Script that makes a component from a face selection and extrude.
tookemtoni
tookemtoni
Hello There, Is it possible to make a script that makes a component from face selection and extrude? See demo video.  The design intent is to make edge banding easier.
kandennti
Hi @tookemtoni -San.
I made a simple sample.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        msg: str = 'Select Face'
        selFilter: str = 'Faces'
        sel: core.Selection = select_ent(msg, selFilter)
        if not sel:
            return
        create_extrude_with_new_component(sel.entity)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def create_extrude_with_new_component(
        face: fusion.BRepFace
) -> None:
    comp: fusion.Component = face.body.parentComponent
    extrudeFeats: fusion.ExtrudeFeatures = comp.features.extrudeFeatures
    extrudeFeats.addSimple(
        face,
        core.ValueInput.createByReal(1.0),
        fusion.FeatureOperations.NewComponentFeatureOperation,
def select_ent(
    msg: str,
    filterStr: str
) -> core.Selection:
    try:
        ui: core.UserInterface = app.userInterface
        sel = ui.selectEntity(msg, filterStr)
        return sel
    except:
        return None
tookemtoni
Dear @kandennti,  Magic. Thank You.  See demo video
