Save Dxf file Automatically
isocam
isocam
Can anybody help???
I have the following script file:
import adsk.core, adsk.fusion, traceback
import os
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        sketches = []
        for seln in ui.activeSelections:
            sketch = adsk.fusion.Sketch.cast(seln.entity)
            if sketch:
                sketches.append(sketch)
            for sketch in sketches:
                fullpath = os.path.join('C:\Pda', sketch.name)
                ui.messageBox(fullpath)
                sketch.saveAsDXF(fullpath + '.dxf')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
When I run it, I need to firstly, manually select the sketch.
Is there any way that the above script can be modified so that "Sketch1" is always automatically selected without me having to manually select it first???
Many thanks in advance!!!!!
Darren
erik
If you know in what component the sketch is located and the name of the sketch you can use the following code to get the sketch.
import os
def run(context):
    ui = None
    try:
        design = app.activeProduct
        rootComp = design.rootComponent
        sketch = rootComp.sketches.itemByName("SketchName")
    except:
        if ui:
The code will retrieve a sketch named: SketchName located in the root component.
If you have any further questions or this didn't solve the issue please write again.
- Erik
