rootComponent.allAsBuiltJoints returns an error
dwrCons
Message 1 of 9
dwrCons
I'm pretty new to the Fusion 360 API and python. I've been trying to manipulate various joints in a very complex model. In order to do that, I have to find the joints (regular and As-Built). I've been struggling. To simplify the analysis of my problems, I've created a simple script to just find all the As-Built joints. It fails.
I've read everything I can from the forum and haven't been able to solve this issue. This is the code:
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        rootComp = design.rootComponent
        aj = rootComp.allAsBuiltJoints
        ui.messageBox('Number of Joints: ' + str(aj.count))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
This is the error message:
Failed:
Traceback (most recent call last):
File "C:/Users/DWR/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Scripts/FindJoint2/FindJoint2.py", line 14, in run
File "C:\Users/DWR/AppData/Local/Autodesk/webdeploy/production/3167d85f5fd4280287d8295f20592fa13b977617/Api/Python/packages\adsk\fusion.py", line 55135, in _get_allAsBuiltJoints
return _fusion.Component__get_allAsBuiltJoints(self)
RuntimeError: 3 : object does not belong to the occurrence's component
I also can't figure out how to count the number of items in the returned list, but that is another problem.
Thanks, in advance for any help you can provide.
Replies (8)
Message 2 of 9
Jorge_Jaramillo
I couldn't reproduce the error in my environment.
Some points to check here:
1. Are you in the Design workspace? (otherwise design variable gets a None value)
2. The error message say it crashes on line 14, but in you code line 14 is something else.  They don't match. It look's like you're running a variant of the code snippet you shared.
3. Component's allAsBuiltJoints property returns list[AsBuiltJoint], so you have to check for len(rootComp.allAsBuiltJoints) to get number of joints, instead of count property.
Jorge Jaramillo
Software Engineer
Message 3 of 9
dwrCons
Thank you Jorge.
1. Yes, I am running the script from the Design workspace.
2. Apparently, the line numbers change when you paste a code sample, renumbering from the top of the sample. Here's the revised code, with everything (including the changes you suggest in your #3):
#Author-
#Description-
def run(context):
    ui = None
    try:
        numJoints = str(len(rootComp.allAsBuiltJoints))
        ui.messageBox('Number of Joints: ' + numJoints)
    except:
        if ui:
 3. I've made the change you suggested, but obviously it can't yet work until I resolve #2. BTW, when I run this script using rootComp.asBuiltJoints (and aj.count) I get the results I expect. No error message.
Here's the new error message (using allAsBuiltJoints). Same as the old one.
Failed:
Thanks again!
Message 4 of 9
Jorge_Jaramillo
Could you share the model you're working with?
Message 5 of 9
dwrCons
I could, but the F3Z file is very large: 740MB. Are there limits, before I break something?
Message 6 of 9
Jorge_Jaramillo
Could you try your code snippet with a simpler model o even with an empty model?
Just to check if your problem is due to the model or your environment?
Message 7 of 9
dwrCons
Good idea. I ran the script on several smaller files, even ones with joints in subcomponents. All were successful. It must be a problem with my large model. Any suggestions?
Message 8 of 9
Jorge_Jaramillo
Somehow you broke the model.
I'd suggest make a copy, delete all joints, save it, and start adding them one by one while you check with the script it isn't braked again.
Message 9 of 9
dwrCons
Will do. Thanks for your help.
