TriadCommandInput not setting initialTransform
Joshua.mursic
Joshua.mursic
When trying to set the initial position of the Triad command,
initialMatrix = occurence.transform2
app.log(f'{occurence.transform2.asArray()}')
transformInput = inputs.addTriadCommandInput("constructionTransform",initialMatrix)
app.log(f'{transformInput.transform.asArray()}')
these are the logs,
(1.0, 5.551115123125783e-17, 5.551115123125783e-17, -2.466307277628033, 0.0, 1.0, 0.0, -2.2102425876010776, 0.0, -2.7755575615628914e-17, 1.0, 0.7004493042826652, 0.0, 0.0, 0.0, 1.0)
(1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0).
Am I using the command input object incorrectly?
kandennti
Hi @Joshua.mursic -San.
The fact that addTriadCommandInput cannot be set with any Matrix3D seems like a bug.
However, if I set it in the transform property, I get the result I want when it is displayed.
transformInput.transform = initialMatrix
During the commandCreated event, transformInput.transform.asArray did not get the correct values.
My guess is that this is because Command.commandInputs is not created until the commandCreated event is completed.
The following sample outputs transformInput.transform.asArray by pressing the OK button.
# Fusion360API Python script
import traceback
import adsk
import adsk.core as core
import adsk.fusion as fusion
_app: core.Application = None
_ui: core.UserInterface = None
_handlers = []
CMD_INFO = {
    'id': 'kantoku_test',
    'name': 'test',
    'tooltip': 'test'
transformInput: core.TriadCommandInput = None
class MyCommandCreatedHandler(core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandCreatedEventArgs):
        try:
            global _handlers
            cmd: core.Command = core.Command.cast(args.command)
            inputs: core.CommandInputs = cmd.commandInputs
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onExecute = MyExecuteHandler()
            cmd.execute.add(onExecute)
            _handlers.append(onExecute)
            app: core.Application = core.Application.get()
            des: fusion.Design = app.activeProduct
            root: fusion.Component = des.rootComponent
            occ: fusion.Occurrence = root.occurrences[0]
            initialMatrix: core.Matrix3D = occ.transform2
            app.log(f"occ.transform2:{initialMatrix.asArray()}")
            global transformInput
                initialMatrix
            app.log(f"Command Created Event:{transformInput.transform.asArray()}")
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyExecuteHandler(core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandEventArgs):
        _app.log(f"Command Execute Event:{transformInput.transform.asArray()}")
class MyCommandDestroyHandler(core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        adsk.terminate()
def run(context):
    try:
        global _app, _ui
        _app = core.Application.get()
        _ui = _app.userInterface
        cmdDef: core.CommandDefinition = _ui.commandDefinitions.itemById(
            CMD_INFO['id']
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition(
                CMD_INFO['id'],
                CMD_INFO['name'],
                CMD_INFO['tooltip']
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
Joshua.mursic
Yes I think this is a bug, thank you @kandennti
I am trying to create a function to prompt the user to transform a component. They get instances like this where the rotation triad is not aligned well with the part. To rotate the cube around its flat faces instead of the corners it become difficult. I made a button so the user can adjust the triad and align it how they want without rotating the part, but I am having a hard time getting the movement to be correct.
When using the directional arrows the motion is correct, but when using the plane movement is unexpected.
import adsk.core, adsk.fusion, adsk.cam, traceback
app = adsk.core.Application.get()
ui  = app.userInterface
handlers = []
cmdID = "testButton"
gOccurrence:adsk.fusion.Occurrence = None
allowRotate:bool = True
transformMatrix:adsk.core.Matrix3D = None
def run(context):
    global cmdID
    try:
        # Get the CommandDefinitions collection.
        cmdDefs = ui.commandDefinitions
        # Create a button command definition.
        button = cmdDefs.addButtonDefinition(cmdID, 'Test', '')
        # Connect to the command created event.
        created = Create_Command()
        button.commandCreated.add(created)
        handlers.append(created)
        # Execute the command.
        button.execute()
        # Keep the script running.
    except:
        if ui:
def stop(context):
    global cmdID
    try:
        # Delete the command definition.
        cmdDef = ui.commandDefinitions.itemById(cmdID)
        if cmdDef:
            cmdDef.deleteMe()
    except:
