way to hook into TriangleMeshCalculator to know what face a triangle came from?
marcosscriven
marcosscriven
I've been looking at both TriangleMeshCalculator to see if there's some callback as it creates a mesh from a BRep, and the TriangleMesh object to see if it's there as some attribute on the triangles. I can't find anything like this.
There's several use cases for this I can think of, but two are:
1. To be able to know what face in the original brep each triangle came from
2. To be able to modify how the mesh calculator works, or even write a new one. For instance, so I could create a spherical surface in a completely different way, such as a subdivided icosahedron.
One workaround I thought of was to take the mesh calculator from each face, but then one is tasked with manually stitching those meshes together.
BrianEkins
If you get the triangles from each face and used the same tolerance when calculating the triangles, the triangles should be calculated in a way that when the triangles from each face are reassembled they should be watertight without any need to do any modification.
Brian Ekins
marcosscriven
Thanks @BrianEkins
I assume that implies there is indeed no way to get a whole body mesh directly and determine a link to faces?
BrianEkins
That's right, it's not currently possible.
Brian Ekins
marcosscriven
I wish there were way to mark something as “not possible”, as it’s disappointing when you find a “solved” topic on a forum and it turns out it’s not possible.
I’ll try the workaround I was trying to avoid. It’s still annoying having these edges I’ll have to join. I don’t like the idea of just hoping, and in any case I want a connected mesh, not just a bag of triangles.
