How does one Insert a Design sketch or body or component from one drawing file into another Design drawing file, Similar to Insert Block in the Old Autocad?
tperam
tperam
(a) using API Preferably C++
(b) using UI Pull down menus.
When I Copy or Cut from one design drawing file window Fusion 360 has no Paste option in a new design drawing file window.
Thurai
PinRudolf
Unfortunately the drawings API is not yet available. (Though it is hinted that it is in development, we might see new drawing api features coming next year?) This limits what you can do and I don't think you can place sketch items yet.
You might have better luck using the text commands, though I'm not sure if there are any for this purpose.
@kandenntimade a great post about this subject; check it out here. He also posted a list of available commands here. I gave it a quick look but could not find anything about adding sketches.
kandennti
Hi @tperam .
I've never used AutoCAD, so I don't know how it works.
I remembered that there is this command in TextCommands.
https://github.com/kantoku-code/Fusion360_Small_Tools_for_Developers/blob/master/TextCommands/TextCo...
Even before the sketching feature was implemented in Drawing, I was able to use "FusionDoc.ExecuteAcadCommand" to draw lines.
( You could even save the drawn line to a file.)
You may also be able to use the desired command.
If it works, it would help others if you could leave a note.
@PinRudolf .Thanks for the introduction.
tperam
Thanks Kandennti and PinRudolf for responding.
Thurai