# Event handler for the commandCreated event.
class Create_Command(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: adsk.core.CommandCreatedEventArgs):
        global gOccurrence,transformMatrix
        try:
            cmd = args.command
            inputs = cmd.commandInputs
            design:adsk.fusion.Design = app.activeDocument.products.itemByProductType("DesignProductType")
            root:adsk.fusion.Component = design.rootComponent
            occurrence = root.occurrences.item(0)
            #set global variables
            gOccurrence = occurrence
            transformMatrix = occurrence.transform2
            #create triad input
            transformInput = inputs.addTriadCommandInput("constructionTransform",transformMatrix)
            transformInput.transform = transformMatrix
            transformInput.isVisible = True
            #create bool input
            alignTriadButton = inputs.addBoolValueInput("alignTriad","Align Transformer",True)
            execute = Command_Execute()
            cmd.execute.add(execute)
            handlers.append(execute)
            inputChanged = Input_Changed()
            cmd.inputChanged.add(inputChanged)
            handlers.append(inputChanged)
            preview = Preview()
            cmd.executePreview.add(preview)
            handlers.append(preview)
            destroy = Destroy()
            cmd.destroy.add(destroy)
            handlers.append(destroy)
        except:
class Destroy(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: adsk.core.CommandEventArgs):
        global gOccurrence,transformMatrix,allowRotate,handlers,cmdID
        handlers = []
        gOccurrence = None
        transformMatrix = None
        allowRotate = True
        if cmdDef:
            cmdDef.deleteMe()
class Command_Execute(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        global gOccurrence
        gOccurrence.transform2 = transformMatrix
class Input_Changed(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: adsk.core.InputChangedEventArgs):
        global transformMatrix,gOccurrence,allowRotate
        input = args.input
        transformInput:adsk.core.TriadCommandInput = args.inputs.itemById("constructionTransform")
        rotateTriad:adsk.core.BoolValueCommandInput = args.inputs.itemById("alignTriad")
        if input == rotateTriad and rotateTriad.value == True:
            allowRotate = False
        if input == rotateTriad and rotateTriad.value == False:
            allowRotate = True
        if input == transformInput:
            #get the matrix of change between last transform and this one
            fromMat = transformInput.lastTransform.getAsCoordinateSystem()
            toMat = transformInput.transform.getAsCoordinateSystem()
            changeMat = adsk.core.Matrix3D.create()
            changeMat.setToAlignCoordinateSystems(fromMat[0],fromMat[1],fromMat[2],fromMat[3],toMat[0],toMat[1],toMat[2],toMat[3])
            transformMatrix = gOccurrence.transform2
            transformMatrix.transformBy(changeMat)
class Preview(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        if allowRotate:
kandennti
I found the cause.
The direct cause is this part.
        if allowRotate:
I made the changes to do the processing you want.
handlers = []
# allowRotate:bool = True
backupMatrix: adsk.core.Matrix3D = None
def run(context):
    global cmdID
    try:
        button.execute()
    except:
        if ui:
def stop(context):
    global cmdID
    try:
        if cmdDef:
            cmdDef.deleteMe()
    except:
    def __init__(self):
        super().__init__()
        try:
            cmd = args.command
            #create triad input
            #create bool input
            alignTriadButton.value = True
            # execute = Command_Execute()
            # cmd.execute.add(execute)
            # handlers.append(execute)
            preview = Preview()
            destroy = Destroy()
        except:
    def __init__(self):
        super().__init__()
        # global gOccurrence,transformMatrix,allowRotate,handlers,cmdID
        global gOccurrence,transformMatrix,handlers,cmdID
        handlers = []
        gOccurrence = None
        # allowRotate = True
        if cmdDef:
            cmdDef.deleteMe()
# class Command_Execute(adsk.core.CommandEventHandler):
#     def __init__(self):
#         super().__init__()
#     def notify(self, args: adsk.core.CommandEventArgs):
#         gOccurrence.transform2 = transformMatrix
    def __init__(self):
        super().__init__()
        global transformMatrix,gOccurrence#,allowRotate
        input = args.input
        global backupMatrix
        if input == rotateTriad:
            transformInput.setRotateVisibility(
                rotateTriad.value
            transformInput.transform = backupMatrix
        backupMatrix = transformInput.transform
        # if input == rotateTriad and rotateTriad.value == True:
        #     # allowRotate = False
        #     transformInput.setRotateVisibility(
        #         True
        # if input == rotateTriad and rotateTriad.value == False:
        #     # allowRotate = True
        #         False
        # if input == transformInput:
        #     #get the matrix of change between last transform and this one
        #     fromMat = transformInput.lastTransform.getAsCoordinateSystem()
        #     toMat = transformInput.transform.getAsCoordinateSystem()
        #     changeMat = adsk.core.Matrix3D.create()
        #     changeMat.setToAlignCoordinateSystems(fromMat[0],fromMat[1],fromMat[2],fromMat[3],toMat[0],toMat[1],toMat[2],toMat[3])
        #     transformMatrix = gOccurrence.transform2
        #     transformMatrix.transformBy(changeMat)
    def __init__(self):
        super().__init__()
        # if allowRotate:
        transformInput:adsk.core.TriadCommandInput = args.command.commandInputs.itemById("constructionTransform")
        gOccurrence.transform2 = transformInput.transform
        des: adsk.fusion.Design = app.activeProduct
        des.snapshots.add()
        args.isValidResult = True
Joshua.mursic
Thank you very much for your help!
BrianEkins
I wasn't following this thread very closely. Was it an error in the code, or is there a bug in the API?
Brian Ekins
Joshua.mursic
Hey @BrianEkins, it seems like an API bug.
when using addTriadCommandInput, the initial matrix that is provided is ignored or not used (line1).
But can be later set after the command Input has been created (line2).
