Setting and Unsetting Occurrence.isIsolated does not match UI behavior
jsormaz
jsormaz
Using `Occurrence.isIsolated = True` and later `Occurrence.isIsolated = False` results in the occurrence being the only visible item.
In the UI, right click>isolate and right click>Unisolate results in the original item visibility (whatever you had shown / hidden before the action)
Instagram:
@sonsofsormaz
rohit.bapat
Hello @jsormaz
Thank you for posting your query. I tried a quick sample with following script and it worked. Maybe I am missing something. Can you please post the script you are using?
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        occ = root.allOccurrences[0]
        occ.isIsolated = True
        ui.messageBox('Sample Dialog','Sample dialog to pause operations. Click ok')
        occ.isIsolated = False
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Rohit Bapat
Product Owner
jsormaz
Thanks @rohit.bapat
I dug in a little more. It looks like the component I was trying to isolate was a referenced component, so I guess isIsolated is undefined in that case (there isn't even a ui option to isolate a referenced component).
Curious if there are alternatives. I'm trying to walk through the component tree and take special images of each component. My workaround right now is to Documents.open() the referenced component, take the image, then close that component, which feels a little clunky, as there may be multiple levels of referenced components in a tree.
Instagram:
@sonsofsormaz
