Redefining Construction Plane?
When it comes to modifying things, instead of creating them new, I find it very hard to find information or examples.
I'm trying to redefine an offset construction plane but I'm not getting it...
This was my "best bet" but I get an error: "ConstructionPlaneOffsetDefinition_redefine', argument 2 of type 'adsk::core::Ptr< adsk::core:ValueInput > const &'
What am I missing or doing wrong?
xzPlane = rootComp.xZConstructionPlane
planeLeftEyeOP = rootComp.constructionPlanes.itemByName('Plane_LeftEyeOP')
planeDefinition = planeLeftEyeOP.definition
planeDefinition.redefine(newOffsetValue, xzPlane)
Never mind.
I don't know why I need to do that here and not when I modify a sketch line for example, but defining the offset value like this worked:
newOffsetValue = adsk.core.ValueInput.createByReal('newOffset')
kandennti
Hi ljkCRMAD.
Create an offset plane.
Then run a script and select a plane.
# Fusion360API_Python script
# +1Cm offset plane
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        # select
        msg = 'select offset plane'
        pln = selectOffsetPlane(ui, msg)
        if not pln: return
        # +1Cm
        prm :adsk.fusion.ModelParameter = pln.offset
        prm.value += 1
        ui.messageBox('Done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def selectOffsetPlane(
    ui :adsk.core.UserInterface,
    msg :str) -> adsk.fusion.ConstructionPlaneOffsetDefinition:
    filtterStr = 'ConstructionPlanes'
    offPlnDef = adsk.fusion.ConstructionPlaneOffsetDefinition
    while True:
        try:
            sel :adsk.core.Selection = ui.selectEntity(msg, filtterStr)
            offPln = offPlnDef.cast(sel.entity.definition)
            if not offPln:
                ui.messageBox('Type is OffsetPlane only!')
            else:
                return offPln
        except:
            return None
MichaelT_123
Hi Fellows,
Why not right-click a constPlane in the Browser and perform the task.
Writing a good self-sufficient universal script would require some hard yakka.
Regards
MichaelT
MichaelT
Hi guys
Thanks for the replies, but as I wrote in my own reply, I already found the solution 🙂
The reason for doing this is because I'm creating an Add-In (actually just finished) that users in the production apartment of my company, with zero experience with CAD software, will be using many times a day.
Punching in some numbers in a dialog box and pressing OK is all they have to do...
I wouldn't be creating a script to change the definition of a construction plane under normal circumstances 😉
MichaelT_123
... the nice human approach.
Congrats
MichaelT
MichaelT
