Retrieve mesh data from API
In my current project I am creating a plugin for Fusion 360 and I need the mesh representation of all the existing objects one by one. I have found that I can calculate the meshes with  TriangleMeshCalculator, but ( with default values ) the result seems to be incorrect.
Could anyone point me to any tutorial or documentation on how mesh information retrieval should be done properly?
(I am using C++, but you can give me example with any language!)
Any help would be greatly appreciated.
ekinsb
Creating new meshes using the TriangleMeshCalculator should work but if you're seeing problems I would be interested in seeing a specific test case to verify if there is a problem.
When needing a mesh of an existing body, I typically use the displayMeshes property of the MeshManager object and then use the bestMesh property of the returned TriangleMeshList object.  The primary reason for this is that it will be much faster because it's return an existing mesh rather than creating a new one.  In either case though, you'll end up with a TriangleMesh object that contains all of the mesh information.
Brian Ekins
Mod the Machine blog
Hi Brian,
Thank you for your answer. I have managed to get accurate mesh information from the BestMesh method, but the received mesh is missing texture coordinates.
In my test project I have a cylinder that has both physical material and appearance texture assigned.
Is it normal that the texture coordinates are empty in case of BestMesh?
Thank you for your response in advance!
ekinsb
Unfortunately, we're not yet supporting the export of texture information.  This is planned for the future but there isn't a specific date when it might be available.
Brian Ekins
