Spiral help needed
Spiral help needed
brad.bylls
Spiral help needed
brad.bylls
Seeing as how the coil functions aren't available in the API even though all the info is in the help files, I have created a script for a plain spiral using height and pitch to basically create a spring.
I am then trying to create a sweep along the path of the spiral.
The problem is the FeatuersOperation, an error occurs that I don't understand.
Any help greatly appreciated.
Thank you.
This was hacked from Brian Ekins Archimedean spiral code.
import adsk.core
import adsk.fusion
import traceback
import math
ui = None
try:
    app = adsk.core.Application.get()
    ui = app.userInterface
    des = adsk.fusion.Design.cast(app.activeProduct)
    root = des.rootComponent
    # Create a new sketch.
    sketch = root.sketches.add(root.xYConstructionPlane)
    # Create points on the spiral
    pnts = adsk.core.ObjectCollection.create()
    # Convert to inches
    diam = .9 * 2.54
    height = 3 * 2.54
    pointsPerRev = 10
    pitch = .2 * 2.54
    rad = diam / 2
    y = 0
    z = 0
    pnts.add(adsk.core.Point3D.create(rad, y, z))
    angle = 360 / pointsPerRev
    newAngle = angle
    for i in range(pointsPerRev * round(height / pitch) + 5😞
        calcAngle = newAngle * math.pi / 180
        x = rad * math.cos(calcAngle)
        y = rad * math.sin(calcAngle)
        z += pitch / pointsPerRev
        pnts.add(adsk.core.Point3D.create(x, y, z))
        newAngle = newAngle + angle
    path = sketch.sketchCurves.sketchFittedSplines.add(pnts)
    crossSketch = root.sketches.add(root.xZConstructionPlane)
    rectLines = crossSketch.sketchCurves.sketchLines
    center = pnts[0]
    crossRectangle = rectLines.addCenterPointRectangle(center, adsk.core.Point3D.create(center.x + .105, center.y + .05, center.z))
    prof = crossSketch.profiles.item(0)
    sweeps = root.features.sweepFeatures
    sweepInput = sweeps.createInput(prof, path, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
    sweep = sweeps.add(sweepInput)
except:
    if ui:
        ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brad Bylls
MichaelT_123
Hi Mr Brad Bylls,
Consider to look deeper into what path is in:
Regards
MichaelT
MichaelT
brad.bylls
Hello Michael T.
Thanks for the response.
I found this and added it to my code:
 thePath = sketch.sketchCurves.sketchFittedSplines.add(pnts)
 path = adsk.fusion.Path.addCurves(self, thePath, 0)
The problem now is, I don't know how to define self to see that it works.
Brad Bylls
