Running WriteUserIfToFile causes an abort when accessing a specific workspace
epm
epm
hi
when trying to run the sample script WriteUserIfToFile.py, an error is generated when the script tries to access the count field of the MSFNesting workspace ...
attached copies of the error messages generated, the first error is from a script unmodified. Then the script was modified to display the workspace.if of the next workspace being accessed ..
- latest code (i think updated yesterday automatically)
- win10 environment
regards
eric
JeromeBriot
I can reproduce the bug in the script: Write user interface to a file
The bug is in workspace.toolbarPanels.count at line 50
Replace this faulty line with a try-except statement:
            try:
                msg = '   ' + workspace.id + ' (' + str(workspace.toolbarPanels.count) + ')____\n'
            except:
                msg = '   ' + workspace.id + ' (????????????????????)____\n'
Here is the line in the created file:
MSFNesting (????????????????????)____
epm
hi
i realize for production code one uses try/catch ...
however:
1) this is sample code from the fusion documentation site
2) error seems to indicate some sort of internal error/corruption of an autodesk internal component... now is this if concern to anyone?? its easy enough to mask it ...
regards
eric
JeromeBriot
@goyals, I think you have to log this one in your bug tracking system.
epm
hi
woops... i thought this was it ...
where should i go to report it??
regards
eric
JeromeBriot
You did it the right way. This forum is the best place to report API related bugs.
goyals
This is known problem to us and We are working on fixing our samples provided in API documentation. Thanks.
Shyam Goyal
Sr. Software Dev. Manager
